Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Jun 2009, 11:44   #1
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
AMD could move all ATI GPUs to SOI at 32nm - here's why
http://www.bit-tech.net/blog/2009/06...o-soi-at-32nm/
Tim S is offline   Reply With Quote
Old 9th Jun 2009, 12:16   #2
GFC
Multimodder
GFC has yet to learn the way of the Dremel
Mm.. 3ghz gpus that overclock to 4ghz.. here we come! ^^
GFC is offline   Reply With Quote
Old 9th Jun 2009, 20:15   #3
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
So basically I would be getting a GPU that's a CPU but only used for graphics? Not the best example but a Phenom II that's built for graphics?
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 9th Jun 2009, 21:55   #4
pdemon
What's a Dremel?
pdemon has yet to learn the way of the Dremel
Eh, not quite. It would be more like taking a 4870 and building it with the same tools & materials as a Phenom II. Architecture and process are at different levels in design hierarchy. Admittedly the process does effect the overall design and certainly causes some changes in layout but it does not determine the function of a device.
pdemon is offline   Reply With Quote
Old 10th Jun 2009, 00:56   #5
salesman
Multimodder
salesman has yet to learn the way of the Dremelsalesman has yet to learn the way of the Dremel
This was an excellent read Tim. I throughly enjoy reading stuff like this.
__________________
E8400 3.0GHz | ASRock P45X3 Deluxe | EVGA 570 GTX | 8 GB GSkill memory | Crucial M4 64GB Boot Drive | 3x Samsung F3 1TB Raid 0 | 2x Samsung F4EG 1.5TB Raid 0 | Corsair AX750 PSU | Noctua NH-U12P | Antec P180 | M-Audio Audiophile 192 | Marantz PM5004 | Cambridge Soundworks Speakers | Duckey Shine | Dell U2410 |
salesman is offline   Reply With Quote
Old 10th Jun 2009, 05:36   #6
Slyr7.62
«ŚŁÂŶČŘ»
Slyr7.62's Avatar
Slyr7.62 has yet to learn the way of the Dremel
Same here. Thnx Tim, this was quite an interesting article.
__________________
«PNY GTX 260» | «4x1GB Kingston HyperX KHX8500D2K2 Micron D9GKX 1200mhz 5-5-5-15 1.96v»
«Intel E8400 C0 @ 3.6ghz 1.2v Xigmatek HDT-S1283» | «Samsung SH-S223F 22x DVD/CD Burner»
«Gigabyte EP45-UD3R w/ F13e Bios» | «Cooler Master RC690 Modded» | «Ultra 500w X-Finity SLI»
Slyr7.62 is offline   Reply With Quote
Old 10th Jun 2009, 13:27   #7
alpaca
llama eats dremel
alpaca's Avatar
alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.
i do agree!
__________________
my English may not be as good as I think it is...
alpaca is offline   Reply With Quote
Old 11th Jun 2009, 01:06   #8
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
ATI/AMD are hopefully back on the up
confusis is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
