Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 30th Jun 2009, 07:40   #1
Faulk_Wulf
Internet Addict
Faulk_Wulf's Avatar
Faulk_Wulf has yet to learn the way of the Dremel
Motherboard won't let computer boot w/ PCI cards
# System:
* CPU - Intel Celeron Dual Core E1400 Processor BX80557E1400 - 2.0GHz, 512KB Cache, 800MHz FSB, Allendale, Dual-Core, Retail, Socket 775, Processor with Fan
* Motherboard - Midwest Micro Asus P5GZ-MX Socket 775 ATX Motherboard
* RAM - 2x Patriot Signature 1024MB PC6400 DDR2 800MHz Memory (CAS 4-5-4-11) 444Mhz (DDR888)
* Graphics card - EVGA GeForce 7100 GS Video Card - 256MB DDR2, Supporting 512MB with Turbocache, PCI Express, SLI Ready, DVI, VGA, TV Out, Video Card
* Power supply - Unbranded 350Watt Power Supply With Barebones Micro-ATX Tower
* Operating system - Windows XP Pro Slipstreamed w/ Service Pack 2
* Hard Drive - Seagate Barracuda 7200.10 160GB Hard Drive - 7200, 8MB, SATA-300, OEM
* Drives - Sabrent Internal 64-in-1 Multi Flash Media Card Reader - USB 2.0, Black, 3.5", Self Powered, SDHC Support, Vista Ready
# Problem:
* When ever any PCI card is plugged into any PCI port or the graphics card is plugged into the PCI-E port, the computer will hang, reboot, or crash during the XP loading animation. It does not matter what card / port combination-- only when all PCI / PCI-E ports are clear does the system boot.
* With no cards in, the system runs fine. Never crashes, never throws an error, even when up for days and doing a bunch of stuff simultaneously. Formatting has not fixed it, though I never tried flashing the Bios.
Thoughts?
__________________
-- Faulken S. Wulf
"Under the Willow, he sleeps and dreams, of Heaven."
Looking over my threads, I've come to realize that I have a ridiculous amount of bad luck with my electronics.
Faulk_Wulf is offline   Reply With Quote
Old 30th Jun 2009, 10:48   #2
adam_bagpuss
Have you tried turning it off/on ?
adam_bagpuss's Avatar
adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.
guessing that your mobo has on-board VGA.
when you put a graphics card in the PCI-E, boot into the bios and check which is displayed first.
set it to PCI-e if poss.
or
try to disable the on-board graphics if you can.
adam_bagpuss is offline   Reply With Quote
Old 1st Jul 2009, 22:51   #3
Faulk_Wulf
Internet Addict
Faulk_Wulf's Avatar
Thank you very much for the suggestion. I will try that soon.
It would actually explain a lot-- since the computer never had a problem with the card until AFTER i had to replace the CMOS battery.
I'll post again / edit this post once I have tried that.
__________________
-- Faulken S. Wulf
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
