RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Jun 2009, 11:04   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
AMD Athlon II X2 250 CPU Review
http://www.bit-tech.net/hardware/cpu...0-cpu-review/1
The Athlon brand lives on! AMD's latest CPU is a 45nm, 3.0GHz exceptionally budget friendly processor, ready for DDR3 as well as DDR2. Is it a monster overclocker and all round Intel E5200 killer?
Tim S is offline   Reply With Quote
Old 30th Jun 2009, 11:31   #2
OWNED66
Modder
OWNED66 is on a distinguished road
hmmm
good cpu
+ EPIC overclocking skillz
OWNED66 is offline   Reply With Quote
Old 30th Jun 2009, 11:37   #3
Ending Credits
Hoot if you're a revowlutionary.
Ending Credits's Avatar
Ending Credits is a glorious beacon of lightEnding Credits is a glorious beacon of lightEnding Credits is a glorious beacon of lightEnding Credits is a glorious beacon of lightEnding Credits is a glorious beacon of light
AMD, when are you going to catch up?
I've got 4 of your bloody CPUs.
__________________
A Little Game I made in Leadwerks
AMD Phenom 9850 Black Edition || DFI 790FXB-M2RSH || Powercolour ATI 4870 1GB || 4GB 1066Mhz GEIL Black Dragon || Aplus Black Pearl WCR || Yurak 24" PVA || 19" Hanns-G || Vista 64-bit
AMD Phenom 9500 || GIGABYTE GA-M720-US3 || MSI 7600GT || 2GB DDR2 1066Mhz || bequiet 350W
Ending Credits is offline   Reply With Quote
Old 30th Jun 2009, 11:52   #4
Gremlin
Multimodder
Gremlin's Avatar
Gremlin is on a distinguished road
Any idea on when we are going to see the Phenom II X2 550 review show up Bindi?
The L3 should really help it in some scenarios like gaming etc and give it up to another 5-10% or so
Gremlin is offline   Reply With Quote
Old 30th Jun 2009, 12:10   #5
Lizard
Addicted to upgrades
Lizard's Avatar
Lizard is on a distinguished road
The Phenom II X2 550 BE review should be making an appearance later this week
__________________
James Gorbold
CPC Deputy Editor
Folding/Gaming as Lizard
More power, we need more power
Join the Custom PC/Bit-tech Folding Team (#35947)
Lizard is offline   Reply With Quote
Old 30th Jun 2009, 13:56   #6
GeorgeStorm
Overclocking, a way of life....
GeorgeStorm is on a distinguished road
The 550 is the cpu to buy right now, hopefully bit-tech dont get a dud.
What voltage were you using on the e5200 to get that overclock btw?
Im surprised you didnt gain any more results from putting more voltage through the 250, they can take 1.45v no probs, and was I was hoping to see you get 4, ah well.
__________________
Biostar TPower i45 e7300 3.57GHz (7x510) @ 1.32v (testing) with TRU120
2x1gb OCZ Flex PC9600 @ 1225 5 5 5 2.4v (testing) 512mb 9800GTX+ @ 840/2050/2500 (testing)
3dMark 06: http://service.futuremark.com/compare?3dm06=9564758
If you believe in Jesus Christ and are 100% proud of it, then put this in your sig
GeorgeStorm is offline   Reply With Quote
Old 30th Jun 2009, 14:08   #7
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
It's the way the MSI board works - the VDD is recorded as the actual, effective voltage, while the setting for "CPU vCore" is in fact an offset - and while that was set to 1.45-1.5V, the VDD is much lower. It's a bit convoluted and other AM3 boards are different.
It'll boot at 3.9/4GHz ~ish but it wasn't stable.
Bindibadgi is online now   Reply With Quote
Old 30th Jun 2009, 14:26   #8
trig
sweet sweet hangin joben
trig's Avatar
trig will become famous soon enough
wonder what the newer e6300 does...can it hit 4 ghz easily? how much would the extra bus speed improve its performance over the e5200? tell you what though, if i was starting from scratch, and only wanted a dual core rig, this amd chip would be the way to go. i doubt the 550 will give a 20% improvement in performance to justify the price. if it gives 10% more i'd be amazed. would anyone buy this or the 550 over the 720?
