Reply
Thread Tools View Mode
Old 3rd Jul 2009, 12:59   #1
mrdbristol
Voided my warranty years ago
mrdbristol's Avatar
mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.mrdbristol is the Cheesecake. Relix smiles down upon them.
Purple Rain / CustomPC 'Readers Drives' - Issue 81 / Apr '10
Sponsored by ;
( www.tacens.com )
Tacens Ventus Ice 120mm fans
( www.techflex.com/prod_PTN.asp )
FlexoPet 'Uptown Purple' Braiding
( http://www.phenoptix.com/shop/ )
LED lighting supplies
http://www.chilledpc.co.uk/shop/index.php
(Chilled PC Aluminium Case Feet - 4 Pack - Black )
Hi all.
New build time, so welcome
Not sure how long this build will take, but it'll keep me busy anyway.
Nothing hi-tec in the hardware department, so attention to detail will be my main priority.
The Case :
Doesn't need an intro. , a MM U2 UFO.
Never worked with one before, so looking forward to it. Bit scratched at the moment, but not a problem.
The Colour :
Thanks to Craig / Madcat for the piccies.
Hoping to match the purple metallic finish in the above pictures by stove enamelling.
The Hardware :
Q6600
Asus Maximus Formula SE
4g OCZ Reaper
Nvidia GTX 285
Asus Xonar D2X
74g Raptor
500g Samsung F1
Watercooling :
Single loop - CPU, NB, SB, Mosfets + GTX 285
CPU Block - To be decided
Swiftech Komodo Water Block for gtx 285
D5 vario + EK top
Clear Dual bay reservoir
XSPC RX240 Radiator
XSPC R120-T Crossflow
Compression Fittings
White Tubing
Purple coolant
Smoked/Tinted Acrylic Windows.
Tacens Ventus Ice 120mm fans.
Stealthed DVD drive.
Stealthed Rheobus fan controller.
Possibly some custom Acrylic work inside, similar to my Dark Water build from last year, plus whatever else springs to mind along the way.
Thats the plan anyway.
Thanks for looking.
Mark
__________________
| i5 4670K | MSI Z87 - G45 Gaming | GTX 1070 | 16Gb GSkill Trident 2400 Mhz | Jonsbo MOD1 |
( Jan 17 ) : Elemental
( May 10 ) : Monolith
( Jan 10 ) : Purple Rain ( CustomPC - Issue 81 ( April '10 ) / MOTY '10 Nominee
mrdbristol is offline   Reply With Quote
Old 3rd Jul 2009, 18:48   #2
ry@n
Ultramodder
ry@n's Avatar
ry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysis
That colour is tasty :P Really liked your Dark Water project so this should be good.
__________________
Stacker 830 Evo //Core i7-920 ~ 4Ghz (4.2 stable) //Gigabyte EX58-UD5 //Corsair Dominator 6GB 1600Mhz //BFG GTX 285 OCX //BeQuiet! 750w //Samsung F3 1TB
DDC Ultra 18w //Black Ice 360mm //EK Multioption 250mm //Heatkiller LT CPU Block //MIPS RAM block
DDC Ultra 18w //Black Ice 240mm //EK Multioption 150mm //No Blocks yet
- Dual Loop i7 Stacker Left Handed? CLICK HERE -
ry@n is offline   Reply With Quote
Old 3rd Jul 2009, 22:42   #3
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
wow now thats a sexy colour! just took a look at dark water and if this is up to the same standard its going to be awesome...
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 5th Aug 2009, 23:24   #4
mrdbristol
mrdbristol's Avatar
Thanks for the comments
A few weeks have passed since i started, so time for an update.
The initial idea was to stove enamel the case in a metallic purple.
This proved an expensive idea !
The case would of needed to be stripped back to bare metal for the enamel to take. Bead/shot blasting would have twisted the panels, and chemical stripping was too expensive.
After a chat with the local powder coaters we decided on this colour. The best i can describe it as is 'Cadburys' purple.
Inside my front room :
As it wasn't raining for a change, i wheeled it outside for some shots ( not sure what the neighbours thought ! ) :
Close up of the colour :
So far, so good
Cheers,
Mark
__________________
Old 5th Aug 2009, 23:58   #5
mrdbristol
mrdbristol's Avatar
I knew the fans i wanted for this build - Black casing, white blades with white Leds.
Enter Tacens who very generously sent me 9 of their Ventus Ice fans for my build.
MM cases need alot of fans, so a huge thanks to Tacens for their support
Some pics of the beauties :
They ooze quality.
Whisper quiet whilst shifting alot of air ( I've been using 2 today plugged into my mobo as air conditioning as we've had some sun ! ) .
Great finishing right down to the black sleeving ( no thin fishnet stuff here ) and black fan plug :
Saves me sleeving 9 fans
Things are beginning to slot into place
Cheers,
Mark
__________________
Old 6th Aug 2009, 08:35   #6
DonT-FeaR
I know what a fk'n Dremel is ok.:D
DonT-FeaR has yet to learn the way of the Dremel
this is really cool but thats an odd colour :P
DonT-FeaR is offline   Reply With Quote
Old 6th Aug 2009, 08:58   #7
null_x86
Thread Closer
null_x86's Avatar
null_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysis
nice, cant wait to see whats going to be done with the MM UFO... doesnt it fit standard ATX?
__________________
XBL | Twitter
Nexxo - I thought the Catholic church had a time-honoured tradition of sodomy?
