Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 12th Jun 2009, 09:14   #1
Votick
CHMOD bit-tech 777
Votick's Avatar
Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.
How to use Fahmon Webtemplates
This a quick guide on how to set up the webtemplates in fahmon and get them wroking correctly and how to add our CPC/bit-tech skin.
1) Firstly you will need a webhost, with ftp. You should have the username, password and the directory or the folder where your f@h page will be located.
If you do not own your own website but would like to have a go at this I can recomend using (http://awardspace.co.uk) as im currently hosting my f@h page on there free webhsoting service.
2) Setting up Fahmon to export webpages.
In Fahmon go to Fahmon > Preferences.
The Fahmon settings will pop up.
Scroll along the tabs untill you get to Web App 1.
Tick the export webapplication.
Next set the directory to a folder on your desktop.
Go to clients and reload all.
This creates your webtemplate.
Connect to your webserver on ftp and upload all the files. (if you want it to load like mine rename the html file to index.hml).
This makes sure the images are on your webserver.
Once done head back to Fahmon and to the web export 1 window.
Next step is setting fahmon to upload to your webserver.
Use this line and change your username, password, server address and directory to suite your needs.
Code:
ftp://USERNAME:PASSWORD@WEBSITE.COM:21/DIRECTORY/index.html
Once done hit ok and reload your clients.
Check your website for the page.
If its there well done would got your stats updating to your website.
3) Configureing Fahmon.
On the monitoring page you can set the HTML/FTP upload timings.
I have mine set to every 5mins.
Bear in mind bandwidth and how much you want to use.
You will want it frequent but not using too much bandwidth of your site up.
4) Show your colours!
You may of seen that I and Unicorn have a lovely CustomPC/Bit-tech webapp template.
You can also show your team colours and use this template.
We ask that you leave the links in tact at the bottom.
And a big shout out gose to Mitsimonsta the original author.
To use the template browse to your fahmon folder.
You will see a folder called templates.
Rename the fancy_template to somthing like OLD fancy_template.
Creat a new .htm file and call it fancy_template.htm
Open it with note pad and copy the following code into it.
Code:
<!-- This comment is a little trick to keep IE6/7 in quirks mode rather than trying to use it's incompetent standards compliant mode -->
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
	<meta http-equiv="content-type" content="text/html; charset=utf-8" />
	<meta http-equiv="Pragma" content="no-cache" />
	<meta http-equiv="refresh" content="300" />
	<title>Unicorn's Folding @ Home Farm Stats</title>
	<script type="text/javascript">
pdata = new Array(<!--tpl_loop ['@CORE@','@PRCG@','@POINTS@','@USER_TEAM@','@DOWNLOAD_DATE@','@PREFERRED_DATE@','@FINAL_DATE@'], tpl//-->[]);
function removeClassName (elem, className) {
	elem.className = elem.className.replace(className, "").trim();
function addCSSClass (elem, className) {
	removeClassName (elem, className);
	elem.className = (elem.className + " " + className).trim();
String.prototype.trim = function() {
	return this.replace( /^\s+|\s+$/, "" );
function ChangeColor(tableRow, highLight){
	if (highLight){
		var objbranch
		stripedTable();
		removeClassName(tableRow, 'alternateRow');
		removeClassName(tableRow, 'normalRow');
		addCSSClass(tableRow, 'clickedRow');
		objbranch = document.getElementById('core');
		objbranch.innerHTML = pdata[tableRow.id - 1][0];
		objbranch = document.getElementById('project');
		objbranch.innerHTML = pdata[tableRow.id - 1][1];
		objbranch = document.getElementById('credit');
		objbranch.innerHTML = pdata[tableRow.id - 1][2];
		objbranch = document.getElementById('username');
		objbranch.innerHTML = pdata[tableRow.id - 1][3];
		objbranch = document.getElementById('downloaded');
		objbranch.innerHTML = pdata[tableRow.id - 1][4];
