Go Back   bit-tech.net Forums > Technology > bit-tech Folding Team
Reply
Thread Tools
Old 6th Aug 2010, 19:16   #41
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Chin913 - I think you'd be better off with HFM, as it has the points system updated, and recognises new cores, and its easy check for failed units etc ....
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 6th Aug 2010, 23:31   #42
chin913
忍び So say we all
chin913's Avatar
chin913 has yet to learn the way of the Dremel
hhmm think I will have a look @ that this thing was a pig to do ...and I aint very good at webserver and ftp and that ,,,,
__________________
Folding stats
chin913 is offline   Reply With Quote
Old 7th Aug 2010, 08:14   #43
DocJonz
DocJonz's Avatar
I'm not proficient in that area either(!) - though it's worth persisting ....
__________________
Folding stats
Old 3rd Sep 2010, 22:25   #44
SpeckleD
Modder
SpeckleD has yet to learn the way of the Dremel
Ok so I have a question, is it possible to have clients report results to my web template which are running on seperate networks? for instance My home PC and my work PC?
__________________
i7 930 D0@4.2Ghz\Apogee XT~Asus R3E\EK-FB~6GB Corsair@1600mhz~HD5870\Koolance VID-AR587~OCZ Vertex LE~MM U2-UFO\Thermochill PA120.3\PA120.2\Swiftech MCP655\Corsair CMPSU-850HX~Viewsonic VX2835wm~Logitech Z-5500~Win7x64
SpeckleD is offline   Reply With Quote
Old 4th Sep 2010, 13:39   #45
StreetSam
Supermodder
StreetSam's Avatar
StreetSam has yet to learn the way of the Dremel
LogMeIn Hamachi. It's is a free to use VPN system. I have two networks and they both appear on my HFM stats.
__________________
Folding stats
Current Folding@Home stats
StreetSam is offline   Reply With Quote
Old 4th Sep 2010, 18:48   #46
SpeckleD
Modder
Thanks will take a look and give it a whirl!
__________________
Old 17th Jan 2011, 22:56   #47
houch
Multimodder
houch's Avatar
houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!
cant get my head around this, i reg on that website thing but dont know how to do anything else, can anyone help, oh and i have fahmon on me pc, i just need to know how to do the web update, with or without the skins
houch is offline   Reply With Quote
Old 27th Oct 2011, 14:13   #48
Votick
My CPU's hot but my core runs cold.
Votick's Avatar
Votick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming Saiyan
just an update to anyone using/viewing this thread that this skin is no longer in use and has been succeeded by HFM.
A skin for bit-tech can be found at http://forums.bit-tech.net/showthread.php?t=194557
__________________
Folding stats
Votick is offline   Reply With Quote
Old 11th Dec 2011, 16:45   #49
TaRkA DaHl
I *am* a Dremel
TaRkA DaHl's Avatar
TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.
Random bump... I gave up using FTP and just switched to using dropbox instead along with a tinyurl shortcut to get to my page. So much easier to setup and took about 30 seconds.
TaRkA DaHl is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
