#21 | |
Is a cackling Yuletide Belgian
Okay, I've done a lot, just waiting for daylight (tomorrow) to take decent pics.
Here's some of the top I/O plate (this is just the mount - lots of Araldite and two bolts holding it together), cable cutouts in the mesh and the powdercoated parts that I've received thus far. Top I/O (yes, it will end up looking much neater ):![]() Mesh: ![]() Closer look: ![]() Parts all lined up (excuse the noisy pictures, my camera sucks donkey nuts): ![]() With flash: ![]() Top panel: ![]() 'Citadel'-esque side panel thingy: ![]() Left side panel: ![]() Right side panel: ![]() More as I have it.
__________________
My Flickr
#22 | |
Actually, cityscape-panel-acrylic sandwich
![]() Yep
__________________
My Flickr
#23 | |
Ok, tonight's update - everything is ready for the powdercoaters. I just finished the last of the place-testing of the hardware and everything fits as it should, unless I missed something (which, sadly, is very likely because I have a memory like a sieve).
All fitted up, minus a PSU :![]() Obviously, the pump isn't going to sit like that - it'll be isolated using rubber bushings or cured rubber slabs. And it's not really visible, but the hose going from the radiator to the reservoir needs a little trimming (to cut some slack, as it were ):![]() Artsy shot :![]() Ah, that last picture has no noise! ![]() More tomorrow
__________________
My Flickr
#24 | |
Thanks for the view and the comment AnG3L. I was beginning to despair
![]() That fillport actually serves as a drain port. The first time I messed with WC'ing (someone else's rig) the one thing I noticed was that draining/cleaning a loop is a royal pain. So I'm determined to keep it simple and neat in my own first attempt.
__________________
My Flickr
#25 | |
Powdercoated stuff arriving tomorrow. Looks like this one's going to be down to the wire.
Stuff left to do: 1. New PSU (my DA700 has not yet been delivered )2. Cut and paint the mesh shelf to accommodate the tubing/fittings - has to be done tomorrow because the chassis is at the powdercoater's 3. Put it together and fill up the loop ![]() This is going to be down to the wire (I fly back to univ on the 25th morning )Anyway, I did some final touch-ups and the like. Found the aluminum faceplate for the front I/O ports, so that if getting stuck onto the ex-ghetto I/O plate. Painted the mesh that holds up the res and got some rubber slabs for some SERIOUS vibration-isolating pump mounting ![]() Mesh: ![]() The rubber slabs - this is the rubber that's fed into dies before being squished into stuff like o-rings, bushings and such: ![]() They're all between 12-13mm thick, except one which is 5mm: ![]() When you stack them up like this: ![]() You get a pretty neat (if slightly untidy) pump mount! ![]() And here's a shot of a lot of clampage getting the I/O ports epoxied up: ![]() One more update tonight (when the clamps come off). Then the finale tomorrow. Hopefully I can get it wrapped up in 24-odd hours
__________________
My Flickr
#26 | |
Last update before I crash.
I forgot, I got a bunch of M6 socket head bolts for the switchplate. Also, the top I/O plate is done. Switchplate: ![]() And again, for kicks :![]() I/O plate: ![]() Now what I would like to know is this - the I/O plate has some obvious scratches, along with being upside-down when mounted. Should I leave it as it is in the pictures or just give it a couple of coats of black? I'm not really fussed about getting rid of the markings - they're for n00bs anyway
__________________
My Flickr
#27 | |||
Thanks!
Thanks!Quote:
Anyway, I am working to put everything together. The clock is ticking. Here are some pics while the rad and block get a little vinegar bath. Chassis back from powdercoaters: ![]() ![]() ![]() ![]() ![]() Front panel: ![]() ![]() ![]() I/O masked before being sprayed: ![]() New power supply (CM Silent Pro M600): ![]() ![]() I think an update or two from now I'll be done
__________________
My Flickr
#28 | ||
Thanks! But I'm still a bit bummed that the DA700 STILL HASN'T REACHED!
Thanks! But on the other hand, I epic failed. Had to leave for Univ with the whole thing put together, looking fine and all that, but the loop was left unfilled because I simply did not have the time. Hopefully will get this completed over winter break.
