Reply
Thread Tools View Mode
Old 7th Jul 2009, 08:26   #61
perplekks45
LIKE AN ANIMAL!
perplekks45's Avatar
perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.perplekks45 is a hoopy frood who really knows where their towel is.
Well, we all know who to blame if anything goes wrong. So Cheaps can just use good ol' trial-and-error.
But could I get some help over here now? Jaw's on the floor...
Well done mate!
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far.
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
Iä! Iä! Cthulhu fhtagn!
perplekks45 is offline   Reply With Quote
Old 7th Jul 2009, 16:48   #62
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.
Thanks guys.
@Perplekks - It's not my fault your jaw is on the floor. Everything I've done so far is a re-hash of my previous work.
@Bfelda - The old lexan argument again. The ones I made for Bloo are still very supple. I think problems with cracking would only occur if you put the material in a situation where it's always bent.
-I just remembered a section of curved solarium glass I replaced with lexan. It hasn't done any cracking either, and it's exposed to sunlight.
Anyway, the stuff is really flexible, and you can fold it without cracking it, (in my experience.) I have a 1/2" thick piece that someone tried to cut with an industrial metal shear.
@Modminded -
Yeah, that's what she said.
It's a good thing I didn't say anything about how it takes all my 3/8" shank bits...
SOMEWHERE on the net there is a free DXF SU exporter. I think I found it on a Guitar making forum. SU works great for basic 2.5D stuff, but I wouldn't use it for curves. -Not that I care. I have to sand the stuff down anyway.
Cheapskate is offline   Reply With Quote
Old 7th Jul 2009, 17:07   #63
perplekks45
LIKE AN ANIMAL!
It's NOT your fault?! YEAH RIGHT!
__________________
Old 8th Jul 2009, 06:02   #64
Bad_cancer
Mauritius? 2nd speck east of africa
Bad_cancer's Avatar
Bad_cancer has yet to learn the way of the Dremel
Well lexan is uv proof, not only does it not get damaged by uvs, it doesnt let any through.
So no solar damage to lexan (This is polycarbonate we are talking bout right?)
And i can confirm it will not crack or break only bend. You can drive over it and it will only bend out of shape.
If you make a deep cut in it with a utiliy knife then you can snap a section off.
I used to work for a signage company and this is what they use when they dont want their plastic signs to be broken by "local riffraff"
This is the stuff they use for bulletproof windows afterall.
So i really doubt that those clips will break or crack even if bent all the time.
Most probably your worst case scenario is that they are going to bend out of shape, nothing more.
__________________
Q9550 | Evga 790i ultra sli | 4gb Ram | 2x Gtx460 (1gb) | 1Tb storage | Icute titanium 750w |
Cold lava~MOTM Nominee May 2010.
Bad_cancer is offline   Reply With Quote
Old 8th Jul 2009, 13:03   #65
Monkey Puzzle
Multimodder
Monkey Puzzle's Avatar
Monkey Puzzle has yet to learn the way of the Dremel
Looking good. Wouldn't it be easier and stronger to use thicker sheets rather than lots of thinner ones on the side panels etc, or is it like that for aesthetics?
Monkey Puzzle is offline   Reply With Quote
Old 8th Jul 2009, 16:01   #66
Cheapskate
Cheapskate's Avatar
Thanks.
There's a lot of reasons for doing it this way.
A single 2' x 4' sheet of 1/4" plexiglas from this company cost me ~66 bucks. The size choices they carry skip from 1/4" to 1". A 2x4 of 1" costs $370. They are also not the most precise cutters. They cut one panel 1/8" short of 24", and the other 3/16 short. I made sure to cut the frame parts from the same sheet the body panels were cut from so they would match.
The layered look will make neat effects when polished, and it's just as strong as a solid piece. Also I'm sandwiching machine nuts in the frame layers.
Old 10th Jul 2009, 15:53   #67
murtoz
Busy procrastinating
murtoz has yet to learn the way of the Dremel
Originally Posted by Cheapskate View Post
@Modminded - I'd have to change my avatar to Elmer Fudd- and do the whole log like that.
Pwus one.
murtoz is offline   Reply With Quote
Old 10th Jul 2009, 17:21   #68
ModMinded
Are you throwing that away?
ModMinded's Avatar
ModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the Dremel
Originally Posted by murtoz View Post
Pwus one.
lol! (pwus rep)
Anyone remember Elmer Fudd Google results?
__________________
My First Mod Log (Nzxt Lexa) (Ongoing) - What was that about idle hands?
ModMinded is offline   Reply With Quote
Old 10th Jul 2009, 17:34   #69
Cheapskate
Cheapskate's Avatar
Still in the testing stages...
No way! People have a hard enough time understanding me here.
-My slow progress must drive you people crazy.
-The test fit of the drive latches proved my fears were correct. The best way to fix this is to move the fan to the outside, which will hit the frame. The back is going to end up being the most interesting area on the case. Note to self: Add a baseplate.