Cheapskate - @The beast - NAMBLA= Nasty Aged Men Banging Little An*ses
Korraz - That iPad vs Stone one is an insulting lie! I never expected to see something so mediocre as THIS an this holy thread! You disgust me! A stone HAS a Touchscreen!
null_x86 is offline   Reply With Quote
Old 6th Aug 2009, 09:00   #8
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
I like those fans
__________________
stonedsurd is offline   Reply With Quote
Old 6th Aug 2009, 09:26   #9
ry@n
Ultramodder
ry@n's Avatar
Never seen those fans before, is there a switch to turn off the LEDs?
At some point I want to do a project based on a MM case, great project!
__________________
Old 6th Aug 2009, 09:52   #10
null_x86
Thread Closer
null_x86's Avatar
I would so get a MM UFO case for my server, but I think my server wont fit cause of all the stuff in it lol
__________________
XBL | Twitter
Old 6th Aug 2009, 10:56   #11
mrdbristol
mrdbristol's Avatar
Don't see many purple cases around i agree, but i wanted something different
Those pics were taken in bright sunlight, so the colour isn't quite right. In normal daylight its darker. I'll get some 'decent' shots of it near the end of the build.
Yep, standard ATX mobo
No switch, the LEDS are hard wired to the fan.
Cheers,
Mark
__________________
Old 18th Aug 2009, 00:49   #12
mrdbristol
mrdbristol's Avatar
Update time again
Braiding, a neccessary part of any build.
But what colour ?
Black was too obvious. Purple would of been too much for my liking. So i set off to search for a mixture of both.
Techflex came to my rescue
Saw this braiding on their website and decided that it was perfect.
They very generously sent me a reel from America for this build, so a massive thanks to Techflex for their support.
120 foot of top quality braiding goodness.
Now the time consuming part
Braiding an entire PSU, Sata cables, molexes, fan extension cables...........the list goes on and on.
Old school braiding workshop ;
Stanley knife
Very small precision screwdriver ( for pin removal )
Lighter ( for heatshrink )
Insulting tape ( to wrap around the pins to stop snagging when threading through the braiding )
Purple Heatshrink
Many hours later, and very sore thumbs :
1 double Pci-E cable and a molex chain done......... Well, its a start !
Plenty more to keep me busy.
__________________
Old 18th Aug 2009, 00:50   #13
mrdbristol
mrdbristol's Avatar
A few pics of the build, as it stands.
New PSU ( Birthday present to myself ! ), Silverstone Decathlon DA850.
The next 2 show the fixings i am using ( simple screw covers ) as i was not keen on the look of thumbscrews, something different anyway.
Replaced the original silver switches with black vandal switches with white LED rings. (Will be fitting white 5mm LEDs in the 2 small holes)
Had a Fansis fan controller powdercoted at the same time, just need to change the 3mm LEDs from Blue to White to keep the theme going.
And finally the stealthed DVD drive ( test fitted - Will need to either spray the bare grey casing or hide it as you can see it inside ).
Thanks for looking, and any comments or critique are always welcomed.
Cheers,
Mark
__________________
Old 18th Aug 2009, 02:03   #14
null_x86
Thread Closer
null_x86's Avatar
nice job on the PSU sleeving, and purple heatskrink to boot, this is going to be good. Maybe purple coolant?
__________________
XBL | Twitter
Old 18th Aug 2009, 14:50   #15
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Nice colour, you don't see many purple cases around lol. I really like those fans, you got a link to the product page?
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 18th Aug 2009, 15:27   #16
mrdbristol
mrdbristol's Avatar
Thanks.
It takes time, but worth it in the end.
Yep, looking at purple coolant, mainly to show in the front dual bay res.
But i think i'll be using white tubing to match the fans and give it some contrast.
I agree, i went for purple to do something a bit different, and i think the colour has worked out well.
Its a bit tricky to get the colour photographed to the exact colour ( due to my camera skills ! ), but its very close to the bit-tech logo colour purple.
The fans are here : http://www.tacens.com/ > Products > Cooling
Cheers
__________________
Old 18th Aug 2009, 15:37   #17
The boy 4rm oz
Project: Elegant-Li
Thanks for the link .
__________________
Old 21st Aug 2009, 09:59   #18
The Twisted One
Minimodder
The Twisted One's Avatar
The Twisted One has yet to learn the way of the Dremel
Nice choice of purple there mate , and the sleeving has to be some of the best Ive seen .Pity i cant get quality stuff like that in N.Z. (BTW fan of Prince? )
The Twisted One is offline   Reply With Quote
Old 21st Aug 2009, 16:46   #19
mansueto
Too broke to mod
mansueto's Avatar
mansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyan
The color is awesome! I can't wait to see this progress!
__________________
Black Momba: i5 2500k @ 4.5ghz | Corsair H80 | MSI P67A-G43 | 16GB DDR3 1600 Ripjaws | 128GB Corsair M4, 1TB Barricuda | Gigabyte R9 380X | Asus PA248 IPS + Acer P243w | Asus Xonar D1 + Fio E07K Andes | Windows 7 Ultimate x64 | Seasonic X760 | Fractal R3 | Corsair Vengeance K70 w/ Browns | Razor Deathadder Chroma
Lenovo U410: i7 3517u | 8GB ram | 24GB + 750GB HDD | 14 inch ultrabook
mansueto is offline   Reply With Quote
Old 21st Aug 2009, 21:54   #20
stonedsurd
stonedsurd's Avatar
Good job on the sleeving
I gotta get my DA700 as soon as this month's check clears so I can get sleeved and then post up pics of my own (stagnating) mod
Aren't they great PSUs?
__________________
Reply
Tags
dark water, mod of the year 2010, mountain mods, purple rain, u2 ufo
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
