Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 21st Jul 2009, 22:16   #1
Sheiken
Wat?
Sheiken's Avatar
Sheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the Dremel
Using networked vista printer in os x !
Hi guys, I have spent the last 45 minutes or so trying to get my unibody macbook to find and recognize the hp laserjet 2605 printer which is shared on my windows vista server, and my attempts have yet to be successfull...! I need your advice!
Name of vistaserver : vistaultimate
Name of shared printer : Laserjet
I have also tried installing the lpd printserver package for vista, but didnt work either...what am I doing wrong?
Sheiken is offline   Reply With Quote
Old 22nd Jul 2009, 00:02   #2
null_x86
Thread Closer
null_x86's Avatar
null_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysisnull_x86 can run Crysis
/snip what am I doing wrong?
1) vista and server in the same sentence, no less the same word/phrase
2) Vista
ok now to help you..
1) different OS choice
2) If there are drivers for the printer in OSX, get them and install them in OSX, then try to set it up.
__________________
XBL | Twitter
Nexxo - I thought the Catholic church had a time-honoured tradition of sodomy?
Cheapskate - @The beast - NAMBLA= Nasty Aged Men Banging Little An*ses
Korraz - That iPad vs Stone one is an insulting lie! I never expected to see something so mediocre as THIS an this holy thread! You disgust me! A stone HAS a Touchscreen!
null_x86 is offline   Reply With Quote
Old 22nd Jul 2009, 00:25   #3
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
Have Mac OS drivers of your printer installed on your Mac system, then add the printer from the network.
What you did is technically correct if it was Windows to Windows as Vista (win7 also), will send to the other computer the drivers and install it automatically and then add the printer for you.
As Windows and Mac OS are well different OS and works differently, Windows can't feed to the Mac OS, Windows drivers of your printer.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is online now   Reply With Quote
Old 22nd Jul 2009, 00:30   #4
null_x86
Thread Closer
null_x86's Avatar
Originally Posted by GoodBytes View Post
Have Mac OS drivers of your printer installed on your Mac system, then add the printer form the network.
QFT
__________________
XBL | Twitter
Old 22nd Jul 2009, 16:43   #5
Sheiken
Wat?
Sheiken's Avatar
I already have the osx drivers installed on my mac and when I choose the printerdriver from the drop-down menu I choose the right ones, the problem seems to be the connection?
Old 22nd Jul 2009, 17:11   #6
null_x86
Thread Closer
null_x86's Avatar
make sure the connections are solid are fully inserted, is the "vistaserver" or lan or wlan?
__________________
XBL | Twitter
Old 22nd Jul 2009, 17:46   #7
Sheiken
Wat?
Sheiken's Avatar
the server is connected to my router via lan as is my xbox, and my macbook is on my wlan, but I can easily connect to my server when using the "connect to server" function in finder, and browse my shared folders, its just the damn printer!
Old 22nd Jul 2009, 18:21   #8
null_x86
Thread Closer
null_x86's Avatar
check the sharing on the printer itself on your "server" box, that is most likely to be the cause
__________________
XBL | Twitter
Old 23rd Jul 2009, 15:44   #9
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
2) Vista
Elaborate, please.
__________________
Intel Core i5 3570K @ 4.5GHz || Thermalright Ultra 120 eXtreme || Gigabyte GA-Z77-D3H || 2x 8GB Corsair Vengeance LP DDR3 1600MHz CL10 || Radeon 4870 512MB || AC Accelero Twin Turbo Pro || Asus Xonar DX || Samsung 830 128GB || 2x WD Blue 640GB || Corsair HX620 || Antec P182 || Samsung SM 2232 + 2233 || Windows Server 2012
mm vr is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
