Old 25th Jan 2010, 16:21   #321
Draxin
Seeker of Photons
Draxin's Avatar
Draxin has yet to learn the way of the Dremel
Originally Posted by Jumeira_Johnny View Post
Do you have a filter on the front of your lens? it looks like internal reflections.
AH!
i have the UV 0 on the front of my 50mm 1.2L for "protection"
i always forget to take that off when i shoot at night.
thank you for helping me realize the obvious.
Draxin is offline   Reply With Quote
Old 25th Jan 2010, 20:37   #322
Fod
what is the cheesecake?
Fod's Avatar
Fod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run Crysis
Just leave it off. Filters do nothing for protection that a hood won't do.
__________________
"This face is left intentionally blank."
XBL/PSN/Steam ID: FodT
Fod is offline   Reply With Quote
Old 25th Jan 2010, 20:46   #323
GregTheRotter
I Mod, Therefore I Own
GregTheRotter's Avatar
GregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for presidentGregTheRotter should be considered for president
Said the man who hadn't been shooting stuff like this;
While I am starting to feel that filters are just there for peace of mind, they do have their time and place. In the shot I posted above, there was a lot of wind, and I was often having to wipe the salty sea spray off the filter. Obviously for just about any other situation you might not need one.
On the other hand, hoods can sometimes draw added attention, or just might not be convenient to carry around. It's just a case of whether you've got money to blow on a pro grade filter (I use the Hoya Pro1 D filters, and I can't see any difference). Obviously if you notice you're getting flare, and you happen to have a filter on, then it's common sense to remove it.
Ok, I'll stop rambling xD In any case, I've stopped buying them The only lenses that I have one on at the moment are my 24-70,70-300VR,35mm F2D, and 85 1.8D. Lenses without; 50 1.8D, 135 f2.8 AI-S, 55mm F2.8 Micro Nikkor AI-S and 180 f2.8 AF-D.
__________________
Main rig: i7 920, 12gb 1600mhz ram @ 1333mhz, Asus P6T Mobo, Crucial m4 128gb SSD as OS disk, Samsung 1tb F1, 2x1tb F3 as storage, 1xSamsung F4 2tb, Creative X-FI Fatality pro soundcard,2 x EVGA GTX 670 in SLI, Dell U2711, Nec 20WGX2.
Photography gear; Nikon D700, Nikon 16-35 F4 VR, Nikon 24-70 AF-S, Nikon 70-200 F2.8 VR II, Nikon 35mm F2 D,Nikon 50mm 1.8D, Nikon 85mm 1.8D, Micro Nikkor 105 f2.8 AI-S, Nikon SB-800, SB-900,
GregTheRotter is offline   Reply With Quote
Old 26th Jan 2010, 16:41   #324
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.mars-bar-man is the Cheesecake. Relix smiles down upon them.
I pointed and clicked....it's blurry
__________________
Bewbs.
mars-bar-man is offline   Reply With Quote
Old 26th Jan 2010, 16:41   #325
mars-bar-man
Side bewb.
Double post >.<
__________________
Bewbs.
Old 26th Jan 2010, 17:09   #326
teamtd11
*Custom User Title*
teamtd11's Avatar
teamtd11 has yet to learn the way of the Dremelteamtd11 has yet to learn the way of the Dremelteamtd11 has yet to learn the way of the Dremelteamtd11 has yet to learn the way of the Dremelteamtd11 has yet to learn the way of the Dremel
teamtd11 is offline   Reply With Quote
Old 26th Jan 2010, 17:45   #327
Fod
Fod's Avatar
yes well, of course in *very specific* situations they're needed! even i put filters on at the beach!
Fantastic shot btw!
__________________
Old 26th Jan 2010, 19:46   #328
Lynx
Hypermodder
Lynx's Avatar
Lynx has yet to learn the way of the Dremel
#1
#2
Lynx is offline   Reply With Quote
Old 26th Jan 2010, 19:56   #329
bigkingfun
Tinkering addict
bigkingfun's Avatar
bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.
@Greg I really like that one, the sail details are so sharp.
bigkingfun is offline   Reply With Quote
Old 26th Jan 2010, 21:27   #330
Tim S
Padded Up
Tim S's Avatar
Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!Tim S - it's over 9000!!!!!!!!1!1!1!!!
Tonight's sunset was ridiculously red/purple. Just a shame there wasn't a cloud in the sky (and I was sat in an office in London)!
