Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 16th Jul 2009, 11:57   #1
pete*
Still a PC n00b after 3yrs.
pete*'s Avatar
pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.pete* is a hoopy frood who really knows where their towel is.
Suspected PSU dead... Could someone help?
Hey there,
A few months back I posted (on CPC forum I believe) about my PSU dying.. it was definately
dead so I sent it off to antec to be replaced - cost me £23 in P+P and no PC for a 2 weeks.
But anyway, its happened again!? But this time I don't quite understand why.
The last time, my PC was running and the PSU died on me... This time, the PC was turned off
the night before, shut down fine it wasn't over heating, running perfectly. Went to turn it on in
the morning and nothing. Absolutely nothing, no fan, no lights. The mobo tray green LED is on,
but I know that doesn't really mean much other than one small rail may be working...
The PSU is an Antec TP Quattro 850. Does anyone have any idea what it could be if it isn't the
PSU? I just don't understand why it would shut down fine, but then die over night? :s
But if not, what should I do? I've had this PSU for only about 3 months!! The last one lasted about 8
months... I'm starting to not trust Antec PSU's! I really don't think I want another 850W from
them... But this is really annoying me because I don't have the money to buy even a cheap
crap generic one (which I wouldn't anyway) and don't want to lose what I spent on this.
ARRGH! Anger
If anyone is able to help it would be much appreciated, Cheers
The spec I run is
Antec Twelve Hundred Case
P5Q Pro
Intel C2D E8400
4 GB Dominator 1066
Radeon HD4870 512mb
X-fi Ti Fatal1ty
2 x 1tb F1's
Cheap DVDDLRW
FC7
pete* is offline   Reply With Quote
Old 16th Jul 2009, 12:05   #2
Slizza
beautiful to demons
Slizza's Avatar
Slizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run CrysisSlizza can run Crysis
Obvious sillys first, try the fuse/another plug socket.
__________________
Case: HAF932 :PSU: 850W Corsair :Mobo: Asus Sabertooth Z77 CPU:I5 3570k @4.4Ghz
Memory: 8Gb Corsair 1866Mhz :64gb Crucial M4: 2x1Tb F3's :GPU: Nvidia GTX 570
Slizza is offline   Reply With Quote
Old 16th Jul 2009, 12:09   #3
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
You might have grounding issues like I did before! Take all of your components out of the case place the mobo somewhere like a carton or wood and check it. The other thing you can do is to power on the psu by shorting it but with the rest of your components on, like fans,cathodes etc.
Give it a try and let us know. On the other hand.... PC Power and Cooling for the win!
AnG3L is offline   Reply With Quote
Old 16th Jul 2009, 12:40   #4
pete*
pete*'s Avatar
Yea, i've tried turning it on by shorting the grnd/on connectors on mobo connector, absolutely nothing, no fan nothing.
This takes the piss rly. Think i'm gonna try findin another PSU power cable, if that doesn't work..
Dunno.
May have to email antec see what they say about two of their PSU's failing in the space of a
year. GRRRR!
Old 16th Jul 2009, 12:43   #5
SNiiPE_DoGG
Engineering The Extreme
SNiiPE_DoGG's Avatar
SNiiPE_DoGG has yet to learn the way of the DremelSNiiPE_DoGG has yet to learn the way of the DremelSNiiPE_DoGG has yet to learn the way of the Dremel
get a 3rd one, ebay it/sell on forums, buy a corsair = happy ending
__________________
[Project] :::Mil-Spec::: @ Bit-Tech
[Project] :::Flow::: @ Bit-Tech MOTY Second Prize
|CPU: PHII 955 BE @ 3.8ghz | GPU: 2 x 4890 XXX @ 950 | 8gb Crucial ballistix tracer DDR3 1600 CL8|
SNiiPE_DoGG is offline   Reply With Quote
Reply
Tags
antec, blown, dead, psu, unreliable
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
