Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 17th Jun 2009, 12:16   #1
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.
Graphics Card for 3D rendering...
Hi all been asked on behalf of a mate about Graphics cards for Rendering, he works for an architects and uses 3D rendering programs (cant rememebr what they are called though)
They are using Nvidia Quadro NVS 290's are the moment which are just too slow at rendering so they want to upgrade.
He was asking if they could use high end gaming cards like the GTX285/275 but I think they will need to stick to something designed for the job like a Quadro FX 3800 or something.
Anyone got any knowledge in this field that could advise him?
Many thanks
__________________
Main Rigs:~ i7 4790K @ 4.8 WC'd - 16GB @ 2400 - GTX 1080Ti | Alienware 13 Laptop, i7, M.2 SSD's, 16GB & Graphics Amp 980Ti
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 17th Jun 2009, 15:57   #2
gaz_360
Make that change
gaz_360's Avatar
gaz_360 has yet to learn the way of the Dremel
hi
As you mentioned high end graphics cards would be perfect for the job, especially in SLi, but if you want something more 'industrial', then I would suggest one (or two) of these. When my mate went to uni, he studies 3D rendering using 3D studio Max, and that card ran it beautifully, and you could go SLi I think
Very expensive though lol
__________________
CPU - Intel Core 2 Duo Q6600
Mobo - Foxconn PT890
RAM - 4GB DDR2
GPU - Gigabyte GTX460 1GB
PSU - Coolermaster GX550 - Icute 250mm Fan Gaming case
gaz_360 is offline   Reply With Quote
Old 17th Jun 2009, 16:10   #3
adam_bagpuss
Have you tried turning it off/on ?
adam_bagpuss's Avatar
adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.
if your serious about rendering gaming GPU are horrible really.
They are not optimized either hardware or driver wise.
I use 3d modelling software and we use nvidia quadro range.
we got various models lying around ranging from basic quadros to high end ones.
these are vastly superior to any gaming GPU. even a low end quadro would wipe the floor with a high end GPU because they are just not designed for it.
EDIT - i meant quadro FX range not just general quadros.
The NVS ones are business orientated for multi screen setups not rendering powerhouses.
adam_bagpuss is offline   Reply With Quote
Old 17th Jun 2009, 16:10   #4
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Gaming GPU's can work, but not optimally. A BIOS flash can turn most GGPU into their industrial counterparts, though not 100% transformation.
Many of these cards use the same chipset as the game- and action-oriented GeForce video cards by NVIDIA. Those cards that are identical to the desktop cards can be software modified to identify themselves as the equivalent Quadro cards and this allows optimized drivers intended for the Quadro cards to be installed on the system.[1] While this will not offer anywhere near the performance of the equivalent Quadro card,[citation needed] it can improve performance in certain applications, but may require MAXtreme for the speed improvements.
The performance difference comes in the firmware controlling the card. Given the importance of speed in a game, a system used for gaming can shut down textures, shading, or rendering after only approximating a final output—in order to keep the overall frame rate high. The algorithms on a CAD-oriented card tend rather to complete all rendering operations, even if that introduces delays or variations in the timing.
Would be beneficial for you to take a gander at this page. http://en.wikipedia.org/wiki/Nvidia_Quadro
rickysio is offline   Reply With Quote
Old 17th Jun 2009, 16:31   #5
bobtheangryflower
lalala
bobtheangryflower has yet to learn the way of the Dremel
almost all 3d rendering applications are depended on cpu and ram they barely use video card other than display
__________________
gigabyte gz-x4 red and black mid & asus rampage ii gene micro atx
i7 920 3.5ghz stock cooler for now
6gb ddr3 1066 mushkin
wd 500gb green 16mb &seagate cuda 640gb 32mb
evga gtx260 superclocked & corsair 650w psu
bobtheangryflower is offline   Reply With Quote
Old 17th Jun 2009, 16:34   #6
kingred
Surfacing sucks!
kingred's Avatar
kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.
For 3dsmax rendering is cpu/bus dependant, I use a gaming gpu fine, unless you are using huge thousand part assemblies and actually modelling using a parametric surface modeller then i wouldnt even contemplate buying a quadro.
kingred is offline   Reply With Quote
Old 17th Jun 2009, 16:34   #7
[PUNK] crompers
Dremedial
[PUNK] crompers's Avatar
[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.
i use 3DS Max and always assumed rendering was performed on the cpu? i thought rendering was one of those GPGPU task that couldnt be assigned to the card until a driver update?
could someone enlighten me? would like to know
EDIT: as i was typing my questions were answered! so the gpu is used when creating objects in the viewport? and then the cpu to render?
