Old 3rd Aug 2009, 03:53   #1
Gooey_GUI
Wanted: Red Shirts
Gooey_GUI's Avatar
Gooey_GUI has yet to learn the way of the DremelGooey_GUI has yet to learn the way of the DremelGooey_GUI has yet to learn the way of the DremelGooey_GUI has yet to learn the way of the DremelGooey_GUI has yet to learn the way of the DremelGooey_GUI has yet to learn the way of the DremelGooey_GUI has yet to learn the way of the Dremel
Gooey_GUI is offline   Reply With Quote
Old 3rd Aug 2009, 04:46   #2
Volund
Am I supposed to care?
Volund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run Crysis
for tri-sli it is a double wide, slightly lengthened bridge, like this one-
they seem to be only offering the standard 1 bridge for regular SLI
alternately, if you have some short bridges and a long flexible one lying around, you can make a ghetto connector like this-
__________________
Current System- XFX 780i SLI Mobo, Sapphire HD4850, Q6600, 4GB RAM, 2xSamsung F1 1TB, Corsair 850HX, Lian-Li A05NB, W7 Ultimate x64
If you believe in GLaDOS and are 100% proud of it, put this in your sig
Volund is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
