Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
6-core Nehalem coming to LGA1366 this year
http://www.bit-tech.net/news/hardwar...ng-this-year/1
Sources close to Intel say it will release a 6-core Nehalem derivative in roughly the same timeframe as Lynnfield.
__________________
#2 |
Multimodder
It'll be called the i6 at my guess.
Did i read this right? the 6 core CPU will be able to use exactly the same motherboards as the existing i7's? If so, then that's the obvious update for an i7 rather than a i5.
__________________
GND Techlabs |
#3 |
3˛Gaming
Its good to know that if my i7 ever stops being overkill, I have something to upgrade to without needing to change my motherboard and memory again.
Any plans for a 6-core chip for skt 1156?
__________________
Stacker 830 Evo //Core i7-920 ~ 4Ghz (4.2 stable) //Gigabyte EX58-UD5 //Corsair Dominator 6GB 1600Mhz //BFG GTX 285 OCX //BeQuiet! 750w //7200.12 1TB
DDC Ultra 18w //Black Ice 360mm //EK Multioption 250mm //Heatkiller LT CPU Block //MIPS RAM block DDC Ultra 18w //Black Ice 240mm //EK Multioption 150mm //No Blocks yet - Dual Loop i7 Stacker Left Handed? CLICK HERE - |
#4 |
Supermodder
Intel's approach / line up / naming conventions are looking confusing to be honest.
i7 discontinued, to be replaced by i5 which may actually offer better performance ? new 6 core chip for the top end... certainly wont be called i6 which implies 'lesser'. crazy. I actually think it all started to go wrong with the Core Duo and Core2 Duo branding which was also lame. |
#5 |
Minimodder
Does any1 know where they got the i7/i5 branding from?
#6 |
3˛Gaming
Windows 7
Core i7 Just an idea :P
__________________
#7 |
Preparing to commence simulation
its loosely based on psychological studies "even if the product is pants it sells better with an i in front of it!" only joking
__________________
"I was able to look out the window to see this incredible sight of the whole circle of the Earth. Oceans were crystal blue, the land was brown, and the clouds and the snow were pure white. And that jewel of Earth was just hung up in the blackness of space" Charlie Duke Apollo 16 |
| patchcable |
| View Public Profile |
| Find More Posts by patchcable |
#8 | |
Senior Super Douche
#9 |
Modder
So ...
Core Duo = 2 cores Core 2 Duo = 2 cores Core 2 Quad = 4 cores Core i7 = 4 cores / 8 threads Core i5 (may) = 6 cores? For high street consumers, the naming scheme is extremely confusing. It's probably as bad, or worse, as NVIDIA's naming schemes. For example, most high street customers assume that 'Core 2' means 2 cores. A smaller percentage of consumers think 'Core 2 Duo' means 2 plus 2 cores. Some people ( not enthusiasts ) think that 'Core i7' means a new cpu with 7 cores. Intel should completely drop the 'core' branding if the name refers to a chip generation or anything other than the actual number of cores. I believe NVIDIA and INTEL deliberately seek to confuse the public. So a Core i7 sounds like it has more cores than it actually does. A new NVIDIA graphics card is given a name that prevents most people from realising it is based on old architecture and is no different from another card with a different name. |
#10 |
Multimodder
So is that 6 core with hyper threading to 12 simultaneous threads?
| technogiant |
| Find More Posts by technogiant |
#11 |
Multimodder
Yup, 6-core, 12 thread monster.
I believe that the i7 platform will be high-end enthusiast only. i.e. Very expensive. There will be virtually only extreme chips. They are expensive to make and intel wants its profit margins back. i5 will be mainstream, with high-end 4 core, 8 thread, and dual channel memory. low end will be 2 or 4 cores with integrated graphics on chip. the 4 core ones will come at a later date, on smaller process. We may see 6 cores on i5, but not for a while. AMD might get lucky, they have had integrated memory controllers for quite a while now, and adding a third or fourth channel would up the pin count, and give them new success. Won't happen until a new socket tho, just not enough pins atm... Gamers may be stuck with 4 core 8 thread chips, and very powerful GPU's (DX11 etc...). Are we going to be CPU limited because of our budget ? If a high end i5 is going to limit GPU's in SLi or Crossfire, then what ? What if even overclocked it stayed CPU limited ? 6-core AMD ? 8-core AMD ? Not with only two memory channels....6 maybe, but having three cores per memory channel is a little much...large cache will help, but yet again = big chip. I'm not sure why intel brought in the i7 only to take it way way up to the top only.... |
| Evildead666 |
| Find More Posts by Evildead666 |
#12 |
Multimodder
It's official: Intel hates us all.
#13 |
Blame it on the Boogie
Wow, did they hire marketing gurus from ReVidia or something? These naming conventions are getting crazy out of hand!
Anyway, apart from that I think their new positioning actually makes some sense. 1156 for the mainstream, 1336 for tech demo/extravagant setups/server applications. Now all they need is a proper way of communicating that, and they'll be fine. |
#14 |
BSc... finally
Their new lineup will be very balanced... if only they'd get the naming halfway right.
AMD's CPUs are good, no questions asked, but if they don't come up with something as fast as i5 they'll be in major trouble by the end of the year I guess.
__________________
"The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far." Blame it on Cheaps! [now a social group]
#15 |
Supermodder
Looking it up on wikipedia, it seems they went from:
286 386 486 Pentium Pentium II Pentium III Pentium IV Intel Core Intel Core 2 then i7 was going to be called Intel Core 3, but changed their mind because apparently calling it i7 makes it easier in the future to distinguish which are the best processors. I am guessing they will give higher numbers to superior processors, for example i8 may be to core i7 what the 45nm core2 chips are to the 65nm core2 chips. Possibly.
__________________
Dreaming C2D E6300 @ 2.8 | | Abit IP35 Pro | | 4GB Corsair XMS2 800 | | BFG 8800GTS OC2 320MB | | 500GB Western Digital for OS + 1500GB Seagate for Storage | | Antec NeoHE 550 | | Lian Li PC A05B | | Samsung 226BW 22" |
#16 |
RPG Loving Freak
Still happy with my E6600
![]() I may upgrade to a Q6700 if I feel I need more CPU power.
__________________
I am the Black Mage. I cast the spells that makes the peoples fall down! |
| BlackMage23 |
| Find More Posts by BlackMage23 |
#17 |
Modder
Who wants 2 more frames in Crysis!? anyone?... no? yeah, me neither
| cheeriokilla |
| Find More Posts by cheeriokilla |
#18 |
Multimodder
Why does core i5 have to be so crappy on the pcie front...either one x16 or 2 x8's....at the moment the pcie control is still on the chipset and has not yet migrated to the cpu (or has it?) I think a core i5 quad running at 5GHz on air with more pcie lanes would be great for gaming for the foreseable future....so can we have chipsets x56 and x57 please.
| technogiant |
#19 | |
Controlled by Eyebrow Powers™
Core i5 is either 4 cores/4 threads or 4 cores/8 threads, depending on the model. New Core i7 CPUs will be 6 cores/12 threads. And I completely agree with you: the naming aproach is insane. |
#20 |
Multimodder
Lets no forget that the server chips will still be out there and will use the LGA1366 socket...
So as far as upgrading goes, it just means that you have to do a bit more leg work
| droitwichdosser |
| Find More Posts by droitwichdosser |
| Thread Tools | |
