Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Sep 2009, 11:03   #1
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
PSU Group Test: 500W, 600W, 700W, 850W
http://www.bit-tech.net/hardware/psu...psu-round-up/1
A small selection of power supplies in the most popular wattage range that were seen in Custom PC magazine's latest PSU labs test. There's a lot more to take into consideration when selecting a PSU than just a paint job and a power output rating. Read on to find out more.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 14th Sep 2009, 11:37   #2
Bbq.of.DooM
Custom User Title
Bbq.of.DooM's Avatar
Bbq.of.DooM has yet to learn the way of the Dremel
A single powerful 12V rail such as this one is cheaper to implement and more power efficient than multiple lower-wattage 12V rails, but it’s also potentially more dangerous if the PSU suffers a catastrophic failure.
could you tell me how? they're all sourced from the same transformer..
__________________
Wowomg!!
Bbq.of.DooM is offline   Reply With Quote
Old 14th Sep 2009, 12:14   #3
do_it_anyway
Supermodder
do_it_anyway's Avatar
do_it_anyway has yet to learn the way of the Dremeldo_it_anyway has yet to learn the way of the Dremel
Darn it
I am waiting for someone to topple the crown of the BeQuiet 650w. I really want this PSU, but am struggling to afford £20 per 100w.
PSU's seem one area in which the prices are going UP faster than inflation.
My current PSU (Hiper 580w Type-R - which I have never had a problem with despite so-so reviews) cost less than £10 per 100w less than 3 years ago.
Come on PSU manufacturers, give us a quiet, stable, cool PSU with oodles of spare power, modular cables and all in a nicely priced package! (Guess I AM asking for the impossible!)
do_it_anyway is offline   Reply With Quote
Old 14th Sep 2009, 12:51   #4
V3ctor
Tech addict...
V3ctor's Avatar
V3ctor has yet to learn the way of the Dremel
Corsair HX-850 FTW!... I read a review somewhere that they stretched it to 1064w and she didn't break... great PSU...
__________________
Main: Intel Core i7 4770K@4.5Ghz / ASUS Sabertooth Z87 / 2x4Gb Gskill Trident X 2400Mhz / MSI GTX 750Ti 2Gb GDDR5 / Samsung T260 / 2x Corsair Force GT 240Gb raid0/ Corsair HX-850W/ Silverstone FT02R-Wi
Laptop: Intel Core i7 4790K 4-4.4Ghz / 8Gb DDR3 1600Mhz / nVidia GTX 980M 8Gb GDDR5 / Samsung SSD 256Gb XP941
Hobby: AMD Opteron 175 / ASUS A8N-SLi SE / 3Gb DDR400 / ATI HD4850 512Mb GDDR3 / Crucial M550 128Gb M2
V3ctor is offline   Reply With Quote
Old 14th Sep 2009, 15:05   #5
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
But at what temperature? PSUs lose the ability to output higher wattages as the internal components get hotter - Corsair rates its PSUs at 50C to give them decent tolerance, so possibly if the test room was 15C or something, the HX850 could output more than its rated wattage. Put it in a hot case though, and the maximum output will be more like the quoted 850W.
Just worth bearing this in mind if you're building a PC - don't assume that you can get a cheaper, low-wattage unit an 'over-watt' it!
Claave is offline   Reply With Quote
Old 14th Sep 2009, 16:09   #6
MiNiMaL_FuSS
ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
MiNiMaL_FuSS's Avatar
MiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming SaiyanMiNiMaL_FuSS is a Super Spamming Saiyan
Cosair still seem to be producing brilliant PSUs, frankly I won't bother with PSU reviews unless something drastic changes, u simply cant go wrong with what COSAIR offer at the moment....just pick the right power range and your away.
__________________
すべてのあなたのチーズケーキは私たちに属している
MiNiMaL_FuSS is offline   Reply With Quote
Old 14th Sep 2009, 16:44   #7
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
My HX1000 is perfect. Really can not fault it.
Skiddywinks is offline   Reply With Quote
Old 14th Sep 2009, 18:13   #8
V3ctor
Tech addict...
