Thread Tools |
#1 |
Player Character
bit-tech Staff
Sharp announces five-colour display
http://www.bit-tech.net/news/hardwar...lour-display/1
Sharp has created a prototype full-HD 60.5" display which uses five primary colours to render its palette - allowing for 99 percent of the Pointer colour space to be reproduced.
__________________
#2 |
Lazy Lurker
Too bad the only way to see for yourself is to actually go out and see for yourself.
__________________
Technology Schmecnology |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#3 |
Officious Bystander
Awesome, but they will need to combine this with locally dimming LED backlighting if they want their claim of "identical in appearance to real-world object" to be taken seriously
__________________
Demand Naked DSL in the UK! |
#4 |
a.k.a KazeModz
lol ya, I am reminded of Futurama, when Fry is on the couch and they are like Fry why not go out side and check out nature and hes like go out side when I can watch nature on TV in Ultra HiDef, Its better then reality lol.
This is a great step and begs the question, if we are doing it with printers why didnt we do it with LCD but I guess the cost was probably a main factor and they wanted tp bleed us of our money first so that they can then bleed us again but still looking forward to this product but Im certainly NOT looking forward to the price tag it will hold.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#5 |
Hypermodder
this isnt exactly new, ive got monitors that have cyan and magenta inputs
__________________
"I think, therefore I think I am" Zippy the pinhead |
#6 |
DUR HUR
Five primary colours? Have Sharp been breaking science?
#7 | |
Officious Bystander
__________________
#8 | |
Supermodder
My first thought was "I hope they release some videos soon". |
| Skiddywinks |
| Find More Posts by Skiddywinks |
#9 |
Rising Fusion
I've seen that FujiFilm's been selling a digital SLR camera that sees in near-UV and near-IR in addition to visible wavelengths. Maybe they should design a CCD camera that can capture full-frame-rate video in 5 color chanels: IR, R, G, B, and UV, and allow those to be output to this display's 5 primary colors to map the IR to red, red to yellow, green to green (natch), blue to cyan, and UV to blue. I, for one, think that would be a potentially useful tool for scientists, ESPECIALLY astronomers, considering the Hubble Space Telescope's new camera is designed to see in a near-IR to near-UV spectrum. What do you guys think?
#10 | |
Supermodder
#11 | |
Supermodder
But nitpicking aside, we are all aware, right, that this means specific support in any driving technology? You can't have "images indistinguishable from reality" on your pentastimulus display if you don't also have camera or CG rendering gear to match. This can be put in the same category as almost all of the stuff you see on TV feature lists in a haze of misapplied superlatives and fabricated nonwords: "Ultra Quad-X Inendo Hyper Crystal Technology Processor". The reduction of required backlight power is also an interesting claim. Assuming all five subpixels are the same area, basic description of the problem follows: Ordinarily to render yellow you would need to turn on the red and green subpixels, both of which throw away 66% of the backlight, thus allowing through about 22% of the backlight energy that made it through the polariser for that macropixel (33% of two subpixels, each of which is 33% of the area of the macropixel). Instead, you're turning on the yellow pixel, which only throws away 33%, being a secondary colour. But the yellow subpixel is only 20% of the area of the macropixel, so you're only actually transmitting 12% of the energy. The upshot of this is that you actually need a backlight very nearly twice as powerful for the same perceived brightness of a primary colour. I love slightly-rewritten press releases! P |
| Phil Rhodes |
| Find More Posts by Phil Rhodes |
#12 |
Ex nihilo nihil fit
Insightful.
__________________
''Trying is the first step towards failure.'' - Homer Simpson |
#13 |
What's a Dremel?
I love how I always learn something new, and/or get the urge to do further research on something when I peruse your site!
#14 | |
what is the cheesecake?
as for needing separate rendering gear to match the five primary colours in this display, that's not necessarily true either. no monitor can match sRGB space as it stands, and i doubt this one will either, so all you really need is a function mapping sRGB space to the 5 primaries. i assume the cyan and yellow primary frequencies will be chosen to bisect the B-G and G-R lines in the sRGB gamut. i was talking to someone at uni who is doing research into high dynamic range displays and wide colour spaces, and he mentioned a few papers that discussed using additional primaries to narrow the colour gamut, not widen it, due to the shift from fluorescent to LED backlighting which have a completely different spectrum. didn't really go into it in depth, i didn't have much time and i'm a virtual environments guy not an imaging guy, so some of it went a lil over my head.
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D." I'm a pretentious git with a camera. ISPs want to spy on you. Join the fight against phorm XBL/PSN/Steam ID: FodT Last edited by Fod; 2nd Jun 2009 at 15:57. |
#15 | |||
Supermodder
The main problem in both sRGB and rec.709 (and 609, which is only different in the detail) is not any of this, it's green, because TV green is based on what they could make green phosphors do in the CRT days. This is a horrible, feeble lime green (which is what, for instance, the CSS spec calls full sRGB green) and is the main vector for improvement in my mind. The real issue I think is that any improvement in this means creating monitors with a better green, an enhanced RGB colourspace (eRGB?) which will inevitably result in a transition period where people have to know to tell their displays what to expect, or it'll be displayed wrongly. There is already some professional gear out there which has some enhanced colourspace capabilities (the Panavision Genesis and Sony F35 cameras, which use the same imaging sensor) but in a domestic context we have people who can't even set aspect ratios up correctly, so god help the person who adds something else to the mix. P |
| Phil Rhodes |
#16 |
Modder
Ahhh, the green you just spoke about makes it make sense now. So you have the same issues with the additive colour model (RGB) as printers have with the subtractive model (CMY). Poor generation of the correct frequencies to make up the gamut.
#17 |
A Monitor Afficionado..
I wonder if this'll make it to the professional market.
And this better be well, better than their Aquos line, which had a really over-lit backlight. Well in comparison to a Pioneer Kuro of course, which isn't fair at all.
__________________
EP45-UD3P|HIS HD4850 ICE-Q 4 Turbo @ 690/1090|4GB G.Skill DDR2-800 @ 844mhz|HAF932|Antec True Power Trio 550w|E8400@3.8Ghz FSB:421 Volt: Stock|Vortex 752(Heatsink)|Mitsubishi/NEC LCD1860NX Other Build: ECS RS400-A|Prescott P4 @ 3.45Ghz|2GB DDR2 533|OEM ATi X1600XT|Dynex 430w|Some Random Case|Mitsubishi 20" Diamondtron Pro |
| Thread Tools | |