__________________
I love me some me e8400 @ 4.45 ghz..ac freezer 7..2 gigs patriot extreme 1150 mhz..abit ip35-pro..xfx 4770 with asus top bios @ 926 core/1077 memory..antec p182b..corsair hx620..seagate 500 gb 32mb cache THE best site ever...1600 signatures under the same avatar...time for a new one
trig is offline   Reply With Quote
Old 30th Jun 2009, 14:33   #9
Hustler
Multimodder
Hustler is on a distinguished road
I thought it was only the 550 which was a Black Edition with unlocked multipliers???........
Its the reason why i was ignoring the 250....until now.
Is it just as easy to overclock this as the 550 is?.
Hustler is offline   Reply With Quote
Old 30th Jun 2009, 15:00   #10
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
We didn't get one in time for the review However the E7400 we have hits 4.2GHz.
The 550 is £18 more now, and at only ~£72-£76 it's a lot cheaper than the 720 BE at £115ish.
Old 30th Jun 2009, 15:02   #11
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Black Editions are not the only ones you can overclock - all AMD CPUs can overclock using the HyperTransport bus, it just means the motherboard choice is more important. The 250s will overclock just as well as the 550 BE with the right mobo under it.
Old 30th Jun 2009, 16:49   #12
Dave_M
Minimodder
Dave_M is on a distinguished road
Take a look at the Athlon 5050e. I would say that would be a compeditor to the E5200. 5050e is cheaper and only a 45w CPU.
I would say get a 5050e or a Phenom 550 BE depending on who you are and what you are wanting to get out of it.
Dave_M is offline   Reply With Quote
Old 30th Jun 2009, 17:04   #13
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
5050e is little different from the 4850e - it's a K8 part still and the difference is considerable. There's no way a 5050 will reach in excess of 3.2GHz, whereas the 250 hits nearly 4 - plus, it has a two generation advantage in execution core.
Old 30th Jun 2009, 17:50   #14
Denis_iii
Hypermodder
Denis_iii's Avatar
Denis_iii will become famous soon enoughDenis_iii will become famous soon enough
which would be the best 790x/sb750 motherboard? the 790fx's are to pricey for me and i'd never use the onboard gpu.......
Denis_iii is offline   Reply With Quote
Old 30th Jun 2009, 17:58   #15
Ending Credits
It's the 790GX with the onboard GPU unless you mean you're discounting the GX series as well.
__________________
Old 30th Jun 2009, 18:02   #16
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
MSI 770-CD45 is good, the Asus Crosshair III Formula is quite cheap and there are a few GXs that are good value
Old 1st Jul 2009, 00:45   #17
perplekks45
BSc... finally
perplekks45's Avatar
perplekks45 is a splendid one to beholdperplekks45 is a splendid one to beholdperplekks45 is a splendid one to beholdperplekks45 is a splendid one to beholdperplekks45 is a splendid one to beholdperplekks45 is a splendid one to beholdperplekks45 is a splendid one to behold
Did I just miss it because I'm tired or did you not post any power consumption numbers for the overclocked CPUs?
__________________
"The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far."
Blame it on Cheaps! [now a social group]
perplekks45 is offline   Reply With Quote
Old 3rd Jul 2009, 22:25   #18
tictactoe
Modder
tictactoe's Avatar
tictactoe is on a distinguished road
Another plus point for AMD is that this CPU supports Hardware Virtualisation, where as the Intel E5200 does not. Suprised that this isn't mentioned!!
__________________
E6300(one of the OLD ones)(back to 2.80GHz ) II with an Arctic Pro 7 on top II 2x2Gb Corsair Twinx@ 400MHz II Sapphire 4850 512MB II Hitachi 320GB, Samsung 500GB and (external)Samsung F1 1TB HDDs II sitting on an Asus P5B Deluxe/Wi-Fi and wrapped in a TT Tsunami Dream (Black), with a couple of Noctua 120mm fans to help keep it cool. All powered by a Corsair 550W PSU. Now showing on a DGM 22" widescreen (1680x1050).
tictactoe is offline   Reply With Quote
Old 3rd Nov 2009, 15:10   #19
steveo_mcg
What owl?
steveo_mcg's Avatar
steveo_mcg has a spectacular aura aboutsteveo_mcg has a spectacular aura aboutsteveo_mcg has a spectacular aura about
Just bought one, first CPU i've bought in many years. Thanks for the review folks
__________________
No boom today, boom tomorrow... there's always a boom tomorrow.
steveo_mcg is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
