Reply
Thread Tools View Mode
Old 19th Sep 2009, 21:48   #1
Spotswood
Custom PC case builder
Spotswood's Avatar
Spotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the DremelSpotswood has yet to learn the way of the Dremel
Project: Large Wooden Tower - Finished!
Final pics here.
I'm very fortunate to have been commissioned to build a large wooden tower case, to be used to hold a large water cooled rig. The design of the case was born from Mick64's 'Case Design for Liquid Cooling' thread over on XtremeSystems Forums. I'm a wood worker, not a metal worker, so I had to compromise that design somewhat in order for me to be able to build it. (But I also like to think I've made some small improvements over Mick64's initial design.)
The case will be constructed in such a way that it could be shipped "flat", but yet still be easily assembled when the case arrives at its final destination. To reduce the weight of the case, it will be made from hardwood trimmed 1/4-inch oak veneer plywood.
The case is designed to contain an EATX motherboard, seven 5.25-inch drives and eight 3.5-inch hard drives. Two 120.4 radiators will eventually be mounted in the top chamber:
For wire routing/hiding, there's a "false back" between the mother board tray and the side panel:
The front fascia/panel is removable (although not on a hinge). Each horizontal "chamber" in the case is fed and exhausted by a 120mm fan.
Fresh air is supplied to the front fans via a bottom-fed, built-in air duct.
The case will stained black throughout:
That pretty much wraps-up "the design tour."
The first order of business is to fabricate the hard drive cages from 1/8-inch aluminum flat bar:
The drives are suspended in soft rubber grommets:
Spotswood is offline   Reply With Quote
Old 30th Sep 2009, 04:32   #2
Spotswood
Spotswood's Avatar
Optical Drive Cage
The cage/rails for the 5.25-inch optical drives were made from 1/8-inch aluminum sheet and 1/2-inch aluminum angle. The aluminum sheet was easily cut on the table saw (fitted with a carbide tipped saw blade). The strips were then stacked and a full-size template of a rail (drawn in Sketchup) was taped on.
The strips were then clamped to a home made jig in order to cut the slots in the rails safely and accurately.
In the center edge of each rail, a 6-32 thread was tapped (using my awesome hand tapper):
The holes in the angle were quickly drilled with the help of a self-centering vice (note the addition of a 1/8-inch plate in order to center the "leg" of the angle in the vice):
All of the aluminum pieces were scratched with 80-grit sandpaper. One-half of an assembled drive cage:
Having the ability to remove individual drive rails provides flexibility when it comes to laying out the rig and for easy customizations.
Old 30th Sep 2009, 11:24   #3
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Nice start brother, I ll keep an eye on you!!!
AnG3L is offline   Reply With Quote
Old 1st Oct 2009, 00:03   #4
SquattingDawg
Minimodder
SquattingDawg's Avatar
SquattingDawg has yet to learn the way of the Dremel
I like the design for this too! I've been thinking of building a wooden case for a while and I REALLY like how the design for this one looks. I'll be keeping track of this one.
SquattingDawg is offline   Reply With Quote
Old 9th Oct 2009, 14:52   #5
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
Any updates?
__________________
Project Log: Zenith Antique Radio Scratch Build
Project Log: Project Quintessence
voigts is offline   Reply With Quote
Old 9th Oct 2009, 15:52   #6
Spotswood
Spotswood's Avatar
Originally Posted by voigts View Post
Any updates?
I've been sick since my last post, so no updates. Sorry. I hope to be back in the shop in the next several days. To help preserve my sanity I've been trying to keep myself mentally active by modeling several variations of this case. Here's one designed specifically to house an air-cooled rig (with the potential to hold a dual radiator):
Old 9th Oct 2009, 23:45   #7
MarkW7
Total Noob
MarkW7's Avatar
MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.MarkW7 is the Cheesecake. Relix smiles down upon them.
Looks interesting, subscribed.
__________________
MarkW7 is offline   Reply With Quote
Old 9th Oct 2009, 23:55   #8
The_Beast
I like wood ಠ_ಠ
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
How are you doing the front for the CD drives? A door or cutouts for each bay
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 10th Oct 2009, 02:38   #9
Spotswood
Spotswood's Avatar
The front panel pops-off:
Held on by these ball latches (part #1790A22 at McMaster.com):
Old 10th Oct 2009, 04:06   #10
The Twisted One
Minimodder
The Twisted One's Avatar
The Twisted One has yet to learn the way of the Dremel
I presume there will be a gap left between front panel and the main case to allow air flow ?
