Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th Sep 2009, 10:25   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
What's the best 120mm case fan?
We've collected 22 120mm fans and put them through rigorous noise and airflow tests to see which is the best. Read on to see how to keep your hardware cool while keeping the noise your PC makes to a minimum.
http://www.bit-tech.net/hardware/200...est-case-fan/1
Claave is offline   Reply With Quote
Old 28th Sep 2009, 10:43   #2
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
Was not expecting this. Good article though, too bad I already bought my Fans.
Also,
Fortunately, [bit-tech[/i] is here
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 28th Sep 2009, 10:44   #3
The Infamous Mr D
Multimodder
The Infamous Mr D's Avatar
The Infamous Mr D has yet to learn the way of the Dremel
This is an extremely useful article, guys! I was in the market for some decent 120mm fans, are you actually capable of clairvoyance?
__________________
S C A R L E T T
Intel Core i7-4790k Asus Maximus VII Impact G-Skill 8GB RipjawsX DDR3 2133 ASUS AMD Radeon R9 290X DirectCU II OC 4GB
Samsung 850 EVO 500GB Thermaltake SMART 530W Bitfenix Prodigy Corsair Hydro Series H105 Liquid CPU Cooler
The Infamous Mr D is offline   Reply With Quote
Old 28th Sep 2009, 10:45   #4
Kyocera
The Garden of Evil
Kyocera's Avatar
Kyocera has yet to learn the way of the DremelKyocera has yet to learn the way of the Dremel
I have a reclamation, or two:
- the trash bag used is to small
- and it should be of another colour (yellow, pink,..)
- pizza box should have been used
I hope you'll expand with bigger size ventilators,..
Kyocera is offline   Reply With Quote
Old 28th Sep 2009, 10:46   #5
billysielu
Multimodder
billysielu has yet to learn the way of the Dremel
Hard to believe there's such a big variation in products which are essentially identical.
billysielu is offline   Reply With Quote
Old 28th Sep 2009, 10:50   #6
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
I was really surprised by this too, but when you think of the huge differences in F1 car performance caused by minor additions in aerodynamic design, you start to understand how a few extra mm of plastic or a a few degrees of fin pitch can make a big, big difference.
Baz is offline   Reply With Quote
Old 28th Sep 2009, 11:07   #7
zr_ox
Whooolapoook
zr_ox's Avatar
zr_ox has yet to learn the way of the Dremel
Well my S-Flex are off to the bin.
Never did like their noise signature, they do cool wee though!
Thanks BT for a very informative and well put together article.
__________________
0ptimizm
:PC under review
zr_ox is offline   Reply With Quote
Old 28th Sep 2009, 11:11   #8
Claave
You Rebel scum
Claave's Avatar
No wonder you're putting them in the bin. Eurgh!
Old 28th Sep 2009, 11:23   #9
MajorTom
Multimodder
MajorTom has yet to learn the way of the Dremel
Thank you so much for this article. I'll be passing this around.
__________________
Steam: MajorTomG
MajorTom is offline   Reply With Quote
Old 28th Sep 2009, 11:37   #10
Rocket_Knight64
Multimodder
Rocket_Knight64's Avatar
Rocket_Knight64 has yet to learn the way of the Dremel
I heard alot about the Gentle Typhoon. I replaced my NF-P12's with the AP-14's and they are indeed much quieter and push alot more air despite the higher RPM. They are not quite so nicely finished though (cable is unbraided and a bit short, and fiddly to mount), but for half the price I can live with it. Now all we need is a 140mm version.
Are there any plans for more fan reviews? Of perticular interest are the enermax apolloish and akasa apatche (which is apparently made by Scythe so should not be tripe).
__________________
Q9550 E0 @ stock under TRUE : Maximus II Formula : 4Gb Corsair Dominator : HD4870 512Mb (790/1100) + Accelero S1
120Gb G.Skill Falcon : 300Gb VelociRaptor : 1Tb Samsung F1 : Auzentech Prelude
AE Aego M 2.1 : Hazro HZ24Wi LCD : G15 v1 KB : G5 Mouse : Lian-Li PC-A17
Rocket_Knight64 is offline   Reply With Quote
Old 28th Sep 2009, 12:06   #11
Stickeh
Help me , Help you.