		objbranch = document.getElementById('preferred');
		objbranch.innerHTML = pdata[tableRow.id - 1][5];
		objbranch = document.getElementById('final');
		objbranch.innerHTML = pdata[tableRow.id - 1][6];
function stripedTable() {
	if (document.getElementById && document.getElementsByTagName) {
		var allTables = document.getElementsByTagName('table');
		if (!allTables) { return; }
		for (var i = 0; i < allTables.length; i++) {
			if (allTables[i].className.match(/[\w\s ]*scrollTable[\w\s ]*/)) {
				var trs = allTables[i].getElementsByTagName("tr");
				for (var j = 0; j < trs.length; j++) {
					removeClassName(trs[j], 'alternateRow');
					removeClassName(trs[j], 'clickedRow');
					addCSSClass(trs[j], 'normalRow');
				for (var k = 0; k < trs.length; k += 2) {
					removeClassName(trs[k], 'normalRow');
					removeClassName(trs[k], 'clickedRow');
					addCSSClass(trs[k], 'alternateRow');
function addIEonScroll() {
	var thisContainer = document.getElementById('tableContainer');
	if (!thisContainer) { return; }
window.onload = function() { stripedTable(); addIEonScroll(); }
	</script>
	<style type="text/css">
table, td, a {
	color: #ffffff;
	font: normal normal 12px Tahoma, Verdana, sans-serif;
h1 {
	font: bold normal 26px Tahoma, Verdana, sans-serif;
	color: #ff0000;
	margin: 0 0 2px 2px
h2 {
	font: bold normal 18px Tahoma, Verdana, sans-serif;
	color: #ff0000;
	margin: 0 0 2px 2px
h3 {
	font: normal normal 13px Tahoma, Verdana, sans-serif;
	color: #008000;
	margin: 0 0 15px 0
div.tableContainer {
	clear: both;
	border: 0px solid #161850;
	overflow: auto;
	width: 564px;
	float:left;
\html div.tableContainer/* */ {
	padding: 0 16px 0 0;
	width: 550px;
html>body div.tableContainer {
	height: auto;
	padding: 0;
head:first-child+body div[class].tableContainer {
	overflow: hidden;
	width: 564px
div.tableContainer table {
	float: left;
	width: 100%
\html div.tableContainer table/* */ {
	margin: 0 -16px 0 0
html>body div.tableContainer table {
	float: none;
	margin: 0;
	width: 564px
head:first-child+body div[class].tableContainer table {
	width: 564px
thead.fixedHeader tr {
	position: relative;
	top: expression(document.getElementById("tableContainer").scrollTop);
head:first-child+body thead[class].fixedHeader tr {
	display: block;
thead.fixedHeader th {
	background: #11060a;
	font-weight: normal;
	text-decoration: underline;
	color: #ff0000;
	width: 564px
	padding: 4px 3px;
	text-align: center
thead.fixedHeader a, thead.fixedHeader a:link, thead.fixedHeader a:visited {
	color: #ff0000;
	display: block;
	text-decoration: none;
	width: 100%
thead.fixedHeader a:hover {
	color: #ff0000;
	display: block;
	width: 100%
head:first-child+body tbody[class].scrollContent {
	display: block;
	overflow: auto;
	width: 100%
tbody.scrollContent td, tbody.scrollContent tr.normalRow td {
	background: #000000;
	width: 564px
	padding: 2px 3px 3px 4px
tbody.scrollContent tr.alternateRow td {
	width: 564px
tbody.scrollContent tr.clickedRow td {
	background: #ff0000;
	width: 564px
head:first-child+body thead[class].fixedHeader th {
	width: 60px
head:first-child+body thead[class].fixedHeader th + th {
	width: 90px
head:first-child+body thead[class].fixedHeader th + th +th {
	width: 190px
head:first-child+body thead[class].fixedHeader th + th +th +th {
	width: 120px
head:first-child+body thead[class].fixedHeader th + th + th + th + th {
	border-right: none;
	padding: 4px 4px 4px 3px;
	width: 100px
head:first-child+body tbody[class].scrollContent td {
	width: 60px
head:first-child+body tbody[class].scrollContent td + td {
	width: 90px
head:first-child+body tbody[class].scrollContent td + td + td {
	width: 190px
head:first-child+body tbody[class].scrollContent td + td + td + td {
	width: 120px
head:first-child+body tbody[class].scrollContent td + td + td + td + td {
	border-right: none;
	padding: 2px 4px 2px 3px;
	width: 100px
body {
	font-family:Tahoma, Verdana, sans-serif;
	font-size:10pt;
	line-height:13pt;
	background:#11060a;
	color:#000000;
	margin-top:10px;