Any way being a chippie by trade ill be watching , I like the design simple and tidy (simple in style not in skill needed )
The Twisted One is offline   Reply With Quote
Old 19th Oct 2009, 03:12   #11
Spotswood
Spotswood's Avatar
Router Pattern Making
After a lengthy illness I managed to drag myself to the lumber yard and into the shop for a few hours. I took it easy on myself and just fabricated a couple of templates out of MDF that will be used to route out the motherboard tray and power supply openings out of the back panel.
Power supply template:
Motherboard tray template:
I also cut and glued the frame for the back panel out of 3/4x3/4-inch oak:
Old 24th Oct 2009, 21:22   #12
Spotswood
Spotswood's Avatar
A jig was built to safely rabbet the inside edges of the glued-up front panel frame.
The front and back panel frames were rabbeted to accept the 5.2mm oak veneer plywood.
The plywood was cut on the table saw. The corners were rounded "free hand" on the table saw then finished with sandpaper and a sanding block:
A cleat was glued to the backside of the MB tray template for easy alignment.
A router with a 1/2-inch pattern/flush-trim bit was used to route out the hole. For the top and bottom power supply holes, that template its fastened to the underside of the panel in order to center it properly and a 3/8-inch pattern/flush-trim bit was used.
Perfect! The plywood pieces can now be glued to the back and bottom frames.
Stay tuned!
Old 25th Oct 2009, 23:57   #13
Spotswood
Spotswood's Avatar
I was interested to see just how big this case really is so I quickly bolted the panels together and fastened the mother tray:
For perspective, that's an EATX motherboard tray. The "huge" Corsair 800D case would fit inside this case.
Old 26th Oct 2009, 00:15   #14
Colossous
Hypermodder
Colossous's Avatar
Colossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run Crysis
Crikey - that is one big case !! Looking forward to see it transpire
Colossous is offline   Reply With Quote
Old 26th Oct 2009, 00:24   #15
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
No shortage of room for video cards in this beast. Nice work.
I watch.
john
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Old 26th Oct 2009, 02:15   #16
Mach
Multimodder
Mach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the DremelMach has yet to learn the way of the Dremel
Wow, the craftsmanship is amazing! Sub'd
Oh yeah, love the tap!
Mach is offline   Reply With Quote
Old 26th Oct 2009, 15:53   #17
bigsharn
Officially demotivated
bigsharn's Avatar
bigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysis
That thing is MAHASSIVE
Any idea what kind of hardware's going in it?
__________________
{Rolling on a 1990s Dawes Galaxy}
{Nikon D80, 18-55 f/3.5-5.6G and 50mm f/1.8}{Lomo Smena 8M}{Olympus OM10, 50mm f/1.8, 28mm f/2 and 135mm f/3.5}
bigsharn is offline   Reply With Quote
Old 26th Oct 2009, 18:41   #18
RuSGaMeR
No Pain No Gain...
RuSGaMeR's Avatar
RuSGaMeR has yet to learn the way of the Dremel
Same question here)))
__________________
My Avatar = My drawing skills...
Drawing = My LIFE
Started on my case...will make log later (need more pics )
RuSGaMeR is offline   Reply With Quote
Old 27th Oct 2009, 23:17   #19
Spotswood
Spotswood's Avatar
"... 2x RX480 rads, 2 sexy D5 pumps, 2 EK res, all BP fittings. The actual pc components are in the air though."
I'll keep you guys posted once I find out what components he eventually decides to use.
Old 28th Oct 2009, 23:44   #20
Spotswood
Spotswood's Avatar
The "shelves" that separate the case into three chambers was fab'd from 3/4-inch square oak, rabbeted to hide the plywood edge.
The shelves nestle onto brackets made from 1/2-inch aluminum angle.
The angle bracket for the top shelf along the back panel just so happens to land in the same location as the bolts used to fasten the motherboard tray. Originally I was thinking the tray would be bolted onto the back panel (with a nut), but with the angle bracket there, doing so would be very awkward. So instead, I just tapped some 6-32 threads.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