Stickeh's Avatar
Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.Stickeh is the Cheesecake. Relix smiles down upon them.
I'm so glad when i built my system i bought sharkoon!
I put an akasa amber fan in the roof the other day and it was so noisy! My system is almost silent, and thats the way i like it!
__________________
My Midas Mk2 Bronze 'Blog'
Stickeh is offline   Reply With Quote
Old 28th Sep 2009, 12:20   #12
hexx
Multimodder
hexx has yet to learn the way of the Dremel
still, for me the best case fans are Nexus silent 120, got 5 of them in p182 at full speed and can't hear them, true i've got soundproofing in my case, but still after testing about 20+ different fans nexus came as a winner in my box.
__________________
*** MacBook Pro 13" - 2.26GHz - 4GB RAM | iPhone 4 32GB | PS3 Slim 250GB | Get 2 months FREE @ LOVEFiLM - staff code ***
hexx is offline   Reply With Quote
Old 28th Sep 2009, 12:27   #13
shaffaaf27
The budget builder
shaffaaf27's Avatar
shaffaaf27 has yet to learn the way of the Dremel
Also,
LOL I predicted this since i paid for this article a couple months ago _
shaffaaf27 is offline   Reply With Quote
Old 28th Sep 2009, 12:35   #14
mrbens
Supermodder
mrbens's Avatar
mrbens has yet to learn the way of the Dremel
This is a good article taken from CustomPC. How come you didn't post the other fan sizes you tested in the mag?
It would have been nice to see a Yate Loon fan in there, especially for the watercooling testing as they are widely regarded to be the best for this job.
Also seeing all the stats together like this but with actual cfm & dBA instead of 7/10 etc would have been more informative (IMHO):
Anyway, great stuff as usual.
mrbens is offline   Reply With Quote
Old 28th Sep 2009, 12:41   #15
sear
Guest
Posts: n/a
Very good job with this article, and an interesting way of measuring "real world" airflow. I have a couple of Scythe fans myself, though not the ones in the test. I've had a liking for them for a while due to their effectiveness and low noise.
Old 28th Sep 2009, 12:46   #16
DbD
Supermodder
DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.DbD is a hoopy frood who really knows where their towel is.
Great article, but can you do a bit more please? As the radiator test showed there's a big difference between using a fan to shove some air in/out of the case and using one to shove air between the grills of a heatsink.
Would have liked you to run all the fans through something like a thermalright ultra 120 with the sides taped, then into your bag to measure their effectiveness for an aircooled heatsink.
Would also have liked you to measure some of the slower S-flexes.
Any chance of a follow up?
DbD is offline   Reply With Quote
Old 28th Sep 2009, 12:49   #17
Yoy0YO
Lurky Lurker
Yoy0YO has yet to learn the way of the Dremel
Thanks for the article! I was looking for something as well in the lines of a Slim Fan..
__________________
Chef - | i5 750 | Gigabyte H55N | 4GB | 1.5TB | Sapphire 5850 Vapor-X | Silverstone SG05B + ST45SF |
Yoy0YO is offline   Reply With Quote
Old 28th Sep 2009, 12:50   #18
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
No Yate Loons? ;(
rickysio is offline   Reply With Quote
Old 28th Sep 2009, 13:22   #19
WildThing
Hypermodder
WildThing's Avatar
WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.
bit-tech is here with a well-timed group test of 120mm fans
Lol, how very apt that phrase is for me, since it was only a week ago I bought my first Custom PC mag just for the fan article! Still, I guess there are more fans tested in the mag.
__________________
Asus P8P67 PRO Intel i5 2500K @ 4.4GHz Titan Fenrir XFX 6950 @ 6970 2x4GB Corsair DDR3 1600MHz 2x Crucial C300 128GB (OS + Games) Samsung Spinpoint F3 1TB Auzentech XFI-Prelude + Creative T7700 7.1 Enermax Liberty 500W Corsair 650D case HP 24" LP2475W Win7 x64
WildThing is offline   Reply With Quote
Old 28th Sep 2009, 13:25   #20
Lizard
@ Scan R&D
Lizard's Avatar
Lizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run Crysis
For those that have asked - we'll be putting the other fan size reviews up shortly as we didn't want to put a monster 20+ page article up covering all fans sizes in one go.
Lizard is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
