Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 17th Aug 2009, 07:05   #1
eric_r
Minimodder
eric_r has yet to learn the way of the Dremel
Dell U2408WFP or U2410 Inquiry
Hi folks, it's been a long time since I've last posted.
I have a fairly urgent advice request, as Dell currently have a $200 discount on the U2408WFP ($749 sale price) ending on the 20th of this month, and obviously I would like to take advantage of it if I go down that track.
I currently have a 22" Asus TN panel, and after upgrading my graphics cards to Crossfire, I feel I'm not getting my money's worth on my current panel. After doing some research, I've created a dilemma for myself, as I can't decide on a panel.
My main question is this: After noticing the Dell U2410 Ultrasharp, which is available here in Aus through their small business arm for $899, and has an IPS panel, would someone like myself who has never used a high end display get any added benefit out of it over the U2408WFP?
Primarily it would be used for games, movies (SD and HD), with a small amount of graphic design/photography work also. The price of the U2410 is a bit of a stretch, admittedly, so it would need to be a substantial improvement over the cheaper model.
I realise there's a lot of info available on the U2408, but I've found it difficult to determine if it's a good panel for gaming, or whether it's better suited to graphics work. Also, I don't have enough time before the 20th to understand the ins and outs of the different panel types - something which has already done my head in .
Thanks for your replies.
Edit: links for easy viewing
http://www1.ap.dell.com/au/en/busine...=bsd&cs=aubsd1
U2410
U2408WFP
eric_r is offline   Reply With Quote
Old 17th Aug 2009, 07:42   #2
hotnikkelz
Supermodder
hotnikkelz has yet to learn the way of the Dremel
i got the dell 2408 for 350 US....seek another place to purchase it
hotnikkelz is offline   Reply With Quote
Old 17th Aug 2009, 07:50   #3
eric_r
Minimodder
Aussie prices are screwed up for some things. The HP LP2475W is available on Newegg at current exchange rates for ~$650AUD, but it's going for a minimum of $1125AUD....
As far as I know, Dell in Australia is currently only available from Dell directly, or through Officeworks - no luck in getting it cheap from an etailer, unless things have changed.
Thanks for your post.
Old 17th Aug 2009, 08:54   #4
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
I thought the U2410 was only for the Japanese market?
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 17th Aug 2009, 08:58   #5
tominated
Supermodder
tominated's Avatar
tominated has yet to learn the way of the Dremel
Get the u2410 over the 2408wfp. it's a similar price for a much better monitor. you have an led backlit (i think), IPS monitor. much better than ccfl backlit pva
tominated is offline   Reply With Quote
Old 17th Aug 2009, 09:01   #6
bigsharn
Officially demotivated
bigsharn's Avatar
bigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysis
What happened to the Dell U2409WFP?
__________________
{Rolling on a 1990s Dawes Galaxy}
{Nikon D80, 18-55 f/3.5-5.6G and 50mm f/1.8}{Lomo Smena 8M}{Olympus OM10, 50mm f/1.8, 28mm f/2 and 135mm f/3.5}
bigsharn is offline   Reply With Quote
Old 17th Aug 2009, 10:30   #7
eric_r
Minimodder
Yeah, I'm tempted to fork out the extra cash at the moment. My only gripe is the lack of thorough reviews, but I suppose the IPS panels in HPs and NECs tend to rate highly so I shouldn't be too worried.
About the availability of it, I'd say that since Aus falls under Oceania and it would be available in other parts of Asia, we have access here?
Before I take the plunge, if you guys and gals were in my position, is there anything else I should know, especially drawbacks of the IPS technology?
I appreciate all the replies.
Old 17th Aug 2009, 10:56   #8
azrael-
I'm special...
azrael-'s Avatar
As far as I know the U2410 hasn't got an LED backlight, but just a wide gamut CCFL. The IPS panel should be a lot better than the PVA panel, though.
__________________
Old 17th Aug 2009, 13:19   #9
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
Go with the U2410, it's newer, most likely IPS and dell hasn't played the panel lottery on us yet.
Or just go on ebay and pray for the best while searching for a NEC2490WUXi.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 18th Aug 2009, 12:49   #10
eric_r
Minimodder
I've placed an order for the U2410. I'll probably right up a new thread with some thoughts on it, and if anyone has some questions, I'll see if I can answer them, seeing as it's not yet available everywhere.
Thanks for all the advice guys.
Old 19th Aug 2009, 04:33   #11
Elton
Elton's Avatar
When it is, post up screenies, I would like to see it's performance.
__________________
Old 20th Aug 2009, 08:56   #12
eric_r
Minimodder
Interestingly, the U2408 isn't on the website anymore. They either sold out before the end of the promotion, or it was a runout model anyway.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
