Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Aug 2009, 11:02   #1
Sifter3000
I used to be somebody
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
Sony announces new PSN features, Home content
http://www.bit-tech.net/news/gaming/...psn-features/1
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 19th Aug 2009, 11:13   #2
dolphin-promotions
Modder
dolphin-promotions has yet to learn the way of the Dremel
iPlayer will be a very welcome addition!
dolphin-promotions is offline   Reply With Quote
Old 19th Aug 2009, 11:38   #3
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
In built iPlayer functionality is welcome, as is the vidstore: getting your digital content onto your lounge TV is something that no-one's quite come up with a ubiquitus solution for.
That said, I've just turned my 4 year old laptop into a fully functional HTPC with £10 worth of VGA/3.5mm Composite adapter cables.
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 19th Aug 2009, 13:27   #4
eek
CAMRA ***.
eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!eek - it's over 9000!!!!!!!!1!1!1!!!
You can already access iplayer through the browser simply enough, not the most groundbreaking feature to be announced!
eek is offline   Reply With Quote
Old 19th Aug 2009, 15:03   #5
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
indeed and using the browser zoom rather than iPlayer fullscreen gives you better performance than using the fullscreen option in the iPlayer window so its better to do through the browser.
sandys is offline   Reply With Quote
Old 19th Aug 2009, 16:54   #6
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
I did not know this, Thank you eek and sandys! : )
My PS3 already doubles up as my TV (freeview), console (360 has died AGAIN!) and general media centre (DVD,Blu Ray etc) - this will be a welcome addition to catch up with any bits of Top gear I have missed.
__________________
Daedalus - Clevo P170SM | i7 4700MQ @ 3.4Ghz | GTX780M 4GB @980/6000 | 16GB DDR3 | 17.3" 1920x1080 |
ZPM "VIVE" Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | 4K TV / HTC VIVE |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
xaser04 is offline   Reply With Quote
Old 19th Aug 2009, 18:32   #7
sjhujh
Supermodder
sjhujh has yet to learn the way of the Dremel
There was stuff on the BBC website about official support for the iplayerr on the PS3, as at the moment it has been using the same interface and quality as the Wii... So I think what they are refering to is the HD option which used to be missing... Although I haven't used iPlayer in the last couple of months so they may have enabled it since then...
__________________
||Corsair 600Q | i5 6600K | 16gb G.Skill Ripjaws V | ASUS ROG Maximus VIII Ranger | 4gb EVGA GTX 970 SC| | PSN: fillip2k | |
sjhujh is offline   Reply With Quote
Old 20th Aug 2009, 09:00   #8
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpit
ps3iplayer.com has gone donw hill since the last update. It used to be really good but now its very jerky so proper iplayer integration and hopefully HD video will be very welcome. I'm also looking forward to the vid store so i can rent HD films. Nice one Sony.
Da_Rude_Baboon is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