div.small {
	font-size:7pt;
	line-height:10pt;
	color:#FFFFFF;
	padding: 4px 0px 5px 0px;
a.small {
	font-size:7pt;
	line-height:10pt;
	color:#FFFFFF;
*html body #wuinfopanel/* */{
	width: 318px;
#wuinfopanel {
	float:left;
	padding-left:4px;
	height: 224px;
	width: 330px;
#fahmon {
	width: 900px;
	margin: 0;
	background: #ffffff;
header {
	width: 900px;
	margin: 0;
TD {
	margin-left:2px;
	margin-right:2px;
	padding:2px;
	</style>
</head>
<body>
<center>
	<div class="header">
		<table>
 			<tr>
  				<td height=217px width="900px" bgcolor="#11060a" align="right" valign="center" background="http://images.bit-tech.net/content_images/2009/03/intel-xeon-w5580-nehalem-ep-review/cpc%20and%20bit%20tech%20logo.jpg" style="background-repeat: no-repeat;">
					<h1>Unicorn's<br>Folding Farm<br>Stats</h1>
  					<b><font color="#efefef" size="-1"><!--tpl_static @_Last_updated:@ @UPDATE_TIME@ tpl//--></font></b>
				</td>
 			</tr>
		</table>
	</div>
	<div id="fahmon">
		<div id="tableContainer" class="tableContainer">
			<table border="0" cellpadding="0" cellspacing="0" width="100%" class="scrollTable">
				<thead class="fixedHeader" id="fixedHeader">
					<tr>
						<th>Status</th>
						<th>Progress</th>
						<th>Name</th>
						<th align="right">ETA</th>
						<th align="right">PPD</th>
					</tr>
				</thead>
				<tbody class="scrollContent">
					<!--tpl_loop <tr onclick="ChangeColor(this, true);" id="@CLIENT_ID@">
						<td align="center"><img src="@STATE_IMAGE@" /></td>
						<td align="center">@PERCENTAGE@</td>
						<td align="center">@NAME@</td>
						<td align="right">@ETA@</td>
						<td align="right">@PPD@</td>
					</tr> tpl//-->
					<tr>
					<td colspan="5" align="right"><h2>Total PPD: <!--tpl_static @TOTAL_PPD@ tpl//--></h2></td>
				</tbody>
			</table>
		</div>
		<div id="wuinfopanel">
			<table style="border-collapse:collapse;background:#11060a;margin:1px;height:100%;width:100%;">
				<tr>
					<td colspan="2"><!--tpl_static @_Work_Unit_Information@ tpl//--></td>
				</tr>
				<tr>
					<td align="right" width="50%"><b><!--tpl_static @_Core:@ tpl//--></b></td>
					<td align="left"><b><font color="#FF0000" id="core"></font></b></td>
				</tr>
				<tr>
					<td align="right"><b><!--tpl_static @_Project:@ tpl//--></b></td>
					<td align="left" id="project"></td>
				</tr>
				<tr>
					<td align="right"><b><!--tpl_static @_Credit:@ tpl//--></b></td>
					<td align="left" id="credit"></td>
				</tr>
				<tr>
				<td align="right"><b><!--tpl_static @_Username:@ tpl//--></b></td>
					<td align="left"><font color="#ff6600" id="username"></font></td>
				</tr>
				<tr>
				<td align="right"><b><!--tpl_static @_Downloaded:@ tpl//--></b></td>
					<td align="left" id="downloaded"></td>
				</tr>
				<tr>
				<td align="right"><b><!--tpl_static @_Preferred_Deadline:@ tpl//--></b></td>
					<td align="left" id="preferred"></td>
				</tr>
				<tr>
				<td align="right"><b><!--tpl_static @_Final_Deadline:@ tpl//--></b></td>
					<td align="left" id="final"></td>
				</tr>
			</table>
			<div style="border-collapse:collapse;border:0px solid #161850;background:#11060a;margin:1px;width:100%;" class="small">
				Original Template by Mitsimonsta : <a href="http://forums.overclockers.com.au/member.php?u=77979" class="small">OCAU</a> : <a href="mailto:fahmon.template@mitsimonsta.net" class="small">email</a><br>
                                Custom PC / Bit-Tech Version By Votick : <a href="http://forums.bit-tech.net/member.php?u=44944" class="small">Bit-Tech</a><br>
				This Page Generated & Uploaded by Unicorn : <a href="http://forums.bit-tech.net/member.php?u=26539" class="small">Bit-Tech</a> : <a href="mailto:matt@unicornsystems.co.uk" class="small">email</a><br>
				Powered by <!--tpl_static @FAHMON_VERSION@ tpl//--> Web Monitoring Application <a href="http://fahmon.net/download.html" border="0"><img src="dialog_icon.png" border="0" /></a>
			</div>
			</table>
</div>
</center>
</body>
</html>
You will need to find and replace Unicorn with your name.
