Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th Jun 2009, 11:55   #1
Sifter3000
I used to be somebody
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
When is a browser bigger than the platform it runs on?
http://www.bit-tech.net/blog/2009/06...rating-system/
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 15th Jun 2009, 12:03   #2
yodasarmpit
No longer the other Brett.
yodasarmpit's Avatar
yodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyanyodasarmpit is a Super Spamming Saiyan
Originally Posted by article
The user must be able to uninstall it
That option could potentially leave a high percentage of MS users without a method to connect to the net
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
yodasarmpit is offline   Reply With Quote
Old 15th Jun 2009, 12:09   #3
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
It could, but there could be some kind of check to see if other browsers are installed. If there aren't other browsers installed (or isn't a different browser set as the default), it would be quite easy for Microsoft to display a notification along the lines of "you're about to remove the only web browser installed on this machine, are you sure you want to proceed?"
That would, in theory, be a solution to the problem and there could always be a recovery option in Control Panel which allows you to reinstall IE if you've done the dumb thing.
Tim S is offline   Reply With Quote
Old 15th Jun 2009, 12:12   #4
steveo_mcg
steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.
Yeah i can see some one poking around the windows components control panel not thinking it through and clicking remove IE to save 80mb of hard disk space then finding they could no longer get their gmail....
Tim, good post much more balance than your last mini rant . I agree MS shouldn't be forced to include another browser but the included one must be stand alone and not completely integrated into the OS.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 15th Jun 2009, 12:19   #5
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
The browser must adhere to web standards
This seems unfair - Firefox doesn't pass Acid3 either - should Canonical be prevented from bundling it with Ubuntu?
The user must be able to install an alternative
It must not be embedded into the OS in such a way that removing it 'breaks' the OS if an alternative browser is installed
The user must not be punished (with poor performance, instabilities, etc) if they choose an alternative browser
Aren't all these things true already?
ch424 is offline   Reply With Quote
Old 15th Jun 2009, 12:26   #6
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
In my view, MS should not be barred from including IE, but as you say it should not be so tightly hooked into the OS that it can't be effectively removed without breaking things. There is no reason why MS shouldn't use its own browser engine for things like Windows Update, Help etc., and this could be extended to a pre-installed micro-browser whose sole function is to connect to an MS portal and allow the user to download a browser of their choice (Firefox, IE, Chrome, Safari, Opera etc.) MS shouldn't have to host these, they should be hosted by the publisher. This means (a) users have to make a positive choice to use IE (which in my view addresses the EU's principal concern), (b) MS isn't forced to bundle software from other publishers, and (c) users always get an up to date browser from the start, with all the latest security patches etc.
__________________
mclean007 is offline   Reply With Quote
Old 15th Jun 2009, 12:30   #7
Tim S
Tim S's Avatar
Yes, the last post was a bit of a rant... partly because I think the whole thing is completely ridiculous - the issues should been tackled a long time ago, but they weren't for one reason or another. Now is not the time, IMO.
No, but it should make a decent effort to adhere to web standards. 21/100 in Acid3 isn't exactly a great showing in that respect. Firefox's showing is much stronger.
Most of them are already true, yes, but you can't completely uninstall Internet Explorer without third party tools. You can disable it, which some would argue is a happy medium, but I believe the option to remove it altogether should be there.
Old 15th Jun 2009, 14:13   #8
yakyb
i hate the person above me
yakyb's Avatar
yakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysisyakyb can run Crysis
what is the point in webstandards when all companies just ignore them i realise IE8 is a step in the right direction fo MS but realistically all browsers should at least get the rendering correct
yakyb is offline   Reply With Quote
Old 16th Jun 2009, 00:03   #9
Hugo
Ex-TrustedReviews Staff
Hugo's Avatar
Hugo has yet to learn the way of the DremelHugo has yet to learn the way of the DremelHugo has yet to learn the way of the DremelHugo has yet to learn the way of the Dremel
Not to mention a number of applications - Windows Media Player for example - 'cheat' by embedding Internet Explorer windows into their interface for some functionality, on Vista and XP for certain, at least so you definitely have the issue of reduced usability were it removed entirely.
__________________
thisishugo.com - I have opinions; you can read them.
