Thread Tools |
#1 |
Editor @ CPC
bit-tech Staff
Acer Aspire Revo Review
http://www.bit-tech.net/hardware/pcs...-revo-review/1
Acer's Revo is the first product we've seen that uses Nvidia's Ion platform, combining GeForce graphics with Intel's cheap and cheerful Atom CPU. It promises smooth 1080p video playback and playable game frame rates for £250 - join us as we find out of whether the Revo is able to deliver.
#2 |
Multimodder
I really think the lack of GPU accelerated flash kills the Internet browsing experience on the Revo. Purchased one for a relative and they enjoy it as it does the basic things fine.
Until the monopoly Adobe pull their finger out of their a**, it seems that Internet interactive content will need a solid CPU. With the push to Compute shader and OpenCL you would have thought that someone would have enabled GPU browser acceleration? Hmm that gives me an idea!! Of course there is HTML5 from Google which should make Adobe Flash irrelevant and redundant.. here's hoping anyway Good review Harry! |
#3 |
Why so serious?
would the performance be any bettter with Win7:RC installed ratehr than the bloated vista install?
__________________
The Bit-Tech.net X-Box Live! Leaderboard
My X-Box Live & X-Fire GamerTag: BladeMRK WII#: 0379 8536 3210 2060 My Flikr albums |
#4 |
Pewlius Caesar
bit-tech Staff
GPU accelerated web browsing is coming, but who knows when it's actually going to be a reality
__________________
#5 |
Licenced idiot.
Something like that might well be the ideal choice for my energy-efficiency-aware mom... Would save space and electricity compared to a low-spec desktop, and be a pleasure to use with proper mouse+keyboard+screen when compared to a laptop.
Looking forward to the next gen of such things.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#6 |
Minimodder
What the hell happened to this article? I was in the middle of reading it and and went to click over to the next page and now it's suddenly vanished saying none of the pages are available!
#7 | |
Benchmarketeer
bit-tech Staff
#8 | |
You Rebel scum
#9 | ||
Multimodder
#10 |
Modder
Nice PC.
The problem with a lot of these miniature PCs is that most people that walk into a high street store and see these, fall in love with the small cuteness and energy saving factors, but then after they bring it home and use for a few weeks, reality starts to set in: This is when they begin to notice how frustrated they are getting with the system speeds. For example, they run a full indepth virus scan and while it's running, they try to open a few other applications and then notice how the system hardware is brought to its knees. These kinds of devices should be sold with a performance frustration WARNING sticker. People should only buy these if the size and energy saving is absolutely necessary. The thing is that most high street consumers underestimate what CPU intensive things they intend to do with a new PC. At the same time, they don't research the benchmark performance of the cute PC that they want to buy, before they buy it. |
#11 |
Licenced idiot.
There will always be stupid customers, and the whole of USA should prove that a warning sticker isn't going to save them.
__________________
#12 |
Lethargic
Well, I just picked up a Zotac Ion N330 (dual core Atom 1.6GHz) mobo with intent to built a low-power HTPC with it. Let's hope it does better than this little Revo does - the duallie will probably help a bit there.
Mine won't need to play Blu-ray's, but it does need to be able to cope with 720p MKV files so here's hoping that the fact that it's dual core and won't be running tons of manufacturer bloatware will help it. I'll probably also stick with XP rather than Vista... although Win 7 is a possibility. All in all, the Ion will be a good platform for media once there are GPU-accelerated codecs out there that can handle all the HD possibilities.
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA |
#13 |
Multimodder
Sure PowerDVD isn't what I would consider proper media playback software, but Media Player Classic Home Cinema (MPC-HC for short) is decent and has enough options to work with most setup. I find it odd that the people here at Bit-tech can't work that software right when so many others can regardless of what hardware they are running it on.
Maybe the Hardware decoding silicon in the 9400M isn't as good as it's full blown counterparts or you just didn't set up MPC-HC right. Also MPC-HC doesn't support every codec under the sun, but it supports a lot of current and common video codecs and most important l Xvid and H.264. And H.264 content should only be packed in a MKV or MP4 container. I would really like a list of the sample clips you guys used, what container format and what video/audio codecs they are encoded in.
__________________
- I'm the troll who bumps page 2 topics - |
#14 | |
Controlled by Eyebrow Powers
).My only problem is that the linux version isn't for sale here in Portugal. Anyone know an on line store that sells the Acer Revo Linux and ships to the European Union? I can't find any.... |
#15 |
What's a Dremel?
I'm eagerly awaiting someone installing XBMC Live on either model and checking it with 720p and 1080p video. Seems like an ideal "second system" for the bedroom, or even my kitchen, where 720p and a smaller screen are perfectly fine.
#16 |
Minimodder
I was planning on getting a revo for a htpc but I have heard a lot of bad things about it's performance due to the poor cpu.
An alternative maybe ASRock's Ion 330-BD. It has the dual core Atom 330 and is only a little bigger than the Wii http://www.engadget.com/2009/06/17/a...gets-reviewed/ |
#17 | |
Custom PC/Bit-tech - Antony
he he!
#18 |
Ultramodder
So it absolutely will not play TF2? Could you try the phong-free packs?
http://www.fpsbanana.com/skins/35108 http://www.fpsbanana.com/skins/35110 http://www.fpsbanana.com/skins/35148 Makes the game look like garbage, but vastly improves performance.. If TF2 can be made playable on this thing, I'm buying four.
__________________
Armagetron Advanced!
#19 |
Multimodder
Ah well. Such a missed oppertunity to storm the market. Maybe a 330 duel core would have given it the extra umph it needs to be non intrusive?
A quick 'Round 2' using a Win7 RC1 install would be very interesting. This could have been the perfect foil for the home use iMac.
__________________
Q9550 E0 @ stock under TRUE : Maximus II Formula : 4Gb Corsair Dominator : HD4870 512Mb (790/1100) + Accelero S1 120Gb G.Skill Falcon : 300Gb VelociRaptor : 1Tb Samsung F1 : Auzentech Prelude AE Aego M 2.1 : Hazro HZ24Wi LCD : G15 v1 KB : G5 Mouse : Lian-Li PC-A17 |
| Rocket_Knight64 |
| View Public Profile |
| Find More Posts by Rocket_Knight64 |
#20 |
a.k.a KazeModz
Well I have the 1000he, 2gb Ram, Win 7 RC1, and Im able to run 720p HD content fine but ya anything more then that is a no go for sure but hell the res is so low anyways it doesnt matter all that much so 720 is a ok on my system. It take a while and some tweaking around but I was able to get 720p to play with out needing to OC any of the hardware other then setting it to Super Performance and using a couple programs. The only thing I cant do is watch HD content online but after downloading it onto my system it will run fine. So I dont think it will take much from Intel to make that happen and Im sure they will. The 1000HV is running the Atom and the ATI 3450 (something like that cant remember the exact number but its from the 3k series) so it has no issues with any playback involving HD content on the system or online .
__________________
Current Rig: RubyRED
Lian-Li A05B (2) Swiftech 220 Radiators (2) D5 Variable Pumps (2) Res and a whole lot of modding Retired Rig: Project F.E.A.R. TT Lanbox Lite Swiftech H2O-120 Q6600 G0 OC@3.6ghz 2900XT 4gb SuperTalent Memory |
| Thread Tools | |