-I need something to help me get the access panels oriented right. As they are, I wouldn't be able to tell if they were left, right, or even upside-down. So what you are seeing in the pic is a little experiment for possibly adding color inserts on the panels. I have some 1/8" UV blue that would look good as a small accent.
-You can see here I have a small gap between the parts. It's enough that the center bit spins freely, even though the shapes have flat sides. I need to work out how much that is so I can compensate for it in the computer.
-and my math is terrible...
-For my second test cut, I had to remove the wood block. I took this time to add a cr*p guard to the motor mount. The color should tell everyone what kind of container I chopped to make it.
Yes, I am padding a really weak update.
-I mentioned the mill came with a tiny vise. Now you get to see the little guy.
-The plan is to have stainless steel nuts housed in center layer of the frame. I set up another test cut...
-and my nuts don't fit!*cough* I measured the nut by the sides, but SU measures polygons by the distance between points. It's a classic case of me not paying attention, but it's good for a few nut jokes.
-The second test had better results. Because the mill bit can't cut perfect corners, I had to file the hole a tiny bit. There was no way I was going to take a file to my nuts!!!
-I added some IPS#16 gel glue to the fit to see if the edges would clear up.
Old 10th Jul 2009, 19:04   #70
ModMinded
ModMinded's Avatar
Hey Cheaps,
I'm a loser, I can't tell what you used for the motor guard. Medicine bottle?
Can you put the HDs in from the front to avoid this issue? or move the bay forward a bit in the case?
We all know you're nutty!
__________________
Old 10th Jul 2009, 19:41   #71
Cheapskate
Cheapskate's Avatar
The correct answer is - A: Medicine bottle
I'm moving the bay back one inch by losing the fan. That gives me an excuse to make an interesting fan shroud. I already need something to cover the 120x3 radiator. -especially if I use the one I bummed off Legoman666. I hear it will require some serious surgery.
Old 10th Jul 2009, 21:31   #72
ModMinded
ModMinded's Avatar
Yay, I'm not a loser!
Shutup!
__________________
Old 10th Jul 2009, 21:36   #73
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
Shutup!
You are a loser, learn to live with it
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is online now   Reply With Quote
Old 11th Jul 2009, 06:17   #74
perplekks45
LIKE AN ANIMAL!
Just blame it on Cheaps!
It really is THAT easy.
__________________
Old 11th Jul 2009, 18:24   #75
Cheapskate
Cheapskate's Avatar
You are a loser. You spend too much time with the wrong crowd.
-so I guess you can blame it on me...
Old 11th Jul 2009, 18:49   #76
barry99705
sudo rm -Rf /
barry99705's Avatar
barry99705 has yet to learn the way of the Dremelbarry99705 has yet to learn the way of the Dremelbarry99705 has yet to learn the way of the Dremelbarry99705 has yet to learn the way of the Dremel
Hey Cheaps,
"I'm a loser baybayyyy, so why don'cha kill mayyyyyy"
__________________
I always wanted to have that ideal father son relationship. You know, where I get to see him for like eight hours every other weekend, and send checks to some woman I hate. -- Tucker, Red vs. Blue
barry99705 is offline   Reply With Quote
Old 11th Jul 2009, 23:46   #77
ModMinded
ModMinded's Avatar
:hides head in shame:
You know who's not a loser? That guy Langer... he apparently has a life.
I can't really blame Cheaps... though he does encourage this behavior!
__________________
Old 11th Jul 2009, 23:53   #78
perplekks45
LIKE AN ANIMAL!
But... but... IT'S HIS FAULT!!!!
__________________
Old 14th Jul 2009, 04:34   #79
Cheapskate
Cheapskate's Avatar
-You guys...
@Perplekks - This blame me thing is turning into a campaign for you, isn't it.
-Things are going slow in both reality and the virtual world. I swiped a motherboard model from one of Scooby's Sketchup files, so if the measurements are off... It's still my fault for not checking them. The flat blue donut on the side panel is what I plan to use to mark the front edge. A top-bottom marker is still up in the air. The good news is that I can cut the I/O holes out on the mill. It clears by a tiny bit.
-Today's lunch involved milling the nut holes. That doesn't sound right - nut holes...
-Done.
-I had to cut a window pane replacement, so I figured I'd cut some other sh*t out too. I need stuff for the drive cage. I set up the guide with an engineers ruler.
-And I cut.
-and decided to mow today. The scary part is it rained ONCE last week, and the yard went f*ckadilly nuts.
-The I/O layers. My SOP is to glue these to the back panel, and cut out the holes out on the mill. -Only I have a real mill this time. There should be a lot less cleanup.
-Cut. See! I'm making progress. -Even if it's at making a pile of parts.
nut holes...
Old 14th Jul 2009, 07:42   #80
perplekks45
LIKE AN ANIMAL!
You like leaving little piles around, don't you?
Good to see you're making progress.
Oh and I recently saw another forum member [Kauzuul or something like that] who had "Blame it on Cheaps!" in his sig or over the avatar.
__________________
Reply
Tags
blame it on cheaps, cheap's fault, cheapskate, crackskate, master of acrylic, plexiglas
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
