Reply
Thread Tools View Mode
Old 26th Jun 2009, 08:58   #21
DonT-FeaR
I know what a fk'n Dremel is ok.:D
DonT-FeaR has yet to learn the way of the Dremel
wicked design
cant wait
DonT-FeaR is offline   Reply With Quote
Old 28th Jun 2009, 00:09   #22
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Day 3&4
Thanks. Sympathies about the weather from here too. (And gimmie my rain back!)
-I cut out a blank to make the last bits I need for the frame.
-I drilled some holes very close to the edge to mount this to the CNC mill. I'm using the cheap screws they put in miniblind mounting kits. They aren't long enough to go through the 3/4" plank I added to the mill, and I have millions of them.
-I have to set the 'home' position on this machine manually, so I start the program with the axes wound out to their maximum.
-After that I have to set the machine to get the origin point on the material and the CAM file to line up. I'm using the point of a countersink bit again; just like I did with my drillpress 'mill'.
-and away we go... 2500rpm, 7 inches per minute feed, one hour thirty minutes of sitting on the floor.
-I'm cutting the edge parts out first here because I had to take a wild stab at how thick the material was. I didn't know how well it would hold up and really didn't want it coming apart as I was cutting.
-This process wastes a lot of material. I wasted even more. I forgot to check my clearance on the Y axis and ended up crashing. When you crash the machine slips and loses track of where it should be. The part at the top with a big X through it was the part that crashed. The rest of the parts on the top row cut OK. I ran into problems when the the new position parts met the old ones. I cut out the bottom left so the part above it could be cut.
-Anatomy of my first crash.
-I got my hands on a pair of calipers before I started day 2. Things went much smoother. I surfaced the wood block. It left a nice edge I can use to align the parts on.
-I cut out the last bit I needed with an accurate measurement of the thickness. The plexi was .228. I cut down to .225. I'm s l o w l y working the rust out of my technique.
-And until next time, I'll leave you with some squirrel porn.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 28th Jun 2009, 00:35   #23
skreenname
SFF Forever
skreenname's Avatar
skreenname has yet to learn the way of the Dremel
Fapfapfap.
This'll be interesting. o:
__________________
3570S | 12GB DDR3 1600 | Ref. GTX 980 | Ncase M1 V2 | P8Z77I-Deluxe WD | SX500-LG | 840 Evo 120Gb | 850 Evo 500 Gb
skreenname is offline   Reply With Quote
Old 28th Jun 2009, 00:50   #24
Cheapskate
Cheapskate's Avatar
I didn't know you were so into squirrel porn.
__________________
Old 28th Jun 2009, 07:35   #25
longwing
69 Dude!!
longwing's Avatar
longwing has yet to learn the way of the Dremel
Truly, one of the more often maligned pornographic industries.
I'm definitely looking forward to seeing this progress.
longwing is offline   Reply With Quote
Old 28th Jun 2009, 18:22   #26
wbdog206
not me
wbdog206's Avatar
wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.wbdog206 is a hoopy frood who really knows where their towel is.
Nice work.
Can't wait to see more of this mod.
I live a couple 0f states north of
you Cheapskate and this 100+ weather is
killing me.
__________________
Of all the things I have lost,
I miss my mind the most.
wbdog206 is offline   Reply With Quote
Old 29th Jun 2009, 01:18   #27
Cheapskate
Cheapskate's Avatar
Thanks.
I noticed the 4 short bits I cut are wrong. They need to be long enough to fit over three layers of plexi. The part I drew out fits one. I'm making loads of mistakes this early in?
__________________
Old 29th Jun 2009, 02:06   #28
sixfootsideburns
modeteer
sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.
I so badly wish I could afford to put my ideas into projects, lol. Unfortunately I'm a poor college student and it isn't an option, so instead I have to read other peoples project logs and dream about one day making my own
I like the look though mate, one of my concept drawings has a drive bay mounted pretty similar to that. Mine has a locking mechanism so that you can push the top of the tray, and the CD drive slides up to give access, so I'm excited to see what you will do with this!
sixfootsideburns is offline   Reply With Quote
Old 29th Jun 2009, 02:54   #29
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Always love your work mate, looking great so far.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 29th Jun 2009, 03:51   #30
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
Thanks.