__________________
My Flickr
#29 | |
Right, just thought I'd let you folks know that I've resumed work on this. I was in the middle of partially dismantling the rig when I realized that my last update had been woefully inadequate in terms of pictures. So here are a few for those of you who are curious to see what she looks like.
![]() ![]() ![]() ![]() ![]() ![]() This last one if a bit of a dodgy stitch I tried of the previous two images. ![]() I'm currently in the process of getting another power supply and making a new hex mesh bottom partition, not to mention trying to lay me hands on another side panel so I can try not to frak the whole thing up again :P Also, UV and red CCFLs are gone, going to get some SMD LED strips instead
__________________
My Flickr
#30 | |
Obviously I lied when I said this would take me a week to wrap up.
Besides that pesky annoyance known as 'real life' coming in the way, I was also basically just lazy. Anyway, I got my PSU today after a lot of shilly-shallying on my part. That was all the impetus I needed, so I got down to sleeving Removing the wires from the 8-pin connector: ![]() One set of wires removed: ![]() All done: ![]() Injuries of teh day: ![]() ![]() Sunbeam really needs to watch the safety of their tools. Chock-full of sharp edges tearing my hands up ![]() Also daisy-chained my rad fans so I wouldn't have to deal with a ton of extra cables: ![]() That's all folks - will try and be more regular from now on
__________________
My Flickr
#31 | ||
Thanks Rakesh!
__________________
My Flickr
#32 | |
Waterblock (not really an update)
Got the waterblock for my 5870, will mount it up as soon as I get the card off the LN2 bench
![]() ![]() ![]() ![]() ![]() ![]() Yes, I know this hardly counts as an update but I need to keep this worklog alive
__________________
My Flickr
#33 | |
Hey, thanks Ash! Glad you like it
__________________
My Flickr
#34 | |
More 'almost-updates' to keep the worklog going.
Did some more sleeving yesterday because I found some heatshrink in a box (I thought I'd run out and placed an order at MDPC-X to replenish supplies )Anyway, pics. 4-pin molex cable. It had 3 molex 4-pin connectors and one floppy power connector: ![]() It got the chop because all I needed were two connectors: ![]() Removing the pins: ![]() Ended up with this: ![]() And a bunch of other sleeved cables (4-pin molex, 6-pin PCIe and 8-pin EPS): ![]() More updates soon (promise - I'm near the end now, and I'm not faffing about )
__________________
My Flickr
#35 | |
Thanks man. I just wrapped up the 24-pin cable, but too tired to post pics (it's 2am).
Will update tomorrow!
__________________
My Flickr
#36 | |
Right, so I promised another update and here it is.
I got more heatshrink, a crimping tool and a bunch of male/female and fan pins from MDPC-X. Muchos gracias to Nils for throwing in some extras ![]() Cartoon, as usual ![]() ![]() Fan pins ![]() ATX/EPS male pins ![]() ATX/EPS female pins ![]() Crimping tool (it really gives a perfect crimp!) ![]() Same tool with jaws open ![]() Heat gun. I left my other one in LA and doing big heatshrink with a lighter is a colossal pain in the rear. ![]() And the sleeved 24-pin cable (finally!) ![]() I'll probably be done by the weekend (with a temporary side panel, while I keep badgering CM to get replacement side panels to India).
__________________
My Flickr
#37 | ||||
![]() Quote:
![]() EDIT: Looking at the 24-pin cable is pissing me off. I think I'm going to redo it and sleeve each wire all the way.
__________________
My Flickr
#38 | ||
![]() Just used 38feet of black sleeving on the wires and there are 10 left to do. Should have measured before starting. Now I have to order AGAIN from MDPC. I really need to plan this stuff out better. Thanks b4Oz Good to see you posting again!
__________________
My Flickr
#39 | |
![]() Good timing on the revival though. I'll get working on it tomorrow as I'm home sick with some sort of evil mutant flu. Plans have changed drastically, however, as I cannot justify sinking tons of cash into this given that I spend no more than 2 months of the year in India and am unlikely to return to this home once I'm done studying. I will just complete the loop with a 240mm radiator and leave it at that.
__________________
My Flickr
| Tags |
| haf 932, mod, stonedsurd, styx, watercooling |
| Thread Tools | |
| View Mode | |
