#1 |
What's a Dremel?
Couldn't Access My Wireless Admin Page (192.168.10.1)
guys I am fairly new to all of this so please excuse the lack of knowledge.
So I have a wireless Fon Spot access point which I used to be able to access the Admin page to change my wireless setting via 192.168.10.1. Somehow I am not able to do it anymore and I believe someone in my neighborhood is playing around with my wireless internet... I reset the whole thing but still couldn't able to access the Admin page. I tried other address 192.168.1.1 and even run the program that can detect live sources from the address of 192.168.1.1 to 192.168.255.255. So what can I do??? Help~ I really want to change the password and settings for my wireless... Thanks in advance |
#2 |
I Mod, Therefore I Own
Have you tried it via a wired connection??
#3 |
LIKE AN ANIMAL!
Read the manual?
![]() No, just try it wired as CB already said. Many routers disable wireless access to the configuration due to security reasons. Then again you say you were able to access the settings wirelessly before, right? Have you tried pinging the router to see if anything's there at all? Or is that what the program that can detect live sources from the address of 192.168.1.1 to 192.168.255.255 does? Welcome to the forums by the way.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far. ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn Iä! Iä! Cthulhu fhtagn!
#4 |
Banned
#5 |
Hacker. Maker. Engineer.
Open up command prompt and type ipconfig (press enter). Tell us what the address for "default gateway" is. Also, try accessing the router by opening that address in your browser.
__________________
There is no better previewing system than the 'Submit Reply' button.
I <3 Aquatuning & Enermax long time! |
#6 |
Make that change
Are you able to do a factory reset?
If so, then once done enter the default password and user for it (default info should be on the underside of the router on a sticker, if not refer to the manual). Now hopefully it will of let you access the webpage, now you can change the settings to what ever you like. Gaz
__________________
CPU - Intel Core 2 Duo Q6600
Mobo - Foxconn PT890 RAM - 4GB DDR2 GPU - Gigabyte GTX460 1GB PSU - Coolermaster GX550 - Icute 250mm Fan Gaming case |
#7 |
What's a Dremel?
#2 yes i tried via wired connection i have no problem connect to the internet even with the wireless connection... but how do i access the wireless admin page with wired connection???
#3 ty, and the manual says connect to 192.167.10.1.. Wireless LAN adapter Wireless Network Connection: Connection-specific DNS Suffix . : Link-local IPv6 Address . . . . . : fe80::290b:9482:20c7:3741%11 IPv4 Address. . . . . . . . . . . : 10.1.1.11 Subnet Mask . . . . . . . . . . . : 255.0.0.0 Default Gateway . . . . . . . . . : 10.1.1.1 Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Tunnel adapter Local Area Connection* 7: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Tunnel adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Tunnel adapter Local Area Connection* 16: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Tunnel adapter Local Area Connection* 17: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : which connects to my router admin page... but not wireless... so i dunno why... yes i reset it (reset button for 40 seconds turn off power then on) and the name reset as well... use orgiinal... but still couldn't access default admin page.... |
#8 |
Connect to http://10.1.1.1/
__________________
#9 |
Banned
I think I understand how you are setup.. correct me if I'm wrong but you have a wired lan and a wireless access point connected to the gateway.. one way to configure it would be to plug in directly to the wireless router, configure it to match your wired routers subnet- then put it all back together and access the wireless routers new ip (something like 10.1.1.2)
the other way is configure your wired router to subnet 255.255.255.0, gateway 192.168.10.2 and you should be able to connect to your wireless router's web admin through the wired router |
#10 | |
Banned
#11 |
Yeah, it kinda twigged just after I'd posted that there are two different router config pages, and I don't know whether the OP wants to access the backbone router of the Fonera.
__________________
#12 | |
What's a Dremel?
when I plug directly into the wireless router... how do I go to the configuration page??? and if I configure my wired router will that change anything? (cuz i want to keep it as the same as it is so kind of prefer not to change anything there) |
#13 |
What's a Dremel?
I want to access the Fonera config page to change my wireless settings (I am not able to cahnge the wireless settings at the backbone router config page, right?)
#14 |
What's a Dremel?
HELP~ would realy appreciate it if somebody can teach me how to change my wireless settings... its raelly getting on my nerves... lol~
Today I read over the whole user manual and it tells me to ipconfig and just type in the default gateway address.... but that leads me to the Dlink Admin page not my wireless internet Fontera Admin page... sigh |
#15 |
In the dlink configuration page, look for a list of connected devices. Look for the IP of the Fonera and connect to that.
__________________
#16 |
Banned
aye game
well let's make this easy, reset your wired router and it should default to subnet 255.255.255.0 to match your wireless access point.. then you should be able to access both routers menus (the other way- which maybe the easiest without touching any hardware is to setup your rig static on subnet 255.0.0.0 and you'll be able to access the fon and not the dlink)just reset the wired router though.. you'll see them both afterwards |
#17 | |
What's a Dremel?
I prefer not to reset the router because it's my landlords not mine and I don't want to touch it... And I couldnt' find the connection for Fonera it all leads to either nothing or just the Dlink page.... T_T |
#18 |
Banned
I'm sorry I gave the wrong subnet there last post- must have been in ladeda land again.. mean setup static 255.255.255.0 to access the web menu at http://192.168.10.1 (your fon)
here just found this first on google http://www.hotcomm.com/FAQ/FAQ_staticIPXP.asp (save me from typing all that) put in 192.168.1.100 for your ip address, 255.255.255.0 for the subnet.. put in 10.1.1.1 for the gateway.. add a couple dns server ip's (you can make these up if you want) vista is the same but you'll pull up properties for TCP/IPv4 now access the fon menu with your browser... change the router ip to 10.1.1.240, subnet 255.0.0.0, save it.. now go back to your rigs lan connection and put it all back to auto in the tcp properties |
| Thread Tools | |