Thanks to him for updating the changes
Mainly the Title tag. H1 tag, and the footer, and change the email to your own if needed.
Reload all your clients again and ta da you have a lovely CPC template.
Enjoy.
Any questions feel free to ask or IM im on MSN most the time at votick@live.co.uk.
Hope you guys found it useful.
And I look forward to seeing your pages
~ Votick
__________________
Folding stats
| AMD FX 8350 @ 4.0GHZ | Gigabyte GA-990FXA-UD5 | 16GB Corsair Vengeance DDR3 1600mhz |
| Corsair Force 3 120GB SSD X 2 RAID0| Corsair H100 | Samsung F3 1TB HDD | MSI GeForce GTX 680 SLI |
| Silverstone 1200W | Corsair 650D | LG IPS225V X 2 |
Votick is offline   Reply With Quote
Old 12th Jun 2009, 14:15   #2
IwantAbetterPC
Multimodder
IwantAbetterPC's Avatar
IwantAbetterPC has yet to learn the way of the Dremel
Cheers for doing that mate, I really appreciate it. Will go and try to set it up now and see if I can get the FTP through the firewall. easier way to see whats going on that VNC/Hamachi etc!
Craig...
IwantAbetterPC is offline   Reply With Quote
Old 12th Jun 2009, 15:50   #3
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.
Doesn't work for me but I think it is because my username for the ftp site has an '@' in it (meaning there is 2 @ symbols in the code) so its getting confused, I can conenct fine via an FTP clients though.
Might not be able to do it that way then, will have to export fahmon stats locally and FTP it up using windows scheduler or something!
Very good guide though mate nice work
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 12th Jun 2009, 16:01   #4
IwantAbetterPC
Multimodder
Arrgh,
Might need a few edits on your post as it's not quite as easy as I'd hoped!
Got an account set up on awardspace - iwantabetterpc.awardspace.co.uk.
Got the fancy template sorted no problem.
Got fahmon to dump it into a folder called fahweb on the desktop, which looks good if I launch index.html
Can't seem to get the page to FTP to the website. Trying to do it from within command prompt - can ftp to site (so firewall not a problem), input userid, input password, try typing..
put c:\documents and settings\CR\desktop\fahweb\*.*
... to copy it all to the website and dont get any errors (but no confirmation either!), so type "bye"
go to the website and get nothing?
the format of my string in the FAHMon web app 1 is...
ftp://myuserid:mypassword@iwantabett...:21/index.html
...but no joy. where am I going wrong (XP 32 user, by the way!)
Craig...
Old 12th Jun 2009, 17:44   #5
Votick
CHMOD bit-tech 777
Votick's Avatar
the files on your website form teh awardspace control pannel?
delete the default index.html file.
upload all the files including the index.html page to your site.
awardsapce has a slighty diffrent layout.
so i think the problem is your line.
use this:
Code:
ftp://myuserid:*****@iwantabetterpc.awardspace.co.uk:21/iwantabetterpc.awardspace.co.uk/index.html
If you downlaod filezilla and connect to it by that you can check the directory.
Hope it works
__________________
Folding stats
Old 15th Jun 2009, 09:16   #6
IwantAbetterPC
Multimodder
Yay! That works! Used Filezilla to upload it once, then set the extended path in FAHMON as detailed in the last post, hit F6 to refresh and it was up there!
Nice one - now need to add it to my sig!
Next trick is how to add the stats from the other Dell into this FAHMon so I can show the other SMP client numbers too, but the PCs are on different domains, one is XP and the other is MS Server 2003. I've tried sharing and got nowhere, and can't get FTP to work between the boxes. Any suggestions? (I'm being lazy as I'm sure it's on the forum somewhere if I could be bothered to search for it!)
Craig...
Old 15th Jun 2009, 10:05   #7
Votick
CHMOD bit-tech 777
Votick's Avatar
hamatchi? thats what i use.
From the guide in issue 70 i think.
