RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Jun 2009, 12:37   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Three Low Profile CPU Coolers Tested
http://www.bit-tech.net/hardware/200...lers-on-test/1
Having tested plenty of mini-ITX kit recently, we've been searching for a quality low profile cooler to squeeze inside our HTPCs. We've bagged three miniature coolers to find out if, when it comes to keeping your system cool, does size matter?
Tim S is offline   Reply With Quote
Old 11th Jun 2009, 12:45   #2
rickysio
Multimodder
rickysio is on a distinguished road
Suits me. My OEM casing only allows for coolers <140mm in height... Even though it's a full ATX case.
Of course, I'd probably best be getting a cooler using 92mm fans, rather than these HTPC coolers.
rickysio is offline   Reply With Quote
Old 11th Jun 2009, 12:57   #3
Jamie
bit-tech Staff
Jamie's Avatar
Jamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of light
I swear I had a taller version of that Akasa cooler on my thunderbird 1.2 GHz about 6 years ago.
ThermoEngine
__________________
bit-tech hosted by tsohost.co.uk
twitter | flickr | xbox live | last.fm | moot
Jamie is offline   Reply With Quote
Old 11th Jun 2009, 13:24   #4
EnglishLion
working for the good of mankind...
EnglishLion's Avatar
EnglishLion is on a distinguished road
Surely testing in an ITX case would have been better afterall that is what these coolers were designed for. Sure it might limit airflow and that might affect the cooling ability of the coolers (maybe even discriminatory) but as that's what these were designed for that 's what the review should try to discover.
Apart from that, good review. Thanks
EnglishLion is offline   Reply With Quote
Old 11th Jun 2009, 14:00   #5
alpaca
llama eats dremel
alpaca's Avatar
alpaca will become famous soon enoughalpaca will become famous soon enough
now you made me curious. does this have any value as GPU cooler (despite its size)?
regardless: good review.
__________________
my English may not be as good as I think it is...
alpaca is offline   Reply With Quote
Old 11th Jun 2009, 15:35   #6
The boy 4rm oz
Get On My Horse!!!
The boy 4rm oz's Avatar
The boy 4rm oz is just really niceThe boy 4rm oz is just really niceThe boy 4rm oz is just really niceThe boy 4rm oz is just really nice
Funny, before I even read this review I knew the Zalman would win lol.
__________________
Project: LEXA FINISHED 30/11/08 (16 months 14 days) MOTM Nominee October 08
Originally Posted by unknowngamer View Post
Waaaay to much eye make up...be like humping a panda.
The boy 4rm oz is offline   Reply With Quote
Old 11th Jun 2009, 16:00   #7
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
Originally Posted by review
although it’s a little disappointing to see that there’s no PWM connection, meaning the fan will run at its full speed of 2,800rpm constantly.
Umm are you trying to tell that there was no on-board fan controllers before the PWM came along just a while back? Surely most motherboards can control the CPU fan speed without 4-pin PWM...
Other than that, good review, and good to see Zalman still making atleast some decent products.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is online now   Reply With Quote
Old 11th Jun 2009, 16:47   #8
Baz
Benchmarketeer
bit-tech Staff
Baz's Avatar
Baz is on a distinguished road
Not all motherboards have the option to do this. The only way to control a 3-pin fan's speed is by adjusting the voltage, a feature which many motherboard's dont support, and if they do, are controller by the motherboard, not the cooler. We'd just end up with a bunch of coolers all performing identically.As such, we test using only using the PWM option of the fan (which can, of course, be overridden by BIOS options itself) or, if a 3-pin, at full speed.
Baz is offline   Reply With Quote
Old 11th Jun 2009, 18:49   #9
IanW
I *am* a Dremel
IanW's Avatar
IanW is a jewel in the roughIanW is a jewel in the roughIanW is a jewel in the rough
My HTPC (Gigabyte GA-E7AUM-DS2H mobo) is currently wearing an Arctic Cooling Freezer 7 LP on its Intel E4400 CPU.
__________________
Q6600@3GHz / AC Freezer 7 Pro / Gigabyte EP35-DS3R / 8GB OCZ Platinum PC6400 / EVGA GTX260 SSC / LG DVDR / 9TB HDD /
OCZ Modstream 780W / CoolerMaster 590 case / Dell E248WFP / Saitek Eclipse II / Logitech G9 / Ubuntu 9.10-64
IanW is offline   Reply With Quote
Old 11th Jun 2009, 22:42   #10
Jipa
Licenced idiot.
Jipa's Avatar
All mobos have PWM nowadays? Pheew I've clearly not up to date...
It just still seems a bit harsh. I know I've had a fan controller in all my mobos for the last 7 years.
__________________
Old 11th Jun 2009, 22:46   #11
Fod
what is the cheesecake?
Fod's Avatar
Fod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of light
so, where on earthexactly can you actually _buy_ the gelid cooler in the UK?
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D."
I'm a pretentious git with a camera.
ISPs want to spy on you. Join the fight against phorm
XBL/PSN/Steam ID: FodT
Fod is offline   Reply With Quote
Old 12th Jun 2009, 03:56   #12
roy
What's a Dremel?
roy is on a distinguished road
The gelid cooler fits to my zotac 9300ITX ultra silm HTPC project, where can buy it?
roy is offline   Reply With Quote
Old 12th Jun 2009, 04:21   #13
zoot2boot
Multimodder
zoot2boot is on a distinguished road
" If we’d testing in a small case then limited airflow might have favours one cooler over another."
... which, if we ignore the english for a second, is exactly what you'd be interested in in a low profile cooler. surely.
zoot2boot is offline   Reply With Quote
Old 12th Jun 2009, 04:28   #14
sadlydefiant
Minimodder
sadlydefiant's Avatar
sadlydefiant is on a distinguished road
The zalman looks good for my new SFF gaming setup as the stock e5200 cooler is just rubbish
sadlydefiant is offline   Reply With Quote
Old 12th Jun 2009, 05:31   #15
CollinstheClown
-Xbox Pwner-
CollinstheClown is on a distinguished road
Is the US price for the GELID in the wrong currency?
-CollinstheClown
CollinstheClown is offline   Reply With Quote
Old 12th Jun 2009, 11:24   #16
ashchap
Multimodder
ashchap is on a distinguished road
Every motherboard I've used has been able to use PWM without a fourth pin (yes, pwm - not undervolting).
Download speedfan and if it doesn't work straight away, play with the advanced settings - different motherboards use different types of PWM.
Using speedfan you can set the fans to any level you want - keep turning it down until it's silent and then you're sorted!
ashchap is offline   Reply With Quote
Old 15th Jun 2009, 11:13   #17
Baz
Benchmarketeer
bit-tech Staff
Baz's Avatar
To my knowledge, PWM is impossible without the forth pin feeding back information from the temperature sensor onboard the cooler.
Some motherboards do allow you to adjust three pin fan voltages on the fly, where apps like speedfan work great, but they take information from the CPU temperature sensor. This feature, while useful, isn't available on all motherboards, and is usually limited to BIOS controls like Asus' QFan.
Either way, it doesn't take a genius to go out, grab a fan controller (or even a step down voltage cable) and drop the fan's voltage, but with these coolers that's going to dramatically impact on cooling performance. Perhaps not dangerously, but it adds another variable which somewhat undermines the whole point of conducting testing. Even a world beating heatsink will be rubbish with a fan running at 100RPM, while even a rubbish cooler can be good if you strap a delta screamer onto it. It's a matter of preference and if you choose to manually adjust fan speeds at the cost of cooling that's you're personal choice.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
