Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 30th Jun 2009, 16:01   #1
freedom810
Supermodder
freedom810's Avatar
freedom810 has yet to learn the way of the Dremelfreedom810 has yet to learn the way of the Dremel
WRT160N-UK Router! Grr!!
Hey all, so I bought a new Linksys WRT160N-UK router because my old one was getting low signal all the time. I don't know that much about networking just basic stuff so I need simple easy instructions if I get any replies
I go to the router by putting 192.168.1.1 in the browser and enter my details needed yet I get no response after its reset just dead unloaded internet pages. Ive included a pic below to show my settings. I also included a ping test. (I have no idea if it helps or not)
oh and I have tried different firmwares and they don't change a thing, I want a wireless network but have tried plugging my laptop into the router via ethernet and there is still no internet connection, the light on the router representing the internet isnt on. The wireless however is and works fine so it is a internet problem
LINK
Last point I would like to make is that its not my connection as I'm using my old router now (its just a bit slow) but the internet works fine on this, any ideas? Thanks
freedom810 is offline   Reply With Quote
Old 1st Jul 2009, 11:23   #2
freedom810
Supermodder
freedom810's Avatar
Nobdoy knows ahh
Old 1st Jul 2009, 14:03   #3
freedom810
Supermodder
freedom810's Avatar
Fixed, found out the router I got didnt have a modem, Doh! Anyway I'm using my old router as the modem and got it working now :|
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