V3ctor's Avatar
For what I saw... HX-850 is better... cooler, and efficient... stable... Can't put the link here, sorry
__________________
Old 14th Sep 2009, 18:24   #9
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
I used to run 600w on my main.. but last year got a really good deal on a corsair tx850 single rail- the higher wattage is there if you need it, as long as you load it a bit- you'll run in the optimum range and get the best efficiency
that's why I think going higher than what you need is the best case scenario.. if you get a ps that's just enough to cover what you have running, it will have high heat, lower efficiency, need more fan
on the other end.. if you go too high, like 1000 watts and only running a emachine.. the ripple is worse
thehippoz is offline   Reply With Quote
Old 15th Sep 2009, 01:22   #10
Stormtrooper
Shh...
Stormtrooper's Avatar
Stormtrooper has yet to learn the way of the Dremel
I've been using a corsair tx650 for most of a year now. It's very similar in many respects to the 850 model, but it's definitely not noisy (pushes out hot air, though). I'd definitely recommend it if 850W isn't required and you can fit all those cables in your case.
Stormtrooper is offline   Reply With Quote
Old 15th Sep 2009, 04:46   #11
leexgx
CPC hang out zone (i Fix pcs i do )
leexgx's Avatar
leexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremelleexgx has yet to learn the way of the Dremel
as its what i can realy only get on my list i use thermaltake thoughpower PSUs (min is 750w they start from purepower is below that) never realy had an problem with them i had 1-2 1000w PSUs powering 3x9800GX2 (folding) as it has native 6PCI-e power connectors and the 1500w one is perfect for 4GPU systems as that has 8PCI-e power, i would like to see some of thermal take lower end PSUs reviewed
i nom get 500w cheap octigen (most likey blow up at 300w load ) but they do as replacemets as most of them norm pull max 100-150W in the systems
and for better tests realy you should of been doing 75% load tests as well or something like HardOCP PSU tests
__________________
i7-920 (4Ghz) <> Titian ferna <> Rampage extreme III<> GTX480 <> 24gb 3x8gb random make 1600 <> SSD Mx100 500gb / segate .11 1.5TB <> X-Fi Titanium Fatal1ty <> TK 1000w Toughpower <win7 x64> GreenFrog Computers Warrington
leexgx is offline   Reply With Quote
Old 15th Sep 2009, 17:42   #12
cjmUK
Old git.
cjmUK's Avatar
cjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run Crysis
Earlier this year I bought a Be Quiet DarkPower Pro 750W... a little on the expensive side, but you get what you pay for. I'm just hoping these tests vindicate my purchase....
__________________
FD Define R4, i7 920 [with Thermalright HR-01+/Noctua NF-P12], Gigabyte EX58A-UD3R, 6GB Corsair XMS3 PC2-12800, MSI R9 280X
cjmUK is offline   Reply With Quote
Old 16th Sep 2009, 08:28   #13
Scirocco
Boobs, I have them, you lose.
Scirocco's Avatar
Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!
I love all my Corsair PSUs. Never had a problem with any of them (knock on wood.).
__________________
"If she were any more of a bitch, she'd have puppies!" Victoria Chase, Hot in Cleveland.
Current project: La Fée Verte
Scirocco is offline   Reply With Quote
Old 16th Sep 2009, 19:49   #14
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
I have the Nexus NX-8060 in my brothers rig and it is simply amazing, silent, clean, just works. Certainly would recommend that PSU for people needing a PSU in that power range.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 •
HourBeforeDawn is offline   Reply With Quote
Old 16th Sep 2009, 22:35   #15
adidan
Yeah, nah bro.
adidan's Avatar
adidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyan
Be Quiet Dark Power Pros FTW. In my experience no other range comes close for stability, build and quietness.
__________________
Guesswork is still work
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung S24C570HL 24" // W7 64
adidan is online now   Reply With Quote
Old 12th Nov 2009, 05:43   #16
-Acid-
What's a Dremel?
-Acid- has yet to learn the way of the Dremel
Suprised that the Enermax Revolution 85+ 850w+ isn't here seeing that at the minute it curently is the best power supply doing the rounds with 91% efficienty.
I see you reviewed the 950w version and loved it
I,m looking for a new psu as my last one died, dammed 2900xt's suck loads of juice at 1.35v core each.
-Acid- is offline   Reply With Quote
Old 12th Nov 2009, 08:43   #17
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Pretty much the same thing to be honest. 850.. 950..
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
