Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Jun 2009, 14:12   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Freescale unveils smartbook concepts
http://www.bit-tech.net/news/hardwar...ook-concepts/1
Freescale has unveiled a range of concept designs for "smartbook" systems - devices based on the company's ARM processors that sit between smartphones and netbooks.
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 8th Jun 2009, 14:14   #2
I-E-D
Registered User
I-E-D has yet to learn the way of the Dremel
Now that, looks cool Pity they won't make it though.
I-E-D is offline   Reply With Quote
Old 8th Jun 2009, 14:42   #3
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
Actually, dependent on how big the keys/spacing is... text input on that wouldn't be all that hard. "Two thumb" text input works fine, provided you don't want to bash out a 200,000 word novel.
Pity they won't actually make it to market... unless someone works with Freescale... but they sound pretty inventive, anyway. The portable device market badly needs a shakeup...
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Old 8th Jun 2009, 15:13   #4
amdavies
Minimodder
amdavies has yet to learn the way of the Dremel
Where's my sub 100 desktop ARM/Linux computer please ?
A net-top version of the ARM netbooks would be fantastic; heck, build them into televisions.
amdavies is offline   Reply With Quote
Old 8th Jun 2009, 15:27   #5
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the Dremel
The problem with that keyboard design is that it leaves little space for internal components, especially if the two halves overlap inside to give a bigger keyboard. I also don't like the fact that the "d-pad" is in the keys, you won't be able to navigate around a site and have text input at the same time.
Also, the keys are all lined up above each other and the space bar is in a silly place.
__________________
i7 920, 5870, 6GB Corsair all in an Intel DX58SO; 60GB Vertex, 1.5TB F2; Fractal Design R2
ThinkPad Edge 13.
Cupboard is offline   Reply With Quote
Old 8th Jun 2009, 18:47   #6
Jenny_Y8S
Guest
Posts: n/a
Oh my that's fugly! I think I'll keep my OQO thank you very much
Old 8th Jun 2009, 19:05   #7
Faulk_Wulf
Internet Addict
Faulk_Wulf's Avatar
Faulk_Wulf has yet to learn the way of the Dremel
You should check out the other ones though. The detachable keyboard/mouse/screen one is pretty cool and I'm very fond of the modular idea.
__________________
-- Faulken S. Wulf
"Under the Willow, he sleeps and dreams, of Heaven."
Looking over my threads, I've come to realize that I have a ridiculous amount of bad luck with my electronics.
Faulk_Wulf is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
