#1 |
What's a Dremel?
Good All Metal Case
Hello All
Quick Question. I'm looking to do a new build/mod and was wondering if anyone new of a good (somewhat inexpensive) case made completely of either steel or aluminum. Most are metal except for the front panel which is usually plastic. I would prefer an all metal case because plastic is harder to work with, and tends to limit modding to just painting. (at least in my case, more experienced modders probably don't have these issues.) |
#3 |
I Mod, Therefore I Own
Pretty much any Lian-Li case would work, but they're not too cheap. Mid-tower Li-Lis start at $86 on Newegg, but they're pretty much a blank canvas for modding.. Extremely solid construction and quality materials.
__________________
Intel i7-3820 @ 4.65GHz | HD 7850 | 4x4GB Vengeance | Asus Sabertooth X79
HAF XB | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet |
#4 | |
What's a Dremel?
Docodine: Thanks for the suggestion I will look into the lian-li cases. Anyone else know of any other cases? |
#5 | |
Is the daddy!
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
| Tags |
| aluminum, case, case mod, metal, question |
| Thread Tools | |
| View Mode | |