Gratz on getting that to work
__________________
Folding stats
Old 15th Jun 2009, 10:19   #8
IwantAbetterPC
Multimodder
Yup,
Works a treat mate! I'll have a look on the Forum - Saspro has answered this loads of times already, so there are loads of threads on this. If all else fails, I'll get Issue 70 out when I get home.
Cheers again buddy!
Craig...
Old 16th Jun 2009, 13:09   #9
Votick
CHMOD bit-tech 777
Votick's Avatar
Do you think we should sticky this thread for future referance?
__________________
Folding stats
Old 16th Jun 2009, 14:43   #10
IwantAbetterPC
Multimodder
I think so.
I think it could do with tarting up a bit to flesh out the domain registration part, as well as the FTP/Filezilla part, and the most important bit is getting the FTP:// string explicitly right for embedding into FAHMon. Some of these are assuming a degree of knowledge about how to set them up and use them. Fixing the Fancy template is perfect.
Rather than another sticky (we'll soon have so many that you can't see any new posts!), could we tack a reply onto one of the existing signature/stats stickies instead?
I think it is really cool and I can now monitor my folding allotment stats from anywhere on the web - our firewalls at work prevent VNC and LogMeIn etc from working properly, but the plain website is a scoosh!
Regards,
Craig...
Old 16th Jun 2009, 16:44   #11
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.
Aha you beat me to it I had half written a guide and saved it, but meh, it doesn't matter.
Vote for Stickeh!
Unicorn is offline   Reply With Quote
Old 8th Jul 2009, 17:54   #12
Unicorn
Unicorn's Avatar
I'm bumping this for the benefit of being able to find it again later, need to look at something for Saspro. Also, please sticky this? It's a really useful guide!
Old 26th Jul 2009, 20:07   #13
VinnyVortex
Back in the game!
VinnyVortex's Avatar
VinnyVortex has yet to learn the way of the Dremel
Ok, i'm having some problems here. I've set up the awardspace account, managed to upload all necessary files and changed the template to CPC one. FAHMon is updating the index.html file via the ftp. But when I click on my web page link nothing happens. All file are in the sub domain directory. any ideas???
__________________
Currently running 1xSMP & 4xGPU : i7 920 @4.3GHz & 2x9800GX2 (all watercooled)
Folding stats
My folding status : http://vinnyvortex.host-ed.net
http://valid.canardpc.com/cache/banner/1152658.png
VinnyVortex is offline   Reply With Quote
Old 27th Jul 2009, 19:37   #14
VinnyVortex
Back in the game!
OK, 'awardspace.co.uk' didn't work for me. I used 'host-ed.net' instead and it all work out alright.
__________________
Folding stats
Old 27th Jul 2009, 22:10   #15
chin913
忍び So say we all
chin913's Avatar
chin913 has yet to learn the way of the Dremel
Think I am having another blond moment here
__________________
Folding stats
chin913 is offline   Reply With Quote
Old 28th Jul 2009, 11:20   #16
Keith_Whi
Multimodder
Keith_Whi has yet to learn the way of the Dremel
Got it nearly sorted but can anyone tell me why my FAH client status icons on the web page are just a red cross? I.e look like a file that can't be opened.
Everything else is looking fine and it is updating but would like to iron that out if possible.
Thanks,
Keith.
OOps forgot the link.. http://keithwhi.awardspace.co.uk/
__________________
Keith's Current WU's.
Folding stats
i7920@3.8-Rampage II Extreme-60GB OCZ Vertex SSD-1TB Samsung F3-6GB XMS3-2xGTX275-1000wCorsair-H50 CPU Cooling-Corsair 800D-W764.
Keith_Whi is offline   Reply With Quote
Old 28th Jul 2009, 16:58   #17
saspro
Infrastructure Specialist
saspro's Avatar
saspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpit
Thanks,
Keith.
You need to manually ftp them up there
__________________
If what I've said helps you please remember to hit the rep button on the left
Missing the old meeting place? Find us here
saspro is offline   Reply With Quote
Old 28th Jul 2009, 18:17   #18
Keith_Whi
Multimodder
Have replied in the other post, but thanks again, missed them completely.
Hopefully this will help others.
__________________
Folding stats
Old 9th Aug 2009, 13:56   #19
Unicorn
Unicorn's Avatar
+1, can a mod please split this topic?
Old 27th Sep 2009, 16:03   #20
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.
*Bump* - Still be great to have this thread as a sticky
Updated my FahMon web template: www.docjonz.net
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
