Thread Tools |
#1 |
Editor @ CPC
bit-tech Staff
Samsung NC20 - 12in Ultraportable Review
http://www.bit-tech.net/hardware/lap...table-review/1
Samsung is back with a 12.1in clone of its hugely successful NC10 netbook. There's a lot more to it than that though, as the NC20 is one of the first laptops to be based around VIA's Nano processor. Does Samsung's slinky ultraportable retain all of the charm its little brother had? Read on to find out.
#2 |
Multimodder
What I really can't wait for is Via Nano + Nvidia Ion. Now that would be worth getting!
#3 |
I Mod, Therefore I Own
I've found on my NC10 that the zoom thing on the trackpad sometimes seems to zoom by itself, but then I usually realise that my finger on my other hand was just resting on the trackpad, or another finger on my right hand has just tiouched the trackpad.
Looks good, If they offered tradeups, for NC10 owners to get a discount on the NC20 then I might get one. But I don't really use my NC10 enough to warrant buying a new one. , browsing the internet in lectures isn't really a good enough reason,
__________________
| Q6600 @ 3.2GHz with Xigmatek HDT-S1283 | Asus P5K Premium | | 4GiB Patriot 800MHz | 512MiB 8800GT with Thermalright HR-03GT | Thermaltake Armor | 3DMark06 = 13096 Cerberus_xiii from CustomPC
| Cerberus90 |
| View Public Profile |
| Find More Posts by Cerberus90 |
#4 |
Minimodder
What about the fan's habbits? Is it loud? Can it be turned off? Does it ramp up under load?
#5 | |
Supermodder
| Skiddywinks |
| Find More Posts by Skiddywinks |
#6 |
What's a Dremel?
I used my NC-20 outside for the first time over the weekend. I expected the glossy screen to be totally unusable, but with the brightness turned right up it was a bit dark but OK. I think I'd have been scuppered if the sun had been out, though. I'd still prefer a matte screen, but the glossy screen has not been as big a problem as I'd expected.
I agree about the stupid track-pad, I'm *this close* to turning the zoom/scroll stuff off altogether on mine. The problem is that the track-pad is flush with the wrist-rest, so it's too easy for another finger to touch the pad, which triggers the zoom. About the fan, I've not noticed any noise at all, but I don't exactly work the machine very hard. No problems with the battery life from my point of view. I've taken it on days out without the PSU and not run out of juice yet. BatteryBar reckons just under 5 hours, that's with WiFi on and the screen at about 1/3 brightness. You can't use the Ion chipset with the Nano CPU can you? The Ion is for the Atom CPU. |
#7 | ||
Editor @ CPC
bit-tech Staff
#8 |
What's a Dremel?
THis is where I already have an issue with:
While the Atom netbooks display 720p video's perfectly fine, the article mentions that the responsiveness of the in order VIA chip is better than the Atomprocessor. This is wrong in my mind. One of the reasons the Atom worked so well is that it was more responsive than out of order processors due to it's HT capability! The atom shows small commands like opening many windows like smaller programs, web browsers , etc.. better than my AMD Athlon XP 2600+! That's why I switched! Though, the XP2600 could handle single threaded applications better that required more intensive CPU processing power. This is what you see also in the benches, singlethreaded applications appear to function better on the VIA chip than on the Atom. Multithreaded applications are faster on the Atom which supports HT technology. This would have been a good laptop, if it rather had 2 smaller VIA CPU cores, rather than 1 larger one; for system's responsiveness. Ofcourse dual cores / hyper threading capable cpu's perform slightly worse on singlethreaded applications, though that may change in Windows 7. As you mention in the conclusion, the (hardly noticable) performance gain of the NC20 goes together with a decrease in battery life of almost 40%! I think that's not worth it! Also matte screens can hardly or can not be used outside. Glossy screens or reflective surface screens can, because it allows sunrays to penetrate the outter layer all the way to the core of the LCD screen, allowing for better outside environment display contrast. In some cases in sunlight the backlight can be shut down completely, as a reflective screen can be used there where a matte one can't. So the reflective screen is less a matter of 'wants', but to make this laptop available for a larger audience (ie those wanting to use it outside without wasting too much battery on boosting the screen brightness to the max in sunlight). Besides shiny/glossy screens also allow better contrast ratio's when watching movies. Images appear sharper and colors more vivid. So I find there are more benefits to a shiny screen than drawbacks. Usually the drawbacks are (or is) a reflection on a screen that can easily be avoided by tilting the screen upward or down a bit. |
#9 |
Licenced idiot.
Oh cmon give me a dual core ion-netbook already. I just got my IBM X31 sold, and want a genuine upgrade from it. A single core Atom/VIA just doesn't seem like a real upgrade coming from Centrino 1,6 GHz... Also the man who came up with the XP-limitations for netbooks, as well as the people that followed those, deserve to be shot in the dawn.
Yes, I DO have an issue with the current trend I don't care if the screen size has gone from 7 to 12 inches, when the stuff that matters is more or less the same. And still no DVI? Maybe I'll just buy another used IBM...
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#10 |
Supermodder
Is it just me, or is the entire point of a *net*book that it just isn't meant to be able to handle huge CPU loads and graphics programs.
| ParaHelix.org |
| Find More Posts by ParaHelix.org |
#11 |
Licenced idiot.
It's just you.
Sure the price sets certain limitations, but I'd expect them to evolve pretty quickly as the fight at the 300-500 € price range is pretty fierce. Fierce as in right now all manufacturers make different shaped plastic books with the same internals...
__________________
#12 |
Freed on Probation
nice review, ive been tempted by one for ages, just wish it was a bit cheaper. Think i might wait for some lenovo s12 reviews before i do tho...
btw, a tilde is ~ and is in its normal place...
__________________
I may be fat but at least I am not Ginger "The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson |
#13 | |
I'm not a modder.
1)generally Atoms have some trouble with 720P footage... Acer wouldn't feel the need for this if it were fine! 2) not going to say much about OoOE but I can't help feeling you are wrong ![]() 3)I should think most of the battery life drops are due to the bigger screen rather than the more power-hungry processor. The Nano uses more under load but can be under load for a shorter amount of time than the Atom, and the power consumption of the Atom is dwarfed by that of its chipset. 4) I strongly disagree with your comment amount glossy screens being better outside. I had a matte-screened laptop for ages before I got my current one and it was miles better in the sun, I have to have my current one at maximum brightness if I am anywhere bright. The problem is completely the opposite of what you describe - with a glossy screen the sunlight reflects off it and, unless you have got the brightness up on the laptop, completely overpowers it so you can't see anything. The kind of screen that uses the sun to help are transreflective and I have only seen them on PDAs and phones. I do agree that glossy screens can improve contrast but I find myself annoyed far more by seeing myself in my screen than a lack of contrast in most circumstances. A lot of things have been said about the keyboard - it seems to be a little Samsung annoyance having the ` and Windows keys in the wrong places - they are on my Q45 too. Just to add insult to bad key placement, the CTRL and Fn/menu keys are the wrong way round too! What is the 1 called anyway?
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#14 | |
Minimodder
What do you want dual core for anyway? sounds like you should just get a proper laptop and be done with it. |
#15 |
Minimodder
By the way that Ion Netbook better have a digital display output. It's pretty hard to tell from the picture but I only see VGA. Bah!
#16 |
BSc... finally
IT'S NOT A NETBOOK!
Netbooks are <= 10in! Nice ultraportable but still not powerful enough and/or a bit too powerhungry, depending on what you're going to use it for.
__________________
"The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far." Blame it on Cheaps! [now a social group]
#17 | |
What's a Dremel?
| Thread Tools | |