__________________
Global Technical Marketing Manager @ ASUS
ASUS on Facebook | Tech in Style | Republic of Gamers
ASUS Tech Support | Global Tech Support Helplines
Tim S is offline   Reply With Quote
Old 26th Jan 2010, 21:50   #331
Vers
Vers's Avatar
Vers has yet to learn the way of the DremelVers has yet to learn the way of the Dremel
I didn't take these today, but I finally got around to editing them today
__________________
1DIII, 5DIII+BG-E11, 40Dx2, Tamron 17-50, Canon EF-S 17-85, 16-35L, 70-200L f/2.8 IS, 100-400L IS, 35L, 50 f/1.4, MP-E 65, 85 f/1.8, Sigma 150 Macro, 580EXIIx3, Giottos MT 9360+MH1001 Ballhead & MH658 QR system
flickr
TheSite//TheBlog//TheBook
Vers is offline   Reply With Quote
Old 27th Jan 2010, 03:39   #332
fabler
Supermodder
fabler's Avatar
fabler has yet to learn the way of the Dremel
@Vers
Cool Shots man..
__________________
Game on James Bond 007 on Xbox 007
a.k.a stalker.
owned a google nexus one.
fabler is offline   Reply With Quote
Old 27th Jan 2010, 12:04   #333
Draxin
Seeker of Photons
Draxin's Avatar
Made it up to Griffith Observatory last night.
here are a few of my favs. (no photoshoping, but exposure, contrast, rotation, and color correcting were done to various images in Aperture) (full set HERE
(oh and Jumeira_Johnny I remembered to take my UV 0 filter off this time and behold no reflections, thanks for helping me figure that one out)
Old 27th Jan 2010, 12:07   #334
fabler
Supermodder
fabler's Avatar
@Draxin
No Photoshopping. Its great.. good shoots by the way..
__________________
a.k.a stalker.
Old 27th Jan 2010, 13:07   #335
Draxin
Seeker of Photons
Draxin's Avatar
I HATE photoshop.
As far as I am concerned Photoshop has killed (honest) photography.
too many people take "meh" pictures and then spend hours in photoshop to make them "WOW". The only time I personally feel its ok to photoshop a picture is if its one of those once in a lifetime shots and there are just a few things you need to tweak
Old 27th Jan 2010, 13:16   #336
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
I believe a little post-processing is more than okay, especially for professionals whose livelihood depends on their pictures.
That aside, your stunning (non-PP'ed) shots have earned you rep. I am in awe of your skill.
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is offline   Reply With Quote
Old 27th Jan 2010, 13:17   #337
Tim S
Padded Up
Tim S's Avatar
Here's one I made earlier this morning...
Almost straight out of camera. I used an ND grad 0.9 HE filter and deliberately set a low whitebalance to enhance how cold it was this morning. I made minor colour/saturation adjustments running a fairly standard action that I use on most of my landscapes. That was all that I had time for before heading to work and (frankly) all that was required.
__________________
Old 27th Jan 2010, 13:23   #338
Tim S
Padded Up
Tim S's Avatar
Originally Posted by Draxin View Post
I HATE photoshop.
I agree with you about post processing for the most part - I believe it's fine to use it in the way that photographers used to use tricks in the darkroom, but anything beyond that moves it away from photography into the realms of digital art or image manipulation.
The only PP I do is to enhance the original image... never to salvage. I'm not big on Photoshop myself (mainly because I don't have the time or inkling to learn it properly) and, aside from a few actions designed to improve colour saturation and contrast a little, I don't touch the image outside of Lightroom's standard set of adjustments.
__________________
Old 27th Jan 2010, 13:24   #339
supermonkey
Deal with it
supermonkey's Avatar
supermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpit
I HATE photoshop.
I understand the sentiment, but the whole "purist" photographer thing is of the mark, in my opinion. Although you've proudly hailed the purity of your photos by stating that there was no "photoshoping," you then went on to state that you adjusted exposure, contrast, rotation, and color - you just used a different program.
I do agree that every effort should be made to do as much work in camera as possible, I fully disagree that "photoshoping" is an evil modern concept destroying honest photography. Much of what people do in Photoshop (or Aperture, or Pain.net, etc.) comes straight from the darkroom.
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song.
-J.R.R. Tolkien, The Silmarillion
supermonkey is online now   Reply With Quote
Old 27th Jan 2010, 14:28   #340
Tim S
Padded Up
Tim S's Avatar
That's the stuff I think is acceptable - anything beyond that is what I don't (personally) agree with. Changing a photo into something that doesn't resemble the original is, generally speaking, what I don't believe in. Others may well believe in it and they're more than welcome to have their own opinion.
It's the same for HDR - I've dabbled with it using bracketed exposures, but I have never found it creates something that looks real enough for me. To me, photography is all about compromises (when you're behind the camera) and visual tricks when you're in the darkroom, be it one in the traditional sense or a digital one, to enhance the image in a way that captivates the feeling you had at the time you pressed the shutter release.
This is probably worthy of its own topic because I think it's a good (and very valid) discussion.
__________________
Reply
Tags
no skimlinks, stonedsurd? hell yes!
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