Too err is human, to really mess things up requires CNC.
Persevere young man. We watch. Oh, try to stay out of the heat!
john
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Old 29th Jun 2009, 03:53   #31
skreenname
SFF Forever
skreenname's Avatar
I like trees.
A lot.
__________________
Old 29th Jun 2009, 16:55   #32
Cheapskate
Cheapskate's Avatar
Thanks, everyone.
@Sixfoot - Oh! I have to figure out what I need to do with the drive bays! I need to break down and order more plexi too. You reminded me I have NO 1/4" plexi for that. If I have extra, I can make more mistakes.
@John - I'm pressure washing today, mowing tomorrow. I spend more time under the hose than the grass.
@skreen - I have trees. I wanted to take a pic of the perfect puffy clouds, but I realized that the only way to see the sky at my house is to look straight up.
__________________
Old 29th Jun 2009, 21:03   #33
skreenname
SFF Forever
skreenname's Avatar
Same for my house.
You can only really see sky if you're on the roof and looking up.
__________________
Old 29th Jun 2009, 21:25   #34
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Nice Cheapstake!!! I would watch this as it seems an epic win! Bravo and good luck with the mod! (and with the squirrel porn industry!) LoL
AnG3L is offline   Reply With Quote
Old 29th Jun 2009, 22:25   #35
jhanlon303
jhanlon303's Avatar
so? It's 100F degrees at your house and a heat index of 104F and you go to the roof? Me, I'd go to the air conditioned places. It's 91F and full sun here and I'm liking that the yard is drying out but now it's too hot! Keep your heat down there pls.
john
__________________
Old 29th Jun 2009, 22:48   #36
murtoz
Busy procrastinating
murtoz has yet to learn the way of the Dremel
... I expect it to be the heaviest thing I've put a computer in, short of my van. ...
:-O You've always kept your computers outdoors!?
... Feel free to comment on how I have the word 'ween' in the title.
Hmmm. I also noticed another word in the title.
Either way, looking forward to more insanity from cheesecake/cheapskate
murtoz is offline   Reply With Quote
Old 30th Jun 2009, 16:27   #37
Cheapskate
Cheapskate's Avatar
Thanks, Angel.
@Skeenname- I like how the house is completely black in that pic. I'm ruthless with the pruning, but 40 trees... and the reason there's sky in that shot is because that's where the tree that was just cut down used to be.
@John- I'm not on any roof! I got caught in a surprise downpour yesterday! I was thinking it felt nice, then the lightning started up. My neighborhood is still dry.
@Murtoz - Good eye! The name is kinda sounding gay now. Any ideas for a new name are welcome. If I can defile the name of a cartoon character, it will be perfect. I went with that name because glassgreen turns up a million Coke bottle hits.
I ordered more p'glass. Goodbye $130... So I've purchased 3/4 of a full sheet of 1/4" and 1/8" for one project.
__________________
Old 30th Jun 2009, 17:08   #38
MIGUI
Multimodder
MIGUI's Avatar
MIGUI has yet to learn the way of the Dremel
Nice work Cheapskate.
__________________
Excuse me for my bad english.
MIGUI is offline   Reply With Quote
Old 30th Jun 2009, 18:51   #39
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
Awesome, Cheaps. I really like the res location too. Man, that thing's going to weigh a ton. Looks like a PA rad in the Sketchup design; did you go contrary to your name finally on the hardware purchase?
This should be fun! Good luck with the build, man.
__________________
Latest Builds:
LilyPC V.2BIO-A10 - MotM Jul. '12 Nominee Loser!"Movie Sign!" - in progressCheckMate - MotM May '09 Nominee Loser!BluBawx I - MotY '09 Nominee Loser!Lumière Noire - MotM Apr. '08 Nominee Loser!NOTalis w/ MNPCTech"Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 1st Jul 2009, 01:18   #40
Cheapskate
Cheapskate's Avatar
You assume I've bought hardware? All hardware is still just a gleam in my eye.
-Wait. I take that back. I DID buy the screws to mount the side panels. Does that count as hardware?
This one is already $2600 contrary to my name.
__________________
Reply
Tags
blame it on cheaps, cheap's fault, cheapskate, crackskate, master of acrylic, plexiglas
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