__________________
| Main Rig | FT02 BW | 2600k @ 4.3Ghz | Sabertooth Z77 | 16GB Corsair Vengance | GTX 1070 @ 2020Mhz | OCZ ARC100 480GB |1TB Samsung F3 | Corsair HX650W | U2711 | Filco Majestouch 2 Tenkeyless | Xonar Essence STX | ProSonus Eris 4.5 monitors |
| HTPC | Lian Li Q11-B | AMD A10 5800k | ASRock FM2A75M-ITX | 8GB XMS3 2000 | 1TB Seagate | SFX 350W |
[PUNK] crompers is offline   Reply With Quote
Old 17th Jun 2009, 16:35   #8
adam_bagpuss
with most giant 3D models with tons of data on screen you need a pretty beefy professional GPU to manipulate it quickly.
trust me we got some laptops that even on your lowest setting chug along in slide show style when rotating a normal model and you can forget about the big ones.
the CPU and RAM are very important but the GPU does do alot as well.
The actual rendering is heavily RAM dependant but viewing/manipulating 3D is done all the card baby
Old 17th Jun 2009, 16:41   #9
bobtheangryflower
lalala
if u want faster renders get u a dual socket lga 1366 mobo and 2 xeon quads and ull be blazing thru frames
__________________
Old 17th Jun 2009, 16:43   #10
[PUNK] crompers
Dremedial
you'll also be blazing through your bank balance
i'd suggest a bit of overclocking as a more short term solution
__________________
Old 17th Jun 2009, 16:50   #11
bobtheangryflower
lalala
its not that much actually
and overclocking doesnt promise stability
__________________
Old 17th Jun 2009, 16:59   #12
[PUNK] crompers
Dremedial
well to me its a lot of money, and my oc'd system definately provides faster renders than stock (and doesn't crash)
__________________
Old 17th Jun 2009, 19:28   #13
Nicb
Let's discuss among ourselves
Nicb's Avatar
Nicb has yet to learn the way of the Dremel
Any GPU will not impress you on rendering 3D images, especially several frames. They are really helpful in light progressive renders as you work, but painfully slow in the finished render.
I can only find the original liks to the creators of the Microwulf, but I have links somewhere in my bookmarks where guys have used similar builds to render in a fraction on the time. What took hours took 15 - 20 min. Something like that.
The price that is stated on this page says 1250, but you could build it for less now. Probably about the same price as a 295GTX.
http://www.calvin.edu/news/2007-08/microwulf.htm
http://www.calvin.edu/~adams/research/microwulf/
Also Google "Render Farm" you will find tons of articles and how to's about building one.
If he demands high performance this is his option. No graphics card will do anthing close to this.
Nicb is offline   Reply With Quote
Old 17th Jun 2009, 20:05   #14
Nicb
Nicb's Avatar
I wanted to add.
Desktop (Gaming) GPUs are designed to view one viewpoint or window. A commerical GPU is encoded to view several viewpoints of a scene in Maya or 3DsMax. They are also good for viewing a live scene in different viewpoints after the render.
When it comes to rendering a scene or image it is primarily using CPU and Ram power. That is why a render farm of machines or better yet a microwulf would be the best option to use in a network for rendering. They have no need for high end if any GPUs.
Old 18th Jun 2009, 10:50   #15
rickysio
N900 | HJE900
Applications with CUDA support should run faster (much faster) on nVidia hardware.
Old 18th Jun 2009, 22:50   #16
bobtheangryflower
lalala
if only they would add cuda support to 3ds max
__________________
Old 19th Jun 2009, 00:13   #17
Nicb
Nicb's Avatar
coolamasta, If your friend is using CAD then he might be interested in Gelato 2.2. Click on the link below. It has plugins for several #D rendering applications. It does speed up the process.
http://www.nvidia.com/page/gz_learn.html
rickysio, If you would like to do some coding on CUDA for the community we would be ever grateful. Right now it seems like a political issue to why we have not taken a strong hold of CUDA in the 3D rendering industry.
But like I stated before nothing beats multiple CHEAP CPU power and Ram. You slap together some older hardware and all of a sudden you have a supercomputer.
Old 19th Jun 2009, 03:42   #18
bobtheangryflower
lalala
ive got a 3ghz p4 with 512mbs ram and a 1.8ghz dualcore with 4gb ram hooked to my i7 for rendring and its speeds it up quite a bit
__________________
Old 19th Jun 2009, 05:57   #19
rickysio
N900 | HJE900
If I could do coding I don't think I'd still stick with my current system, what with a avenue of income and all that shtick.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
