Reply
Thread Tools View Mode
Old 6th Aug 2009, 19:58   #1
vils
Multimodder
vils's Avatar
vils has yet to learn the way of the Dremel
Project Facit, Intel inside! New sponsor, 1st April.
I had an old electrical typewriter from the Swedish manufacturer Facit at home for the kids to play with.
It was a huge 40 pound heavy mechanical wonder, its die cast aluminium shell crammed with springs, levers and other components. It looked like this:
A couple of years ago I made a mod called "All work and no play" and I missed the wonderful feeling of creation so some while ago I snatched the kids typewriter and began planning.
First of all I disemboweld the machine, 18 pounds of complicated metal parts ended up in a "good to have" box.
I decided to make room for a regular PSU a MATX mobo, one or two HDD's and a slim-lin slot in DVD.
Things have moved slow since then, but now the basics are done.
Here are the lower part of the shell, with the DVD slot visible:
Lower system tray with PSU holder, grommet mounts for HDD, hacked fan and thick metal slab for DVD mount:
Mobo tray in place:
Interior mounted in shell with anti vibration grommets:
The part that so far have caused the most headache:
Front mounted:
Keyboard and roof in place:
Last major part mounted:
There are as you can see many things to work with in this project but for the first time I can really see this coming to an end.
The rectangular hole to the left of the KB I will have a "glowing letter" indicator for HDD activity, caps lock, num lock and so on.
I will propably have the case powder coated to replicate it's original finish.
One of the reasons for all the time this have taken is that it's really is a zero budget project.
I have used scrap material and leftovers. I have bought some metal filled epoxy, some screws and the anti-vibration grommets.
The two most expensive parts so far is a rubber silenced HFX DVD drive I picked up on a sale and the refurbished SMK-85 keyboard.
It will propably continue to be zero-budget in the near future so every steps that require cash will have to wait.
Last note: sorry for the whitebalance in the pics, I will try correct this later on.
Thank you for looking!
vils is offline   Reply With Quote
Old 6th Aug 2009, 20:55   #2
Monkey Puzzle
Multimodder
Monkey Puzzle's Avatar
Monkey Puzzle has yet to learn the way of the Dremel
Looks very nice so far. Would look nice and authentic imo if you could colour a few keys red as for the original.
Monkey Puzzle is offline   Reply With Quote
Old 6th Aug 2009, 21:12   #3
vils
Multimodder
vils's Avatar
Thanks! I have saved all old keycaps and I'm working on a way to use them on the ALPS switches... very complicated with spacing issues, but couloring some red could be a way to go.
Old 6th Aug 2009, 21:18   #4
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
I like this a lot!
I watch.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 6th Aug 2009, 22:29   #5
woody_294
Wizard Ninja :P
woody_294's Avatar
woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.
+1 Red keys would deffo look good. Looks good keep it coming man!
__________________
X3 720 BE @3.5GHz - MSI 790FX-GD70 - XFX 4870 XXX @ 795/995 - 4GB Corsair XMS3 1333MHz
http://www.cpcff.co.uk
Project λ-Zephyr
woody_294 is offline   Reply With Quote
Old 7th Aug 2009, 01:09   #6
vils
Multimodder
vils's Avatar
I'll just add some more info:
The mobo-tray and bottom tray are made of 3mm thick aluminium, the distance between them are 30mm.
Between the mobo-tray and "ceiling" the clearance is just over 120mm.
The "lid" over the interior is made of two sheets of 2mm aluminium epoxied together, strong enough to let a TFT to stand on.
The keyboard is as said a SMK-85 with Strongman/ALPS switches wich have a distinct clicky sound. I think this goes well with the machines origin.
I will definitly try to adapt the keycaps so that they blend in even more.
Thanks for the feedback and don't hesitate to ask questions, I'll answer them as swift as I can.
Old 7th Aug 2009, 07:23   #7
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on you
Typwriter cheesecake! Love 'em.
subbed
__________________
stonedsurd is offline   Reply With Quote
Old 7th Aug 2009, 23:38   #8
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.
