Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 27th Sep 2009, 22:50   #1
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
GTX 280 EK backplate mod (make it fit any GTX 280)
I have a water cooled GTX 280 that came with a Watercool Heatkiller GPU-X² block. Downside is it didn't come with ANY cooling to the RAM chips on the top of the pcb (ones on the core side are cooled by the waterblock).
They get damn hot so I first tried some ramsinks but they too got red hot after a good gaming session.
I then tried some longer ramsinks I had spare to increase the surface area but these too got a little too hot for my liking. Just goes to show how hot these chips get.
I searched high and low for something larger but couldn't find anything then I remembered that EK Waterblocks do a backplate for the GTX 280 which should work a treat as it's massive. Downside is that it's only compatible with EK blocks. Well, not after a bit of modding it's not!!!
I started by drilling out the screw holes, all of them, to make sure nothing fouled any of the existing mounting screws from my Watercool block on this side of the PCB. Thankfully the plate is made of aluminium so this took less than 20mins. I was left with a nice flate plate of aluminium that should sit straight onto the RAM chips on the back of the card.
I'll be using thermal adhesive to attach it so I don't want to not be able to access the block's screws in future so I made sure these were easily accessible. This stuff gives a pretty strong hold and is better than most thermal pads I've used. It's not stuck on for ever though, you can prise things off if needbe but measure twice, stick once that's for sure!
Next up was to test fit then apply the thermal adhesive to the RAM chips.
All done! It's worked a treat and when gaming it gets pretty warm but at least it's doing it's job! Seeing how well the thermal adhesive worked I was tempted to try puting motherboard mosfet coolers across the banks of RAM chips but we'll see how this goes first!
Definitely worth doing if your GTX 280's RAM chips are exposed and cooking themselves.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 28th Sep 2009, 01:37   #2
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
it always surprised me that they didn't include them tbh.
I have been looking all over for a waterblock for my GTX280 for a decent price with no luck, getting annoying now!
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 28th Sep 2009, 16:57   #3
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
It's been a while since I've seen the staff modding. It's good to see one of you still at it.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 28th Sep 2009, 23:06   #4
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
Very nice, now paint the insides of the holes black.
Good tutorial.
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 29th Sep 2009, 00:10   #5
Combatus
Moderator
Combatus's Avatar
Hell yeah!
Good tutorial.
I may be lazy and not bother as the plate faces the bottom of my case (Lian Li with inverted MB tray) I feel bad now.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
