Old 26th May 2009, 11:22   #1
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.
That cant be right lol!
Having a clearout in work and found a few Dell Optiplex PC's with 3ghz Pentium 4 CPU's in.
Thought I would see how well they would fold so I used Fred's Linux SMP client and VMware player, I had to drop the VM to use 1 CPU and memory to 376mb as the machine only has 512mb to begin with but it booted ok and after an hour of it sat at 100% going up 2% and producing some SERIOUS heat it came back with 126 PPD!!!
Yes that was 126 PPD - I didn't leave a number off lol
Is that right do you think? its a Northwood D1 revision CPU (non-hyperthreaded)
Dont think im going to run them some how unless I can get half decent PPD out of them, anything im missing here?
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 26th May 2009, 12:00   #2
MrGumby
CPC 464 User
MrGumby's Avatar
MrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run CrysisMrGumby can run Crysis
My working assumption was that core2 at 3ghz is almost twice as a P4 at 3ghz. Depending on the application. What memory is it using? Ive also been told that folding likes memory bandwith. But im a novice at folding so dont quote me.
MrGumby is offline   Reply With Quote
Old 26th May 2009, 15:00   #3
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.
Old CPU architechture, new WU's... I'm guessing that it's about right unfortunately!
Unicorn is offline   Reply With Quote
Old 26th May 2009, 16:44   #4
saspro
Infrastructure Specialist
saspro's Avatar
saspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpit
Sounds right, SMP on 1 CPU shouldn't work though?
P4's are only good for the standard client or as mules for GPU's
__________________
If what I've said helps you please remember to hit the rep button on the left
Missing the old meeting place? Find us here
saspro is offline   Reply With Quote
Old 26th May 2009, 17:45   #5
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.
I had a P4 660, and it used to produce an average 510 PPD - though on some WU's it only produced 90 PPD!!
DocJonz is online now   Reply With Quote
Old 26th May 2009, 19:01   #6
Deadpunkdave
...why you need a 20-sided die
Deadpunkdave's Avatar
Deadpunkdave has yet to learn the way of the DremelDeadpunkdave has yet to learn the way of the DremelDeadpunkdave has yet to learn the way of the DremelDeadpunkdave has yet to learn the way of the Dremel
As I understand it, they decide the credit for CPU work units by running them on a P4 @ 2.8GHz and multiplying the number of days taken by 220 i.e. a P4 @ 2.8 GHz earns 220ppd across all WU. I'm not sure if they normalise the SMP client WUs in the same way (I would guess they don't) but as a rough guide, that's what you can expect from older CPUs.
__________________
Folding stats
Deadpunkdave is offline   Reply With Quote
Old 26th May 2009, 19:24   #7
SazBard
10 Print "C64 ftw"
SazBard's Avatar
SazBard has yet to learn the way of the Dremel
my athlon xp2600+ produces more than that!
What memory does it have? ddr2 533?
Also it may give a rubbish ppd figure at first, but once it completes a wu, it should go up.
It's not worth using smp client because it will never finish the wu before the deadline.
__________________
Folding stats
SazBard is offline   Reply With Quote
Old 26th May 2009, 20:01   #8
Thaifood
Multimodder
Thaifood's Avatar
Thaifood has yet to learn the way of the DremelThaifood has yet to learn the way of the Dremel
err my althon 6000 has got project 4438 and it says my ppd is 137!!
__________________
i5 2500K @ 4.6GHz / Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler / Asus P8Z68-V LE /Crucial Ballistix Sport 8GB 1600MHz / Sapphire HD 7850 / 1TB HDD / OCZ Stealth X Stream 2 600 WATTS / LG IPS225
Thaifood is offline   Reply With Quote
Old 26th May 2009, 21:35   #9
coolamasta
coolamasta's Avatar
Ah well after some of the things you all said then it must be about right so im not going to bother wasting the electricity on running them for such little PPD.
Makes me laugh about how crap the PPD is yet the heat being pumped out is just silly!
__________________
Old 27th May 2009, 22:37   #10
coolamasta
coolamasta's Avatar
Done another test today - I decommissioned an old IBM server which has dual P4 Xeon CPU's, they are 2.4ghz each with hyperthreading so 4 x cpus appear in task manager.
Stuck a fresh copy of 2003 server on and the SMP client and can anyone guess its PPD?
Will spill the beans tomorrow...
__________________
Old 28th May 2009, 02:24   #11
Unicorn
Unicorn's Avatar
less than 700 per client (i.e. per dual core CPU)?
Old 28th May 2009, 05:59   #12
Norfolk'N'Good
Folding Chimp
Norfolk'N'Good has yet to learn the way of the Dremel
My guess is 480.
__________________
Folding stats
P5Q Pro - E8400@3.6ghz - 4gbOCZ Gold - 2x XFX Alfadog 8800GT - Antec 300 - OCZ SteathXStream 600w
Folding for my family.
Norfolk'N'Good is offline   Reply With Quote
Old 28th May 2009, 13:45   #13
coolamasta
coolamasta's Avatar
The server both CPU's / hyperthreading at 100% load produce a whopping....
370 PPD!!!!!!!!!!!
Shocking lol
__________________
Old 29th May 2009, 13:10   #14
Votick
CHMOD bit-tech 777
Votick's Avatar
Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.
370 PPD!!!!!!!!!!!
Shocking lol
lol mines a bit crap too on my CPU hehe xD
__________________
Folding stats
| AMD FX 8350 @ 4.0GHZ | Gigabyte GA-990FXA-UD5 | 16GB Corsair Vengeance DDR3 1600mhz |
| Corsair Force 3 120GB SSD X 2 RAID0| Corsair H100 | Samsung F3 1TB HDD | MSI GeForce GTX 680 SLI |
| Silverstone 1200W | Corsair 650D | LG IPS225V X 2 |
Votick is offline   Reply With Quote
Old 29th May 2009, 13:44   #15
Unicorn
Unicorn's Avatar
370 PPD!!!!!!!!!!!
Shocking lol
I know every point counts, but I decided a long time ago that my single core A64 wasnt worth running for 400PPD considering the TDP of the chip and the amount of electricity that it was costing to run that rig! Inefficient little bugger of a CPU :P
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