That is slick.
Where's the paper go?
Cheapskate is offline   Reply With Quote
Old 8th Aug 2009, 05:24   #9
Krog_Mod
Supermodder
Krog_Mod's Avatar
Krog_Mod has yet to learn the way of the DremelKrog_Mod has yet to learn the way of the DremelKrog_Mod has yet to learn the way of the DremelKrog_Mod has yet to learn the way of the Dremel
Originally Posted by Cheapskate View Post
That is slick.
That would be really interesting if he could somehow work a printer into this as well.
Krog_Mod is offline   Reply With Quote
Old 8th Aug 2009, 07:49   #10
vils
Multimodder
vils's Avatar
I have test installed an old (unusally small) mATX mobo and a dead PSU to clarify the layout:
The installed mobo is only 190mm deep, but there is room for the standard 244mm as you can see.
I suppose it would be possible to squeeze in a small printer as well, especially if I had choosen a ITX solution with a PicoPSU. But this will be my main rig so I prefer power instead of the printer, wich would be more of a gimmic.
BTW, my last mod had some typewriter theme too:
This is unfortunatly a unlit comp pic, I had the log hosted a the now late systemcooling.com and most of the pics are lost.
Old 8th Aug 2009, 16:22   #11
Cheapskate
Cheapskate's Avatar
Nice window idea.
Old 8th Aug 2009, 22:34   #12
Monkey Puzzle
Multimodder
Heh, is that a dead Hiper PSU?
Old 9th Aug 2009, 06:28   #13
vils
Multimodder
vils's Avatar
That's right, dead 580w Hiper.
Old 15th Aug 2009, 11:54   #14
Kumo
Hypermodder
Kumo's Avatar
Kumo has yet to learn the way of the Dremel
Nice work as usual, Vils. Nice to see you in action again.
Kumo is offline   Reply With Quote
Old 15th Aug 2009, 13:39   #15
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
You need to mod a portable printer into that asap!
__________________
Project log Mocha70
Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2
Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 2nd Sep 2009, 20:28   #16
vils
Multimodder
vils's Avatar
I have worked hard the last two weeks in my not too abundent spare time with epoxi and sanding. Pics will arrive when I'm finished with this stage.
My first idea was to powder coat the case with a colour that is close to the original finish, after speaking to some powdercoaters I think I'll have to abandon this idea.
The epoxi I have used will propably not withstand the 220 d C baking temprature for powder coat.
I have thinked about using a dark metallic gray hammer finish paint from rust-oleum. Unfortunatly this paint seems to be unavailable in the EU and they, so far, don't answer my e-mails.
Another option is to take the case to a car painter and give it a mirror finish dark grey.
But I'm really uncertain about wich finish to strive for, ideas are very welcome.
Old 20th Sep 2009, 03:32   #17
perkins teh modder
Multimodder
perkins teh modder's Avatar
perkins teh modder has yet to learn the way of the Dremel
hey, how'd you get the writing on the window? is all that etched?!
__________________
sorry for bad english, im from america
perkins teh modder is offline   Reply With Quote
Old 20th Sep 2009, 08:07   #18
vils
Multimodder
vils's Avatar
It's laser engraved. Can't remember wich company that made it.
Old 20th Sep 2009, 15:24   #19
Combinho
Ten kinds of awesome
Combinho's Avatar
Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.Combinho is a hoopy frood who really knows where their towel is.
That typewriter is looking very nice. I look forward to seeing it completed.
__________________
"[The World Wide Web is] the only thing I know of whose shortened form — www — takes three times longer to say than what it's short for." - Douglas Adams
Battlefield 3: Combinho Steam: Combinho
Combinho is offline   Reply With Quote
Old 28th Oct 2009, 19:28   #20
vils
Multimodder
vils's Avatar
My connection is for the moment horribly bad, I'll just post some pics and comment later.
Reply
Tags
aluminium, matx, scratch build, typewriter
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
