Thread Tools | View Mode |
#1201 |
Pipebender
#1202 | |
sudo rm -Rf /
__________________
I always wanted to have that ideal father son relationship. You know, where I get to see him for like eight hours every other weekend, and send checks to some woman I hate. -- Tucker, Red vs. Blue Last edited by barry99705; 25th Oct 2012 at 22:37. Reason: stupid forum software... |
#1203 |
Supermodder
Nice job again cheapskate and a nice monkey you got there.
__________________
Completed Projects Project Desk Art - Project Flipmode - Project The Next Level In progress Project P42 |
#1204 |
↓ Don't trust that face!
90% new monkey love. 10% build love. Thanks, though. I gotta step up my game.@Barry - monkey has no body, soooo... no tailpipe. I chopped up the PSU a while back and it still works.
__________________
#1205 |
...And still no fire.
![]() -When we last left our hero, he was fighting Ming's atomic robots- Wait... No, I was mounting a shroud on the side of the recently RMA'd power supply. Here I've removed the label so I'd have a nice indented spot for... wait for it... velcro. A great way to remove tape residue is with some naphtha on toilet paper - if you don't smoke. ![]() -POW! Real quick, and the paint is intact. ![]() ![]() -Currently, I'm making little holes so I can sneak wires into the motherboard cover. ![]() -Before I can cover the motherboard, I need to make a little room for one... Time to tame the octopus. ![]() -Some idiot didn't rotate his pictures. Here I've cut unwanted wires, and have marked the wires I want with what I want them for. ![]() -First, I sure didn't need a foot of cable for each drive. A little black paint takes care of any exposed red or yellow. ![]() -Now to cannibalize the low speed cables that came with the Noctua fans. To get those pesky male pins out, jam a paperclip in the hook side of the connector well. Don't so this with a live connector, of course, you have to lick those first. ![]() I had a Maalox moment for a bit when I noticed the PCI connectors were wire coded like there were 2 rails. Two cords had silver/yellow, two were normal. It hasn't burst into flames yet, so I guess all is well. ![]() I used the extra PCI wires to save space. I didn't need any 5 volt wires, after all. ![]() -I saved a few of the tach wires. -No real speed control, though.. just a, "why, yes. You do have a fan." ![]() -Looks fine to me. This was, what... a week after RMA? That'll bite me in the ass later. The PSU in Bloo tanked already too. ![]() -Ooh Yeah, a slim,sexy, two-wire molex connector for the pump. Guess where that came from. ![]() While buying shrink wrap, I made an impulse buy to check out something Brother Mach taught us... ![]() Yep. 1/4" lamp fittings ARE compatible with G1/4 fittings. If you can get them in solid brass it means that everything you need to make a badass metal reservoir can be found at the hardware store.I'd like to thank my sponsors here for all their support. ![]() RIP![]()
__________________
#1206 |
bt sever tanks, Cheaps makes triple repost update
__________________
#1207 |
BT go down
..and what is a "crackskate?"
__________________
#1208 |
Fenrir The Wolf
Aha, it's your fault for BT go down. BT server can't hadle so much awesome from this log.
#1209 |
dat steak
![]() Cheeps updates.. |
#1210 |
modeteer
#1211 |
Thanks.@Mankz - Is that joy, or shock?
__________________
#1212 |
Never stuck with stock@Hotmods.net
3,5 years now. While others might being losing interest at this point, I'm sticking around for the full ride. MOTY 2016?
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#1213 | |
I've got wood
I always had the same problem, however I bought a decent face mask from Screwfix and it's comfortable enough to wear for hours. You do get some condensation inside the mask which you can either tap out, or let it drip onto your work which it occasionally does! It's made from soft rubber/silicon stuff so is a lot better than the poor quality masks. Also, as it is a good fit on the face you don't typically get condensation on your glasses. |
#1214 |
Pipebender
Fogging goggles? Wipe them down with vinegar,works a treat with my bike helmet visor.
#1215 |
Thanks, Nutman, but stop counting!!! -2016 may be doable. I've made great progress with the sanding.If your goggles fog you should just stop breathing. I can't use the classic soft plastic goggles either. They were apparently made by someone with a tiny nose. A proper respirator will stop the fogging issue. Those stupid paper dust masks show just how useless they are when they fog your glasses. If air leaves the mask around the edges, guess how it gets in.[/rant]
__________________
#1216 |
Car lover and Speed Junkie
Ima stick around till the end. Frankly, I need a lonf term source of reliable, awesome, acrylic awesomesauce updates
#1217 |
Time For your yearly update.
![]() ![]() -Gah! Stupid birds! I just washed that! It looked like this for most of the year while I've been wetsanding. The sneezing blood is over for a while. ![]() -Much better. Let's see you hose a steel case off in the shower. ![]() -There was a month of hand and machine buffing. Essentially I got very touchy-feely with the case, only with Novus polish on felt, and without the police questioning afterward. -This is the setup I used for a lot of the external surfaces. I had a problem at first. I couldn't get the wheel spinning fast enough to heat the polishing wax without it also exploding in a angry lint shower. The hair dryer that only comes out when guests visit got some use heating the wax. BTW, that's the only pic of the polishing process... I can find. ![]() -Oh, I finally got these muthers glued. -An afterthought pick for an afterthought job. ![]() -With 99% of the frame polished, it was time to decide what to do with the motherboard tray. I decided to remove a little of the extra material. ![]() -I marked the cuts well in case it took me a year to come back to it. ![]() -I resorted to drawer-vice one last time. Don't mock the condition of my cabinets. You see how I treat them... ![]() -I filed a bevel on the open edges, and sanded them round and smooth. ![]() -I needed something to make the top seam nice and snug, so once again I whipped out my big nuts and slapped them on top of the bulkhead. I never get tired of that joke. ![]() -At this point I decided to put all the loose bits together and see if there were any problems. -I mean, besides the fact that I haven't finished polishing, cleaning, dusting... -MMMM! Water spots! -That rough polishing pass on the side panel is pretty funky too. -Yep. It's still missing a radiator and some fans here. I was kind of USING them. ![]() I'm going to have a lot of fun with the 4 fans blowing out, one fan blowing in -thing. ![]() -I'm glad I went with the squiggly vent pattern now. The reflections play with your perception 'n stuff. ![]() -Tryin' to get some of the natural color here. I'm already getting autofocus stealth issues with the case. There's lots of flash glare too. Something's still missing... Oh, right the reservoir. Bill was sent the core to get it cut. There's some genuine fear about putting it in a 10,000 RPM CNC lathe. Bill has already dubbed it, "the exploder rod." -And yeah, I've already went though all the jokes you can think about there. On my side, I have a million tiny spacers to get polished for the res fins. ![]() Thanks for tuning in to "SplÖderrÖd" and thanks to our sponsors: RIP![]()
__________________
#1218 |
Dale you're on a roll...
Looking really good Cheaps, seems all the elbow grease was worth it, those acrylic edges look fantastic! Great to see an update on this, love the design.
__________________
Project Azure - MotM Februaray 2013 Nominee
#1219 |
CNC mad!
This is so SCHWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET dude.. (Took me ages to go through the log though! xD
Makes me want to make a tall case! I need to do a scratch build like thisss!
__________________
'You had my curiosity, now you have my attention' |
#1220 |
Fenrir The Wolf
Update!
![]() Is this mean that you will finish this case soon?
| Tags |
| blame it on cheaps, cheap's fault, cheapskate, crackskate, master of acrylic, plexiglas |
| Thread Tools | |
| View Mode | |
