Thread Tools | View Mode |
#1 |
Black & Dremel
Acrylic Powerplant
I will post my worklog later as soon as I have compiled actual pictures from design to fabrication to assembly.
| Cham_E_Lyon |
| View Public Profile |
| Find More Posts by Cham_E_Lyon |
#2 |
Black & Dremel
By the way, this one bagged the 1st prize of the recently concluded PC Casemod contest here in the Philippines!
| Cham_E_Lyon |
#3 |
I know what a fk'n Dremel is ok.:D
this will be a cool log..
#4 |
Black & Dremel
Thanks sir! I will post my worklog soon!
| Cham_E_Lyon |
#5 |
Black & Dremel
started with a sketch
| Cham_E_Lyon |
#6 |
Black & Dremel
finalizing design for lasercutting
| Cham_E_Lyon |
#7 |
Black & Dremel
lasercut pieces
| Cham_E_Lyon |
#8 |
Black & Dremel
the three-piece leg with external brace painted with Luminous Orange spray paint!
| Cham_E_Lyon |
#9 |
Black & Dremel
Assembled the lasercut motherboard tray
| Cham_E_Lyon |
#10 |
Black & Dremel
used a 6/32 Tap tool mounted on a hand drill to make threads for the motherboard standoffs
![]() put the standoffs to where it should be
| Cham_E_Lyon |
#11 |
Black & Dremel
That's me test fitting the motherboard to the tray
![]() My friend Gabe who represented our 2-man team in the contest!
| Cham_E_Lyon |
#12 |
Black & Dremel
deburred grooves for board tray screwmounts
| Cham_E_Lyon |
#13 |
Black & Dremel
made holes for wire management
| Cham_E_Lyon |
#14 |
Black & Dremel
holes for mounting LEDs
| Cham_E_Lyon |
#15 |
Black & Dremel
deburred the existing hole for the PCI lock
![]() bore holes for the PCI ends to pass
| Cham_E_Lyon |
#16 |
Black & Dremel
Painted a Coolermaster 200mm fan a customer gave from a Cosmos S
![]() Added two more LEDholes from the existing four LEDholes ![]() Lights out LEDs ON
| Cham_E_Lyon |
#17 |
SEXCAKE! SEXCAKE! SEXCAKE!
Good acrylic work there
#18 |
Black & Dremel
| Cham_E_Lyon |
#19 |
Captive nut
Not good acrylic work, great acrylic work considering the workshop!
__________________
Project: Seawolf "Problems cannot be solved by the same level of thinking that created them."
#20 |
Multimodder
I also have to say, very good acrylic work.
| Thread Tools | |
| View Mode | |
