Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 29th Jun 2009, 10:40   #1
Sifter3000
I used to be somebody
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
Games I Own: SiN and Sin Episodes
http://www.bit-tech.net/blog/2009/06...-sin-episodes/
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 29th Jun 2009, 10:51   #2
steveo_mcg
I Mod, Therefore I Own
steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.
I still have this installed for the arena mode its great fun when you need to pop helmets off bad guys, the balance thing is interesting and frustrating at the same time as it some times makes it just a little too hard and kills that streak you were really enjoying.
Should probably play through the single player again, tbh i found it too hard for my liking and ended up with god mode on. I got it cheap probably just before ritual were bought out so i'm not all that sore that its not getting finished.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 29th Jun 2009, 11:21   #3
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
There are points of the SP that are very hard admittedly, especially once you get to SinTower. If you're having trouble though then why not start the challenge slider really, really low? If the difficulty of the game starts off at the bottom then it'll very slowly increase in difficulty until it gets to the right setting...supposedly.
It's important to change between weapons a lot too. If you stick with the pistol into the end of the game for example and keep popping helmets and blowing heads off then the game will start to replace the grunts with more and more chaingunners. The pistol doesn't do anything for them and you'll need to swap to shotgun or SMG alt-fre, but you can keep their numbers a bit more reasonable by using grenades, swapping your arsenal around and shooting gas tanks.
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 29th Jun 2009, 11:36   #4
steveo_mcg
Good advice, i think i'll give it another go over the week instead of my tf2 evening sessions though with the slider right down.
I'll try alternating the guns shame really, the pistol in SiN is about the best fun in any game, right up there with 47's ballers.
__________________
ook
Old 29th Jun 2009, 12:02   #5
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.
Why a spoon cousin?
__________________
Jamie is offline   Reply With Quote
Old 29th Jun 2009, 12:21   #6
CardJoe
CardJoe's Avatar
Originally Posted by Jamie View Post
Why a spoon cousin?
It's dull, you twit. It'll hurt more.
That film is full of material that's oh-so quotable, even though it really shouldn't be.
__________________
Old 29th Jun 2009, 13:42   #7
Blademrk
Why so serious?
Blademrk's Avatar
Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!
Got the original + expansion pak, always meant to pick up sin: episodes too, it's just one of those I games I never got 'round to getting.
__________________
刃mrk
My X-Box Live gamertag, PSN, Steam & Nintendo ID is BladeMrk
Blademrk is offline   Reply With Quote
Old 29th Jun 2009, 15:39   #8
philheckler
Used to be a pc enthusiast
philheckler's Avatar
philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.philheckler is the Cheesecake. Relix smiles down upon them.
Sin episodes was ok - some very nice breasts though! - i did feel a bit ripped off when there were no more Sin episodes , HMMM that reminds me of another episodic game that seems to be M.I.A
__________________
i5 750 currently @ 3.6ghz / p7p55d pro / 4 gb gskill ripjaw 1600mhz cas 8 (@1440mhz) / freezer 7 pro rev2 / gtx470 sli / Corsair hx850 psu / coolermaster cm690 v2 advanced
philheckler is offline   Reply With Quote
Old 29th Jun 2009, 21:46   #9
goafreak
What's a Dremel?
goafreak has yet to learn the way of the Dremel
Play it, too, and enjoyed it as much as you did!
goafreak is offline   Reply With Quote
Old 30th Jun 2009, 01:12   #10
Snaek
Multimodder
Snaek's Avatar
Snaek has yet to learn the way of the DremelSnaek has yet to learn the way of the Dremel
Sin Episodes was a lot of fun. I was very disappointed when the series was canceled.
Snaek is offline   Reply With Quote
Old 30th Jun 2009, 03:06   #11
bridgesentry
3verything must bee wat3rcooled
bridgesentry's Avatar
bridgesentry has yet to learn the way of the Dremel
I had been waiting for this game to come out, but GS (sorry at that time I did know no thing about BT ) review of it disappointed me. I think only if I have a brother who bought it and installed it for me, I 'd give it a try.
Originally Posted by our Joe:
Every time I played through the game it seemed different and I probably played it a good ten or so times (each time with God mode on though as it was a horrendously difficult game).
I can't remember how many times I have played NOLF2 (not "play through", just beginning levels, I hate boss fight), maybe more than 100, Warcraft3 (single map): maybe more than 1000
bridgesentry is offline   Reply With Quote
Old 30th Jun 2009, 10:55   #12
Hamish
Hamish has yet to learn the way of the DremelHamish has yet to learn the way of the Dremel
sin episodes was great
i remember completing it before they patched the broken difficulty system that never ramped the difficulty back down
that made things interesting
Hamish is offline   Reply With Quote
Old 2nd Jul 2009, 04:00   #13
Snaek
Multimodder
Snaek's Avatar
Oh, yeah. That was... real fun. I just thought the game was insanely difficult the first time I played through.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