Hugo is offline   Reply With Quote
Old 16th Jun 2009, 21:44   #10
stoff3r
Multimodder
stoff3r has yet to learn the way of the Dremel
Microsoft should leave browser-developement to somebody more capable.
stoff3r is offline   Reply With Quote
Old 16th Jun 2009, 22:47   #11
The_Beast
I like wood ಠ_ಠ
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
This is so stupid, Microsoft can do anything it wants to it's own products
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 23rd Jun 2009, 02:03   #12
noveltylamp
What's a Dremel?
noveltylamp has yet to learn the way of the Dremel
You know what you're getting when you buy Windows, an OS along with all the tools you need for basic computing, a word processor, a basic image editor, a file manager and of course a web browser and media player. This is just the same as any Linux distro or Mac OS. I want to buy Windows with all these things I expect included in the box, with an option to untick what I don't require when installing. To force Microsoft to remove these completely is just plain silly and whoever likes the option to install MSIE and WMP being taken away completely probably doesn't use Windows anyway. Why is no-one kicking off because they've bundled Write and Paintbrush for years, oh yes and Calc - surely they're doing Casio out of the interactive computer calculator market!
noveltylamp is offline   Reply With Quote
Old 23rd Jun 2009, 05:55   #13
jamesthebard
Too Much Time On My Hands
jamesthebard's Avatar
jamesthebard has yet to learn the way of the Dremel
It's a damned-if-you-do/damned-if-you-don't situation. Either keep IE bundled with Windows which, due to market penetration, inhibits other browsers from making any headway, or leave out IE which means you've got to get to the web via other methods.
I agree, I'm not a huge fan of IE myself but the crux of it is this: a modern OS needs an internet browser. How much of your 'computer experience' is based on being able to browse and interact with websites.
To make this work, you have to do one of the following: (1) allow Microsoft to bundle IE with Windows, (2) allow users to pick from a list of browsers when they install/initially start Windows, or (3) force Microsoft to conform to standards. (1) is bad, (2) makes me smile at the thought of the inherent chaos in the would-be selection system, and (3) was almost realized until Microsoft went back to it's policy of having to opt-in for standards compliancy mode.
It's a bad situation for consumers no matter what happens.
__________________
Never underestimate the power of stupid people in large groups.
1 | ASUS M3A78-EM | AMD Phenom 9850BE | ATI Radeon 4870 512MB | 2x 2GB OCZ DDR2-6400 | Win7 x64
2 | Mac Pro (2006) | 2x Intel Xeon 5160 | ATI Radeon X1900 512MB | 2x 2GB 667MHz FB-DIMM | Snow Leopard
3 | ASUS P7F-E | Intel Xeon X3430 | 4x Samsung 1.5TB (ZFS/RAIDZ @ ~4.5TB) | 4 GB RAM | Nexenta Core 3.0RC1
jamesthebard is offline   Reply With Quote
Old 23rd Jun 2009, 13:05   #14
dec
[blank space]
dec's Avatar
dec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysisdec can run Crysis
of the web browser makers doesnt microsoft have the biggest pockets and can thereby out bid everyone else? The list of browsers at OS install seems to be the best method to me. Its not perfect but it works. Theres only like 4 or 5 browsers out there anyways. (IE, Firefox, Opera, Chrome)
__________________
Pure. Refreshing. Bacon.
dec is offline   Reply With Quote
Old 23rd Jun 2009, 20:26   #15
jamesthebard
They could, but if they (hypothetically, of course) were forced to bundle other browsers with their OS then there wouldn't be a problem with keeping IE with Windows 7. But it is a good point: which browsers do you include?
You could say popularity/marketshare, but then how many do you add to the default install? Firefox, Opera, and Chrome are good choices.
Reality is that Microsoft is being forced to remove a core part of their users 'experience'. I do not like Microsoft's business practices (or marketing campaigns) but this judgment will have a more severe impact on the people who are buying copies of Windows 7 than those purchasing new computers with Windows 7 on them. OEMs will throw a web-browser onto the machines they sell before sending them out, but people upgrading to Windows 7 might encounter a few more difficulties.
__________________
Old 24th Jun 2009, 15:23   #16
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the Dremel
What is in it for Microsoft having their browser in a system? The only way I can see that they could make money from it is the search and the home screen if it left at default.
Rather than put resources towards a bad browser that artificially gets them a few extra hits, why not sort out their search and make it a place people want to go?
__________________
i7 920, 5870, 6GB Corsair all in an Intel DX58SO; 60GB Vertex, 1.5TB F2; Fractal Design R2
ThinkPad Edge 13.
Cupboard is offline   Reply With Quote
Old 30th Jun 2009, 08:54   #17
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Forget WMP, Steam has IE embedded in it, and that is my biggest worry. I'd like to see if Valve release a version of Steam that will run with whichever browser you have installed/set as default, but I can't see that happening somehow, so I for one will have IE installed. *sigh*
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
