Hardware Sapphire Radeon HD 4890 Vapor-X 2GB review
Discussion in 'Article Discussion' started by Guest-16, 25 Aug 2009.
  1. Guest-16
    Guest-16 Guest
  2. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Wow I cant believe it! A 4890 is beating a 285!
  3. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    And that's with ATI drivers 4 months old which was a serious shame imo, one month or even 2 i could forgive but 4? That's just bad form
  4. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    I'm glad you pointed that out Gremlin, I can't help but get really annoyed at reviews (not just BTs) when they use out of drivers. Enjoyable read though.
    :D
  5. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    Thanks for the comments. PLEASE CHECK YOUR PMs!!!
  6. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    WTF is happening with the multi-GPU solutions on COD5? On the higher resolutions, they all go down HARD on the minimum framerates, dropping under 25, which is definately unplayable! Yikes. the single-cards perform much better :confused:
  7. Guest-16
    Guest-16 Guest
    Yep, not smooth.
  8. Elton
    23 Jan 2009
    Hmm, lots of connectivity here, but there still should be no reason to even include D_sub.
    Still an awesome card, and I would get one if it wasn't for the fact that DX11 cards are literally coming around the corner, and I need to save up for a LCD2080UXi.
  9. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    Nice review, well written, but on relevance EPIC FAIL.
  10. Action_Parsnip
    3 Apr 2009
    Pull your fingers out of your behinds and update your damn drivers. Cheap-ass websites will end up with cheap-ass readers.
  11. Elton
    23 Jan 2009
    Actually, I haven't seen much "rabbit-out-of-hat" drivers from ATI for quite a while. That said I do agree, although in this case it might've been a bit harsh.
  12. Gremlin
    31 Aug 2008
    Is the situation fixed with newer drivers considering the age of those tested and the big gains since then? Cat 9.8 had HUGE gains for multi gpu setups iirc
  13. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    I too had noticed drivers are somewhat out of date when these tests are performed!
    If you look at the gainward gtx295 single pcb review you will see what I mean. (comments section)
    Andy
  14. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Well spotted on the drivers guys.
    Is there a reason why the 9.4 ATi drivers were used instead of this months 9.8 or the 9.7 if you tested these cards before the 15th August?
  15. fargo
    fargo What's a Dremel?
    13 Feb 2006
    good review and a great card that said wouldn't a sapphire 4890 toxic with vapor-x be a better choice with manufactured clock speeds
    of 960 that is under warranty?
  16. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    Why Isn't there a picture, or description of the bundled goodies??
  17. Combatus
    16 Feb 2009
    1st page, 4th paragraph, last sentence ;)
  18. Hustler
    Hustler Minimodder
    8 Aug 2005
    Hmmm, 4-6wks from now you will be able to buy a 5850/5870 DX11 class card, both of which should be quicker than this, and for the same amount of money, in the 5850's case anyway......
    Silly to buy a new CPU or GPU at the minute......
  19. Action_Parsnip
    3 Apr 2009
    Its got nothing to do with rabbits. Its good practice to keep forceware and catalyst up to date. 4 revisions out of date is just epic fail. Not even xbitlabs or legionhardware pull this kinda crap. Fail.
  20. Nelly
    Nelly EverQuest Addict, 10+ Years.
    13 Mar 2008
    The Nvidia 185.85 drivers better than any of the 190 series drivers I've used especially in Crysis.
    Would of been good if they used the Nvidia 185.85 drivers vs ATI/AMD 9.8 Cats.
Tags: Add Tags
