Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 29th Sep 2009, 01:35   #1
TheMusician
Audio/Tech Enthusiast/Historian
TheMusician's Avatar
TheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the Dremel
What resolution are you running?
1. What resolution are you running?
2. Is it worth making my site viewable on 1024x768 displays?
Also, how do I add a poll again? I couldn't find it when I posted this, and now I can't find it at all.
__________________
DIY Desktop: Ph X4 960T (w/OCZ Vendetta), Gigabyte 785G, 8GB DDR2-1066, XFX HD4850, 64GB Crucial M4 + 640GB Cav Black, M-Audio 2496, W7 Pro x64
ASUS UL30VT-A1 Laptop: C2D SU7300, 6GB DDR3-1066, G210M, 500GB Sco Blue, W7 Pro x64
TheMusician is offline   Reply With Quote
Old 29th Sep 2009, 01:56   #2
DarkLord7854
Pew pew lazerz
DarkLord7854's Avatar
DarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run Crysis
1. 5760x1080
2. Yes, the web standard is 1024x768, as it has a VERY large percentage of people using that resolution.
http://marketshare.hitslink.com/report.aspx?qprid=17
__________________
Asus P9X79 Deluxe | i7 3930K | 2x Asus GTX560 Ti | 3x OCZ Agility3 240GB SSD - 1x WB Black 1Tb | G.Skill Ripjaws Z 32GB DDR3-1866 | Creative XtremeGamer X-Fi | Thermaltake Level10GT
DarkLord7854 is offline   Reply With Quote
Old 29th Sep 2009, 02:02   #3
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Standard sizes from PhotoBucket. For B-T I use 17" monitor mostly
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 29th Sep 2009, 02:50   #4
klutch4891
Hypermodder
klutch4891's Avatar
klutch4891 has yet to learn the way of the Dremelklutch4891 has yet to learn the way of the Dremelklutch4891 has yet to learn the way of the Dremel
I'm running 5408x1152. One 2048x1152, one 1440x900, and one 1920x1080.
A website is definitely worth making compatible in 1024x768. To be honest I normally have a problem making it viewable on smaller resolutions (horizontal scrolling is horrendous).
__________________
Main Rig |Intel Q6600 @ 3GHz ¦¦ XFX 680i ¦¦ 4GB G. Skill ¦¦ HD7970 ¦¦ ¦¦ Xonar DX ¦¦1TB Samsung F3 ¦¦ 1TB Samsung F1 ¦¦ 250GB Seagate 7200.10 ¦¦ 40GB Samsung Spinpoint ¦¦ Coolermaster Cosmos
klutch4891 is offline   Reply With Quote
Old 29th Sep 2009, 02:53   #5
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
1920x1200. Smaller, I dunno, we don't even sell a monitor that small.
__________________
I don't feed the trolls...
Quit chopping up the locals to make tools.-Cheapskate
KayinBlack is offline   Reply With Quote
Old 29th Sep 2009, 03:03   #6
outlawaol
Geeked since 1982
outlawaol's Avatar
outlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysis
1680x1080 - Gaming Rig. 1366x768 - Media PC. 1024x600 - Netbook. I find that most websites need to be viewed with the full screen function set to ON with my netbook. Or else its a real narrow window.
__________________
40D| 350D | 24-105 f/4L | 24-70 f/2.8 Sigma | 50mm f/1.8 | 75-300 f/4-5.6 Sigma | 420ex Speedlight
365 Daily Photograph | Smugmug
outlawaol is offline   Reply With Quote
Old 29th Sep 2009, 03:04   #7
jhanlon303
jhanlon303's Avatar
ACK! Resolution Bigot. 17" LCD monitors are the cheapest (thrift store, charity shop) replacement for CRTs.
Marilyn has a 55 inch Samsung with 3 HDMIs and it's a scary Blu-ray monitor. Ryan's 42" plasma it ALL kinds of resolution goodness. Plasmas are scary bad monitors.
I still have multiple 15" test bed monitors for customer reloads.
If it's bigger than an iPhone or PSP screen I'll use it.
Poverty brings equality.
__________________
Old 29th Sep 2009, 03:06   #8
DarkLord7854
Pew pew lazerz
Btw.. OP.. you're asking the wrong community.. obviously all of us know our stuff and have good, high resolution screens.
__________________
Old 29th Sep 2009, 03:21   #9
mvagusta
Did a skid that went for two weeks.
mvagusta's Avatar
mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.
My work lappy is 1440 x 900, where most of my pc time is spent, but i've only got crts at home
2 x 17" and 1 x 15", all at 1024x768
The colors on all of them are great, easily beats average lcds, including my ~ 1 yr old lappy. Quality lcds are getting cheap i know, so i'll probably start upgrading my screens in a year or two, unless they die before hand.
mvagusta is offline   Reply With Quote
Old 29th Sep 2009, 03:27   #10
klutch4891
Hypermodder
klutch4891's Avatar
Good point, but even my parents, grandparents, etc. use at least 1024x768.
__________________
Old 29th Sep 2009, 03:36   #11
jhanlon303
jhanlon303's Avatar
Good point but DAMN I feel old.
__________________
Old 29th Sep 2009, 03:57   #12
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
I'm at 1440x900
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 29th Sep 2009, 04:30   #13
dark_avenger
Raspberry Pi owner
dark_avenger's Avatar
dark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysisdark_avenger can run Crysis
1680x1050 main screen and 1280x1024 secondary screen
__________________
Xigmatek Elysium WC i7 920 Build
Raspberry Pi in a Bay
Speaker Box Project
Join the CPC/Bit-Tech FAH Team #35947
dark_avenger is offline   Reply With Quote
Old 29th Sep 2009, 04:34   #14
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
2560*1024 and 1280*800
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 29th Sep 2009, 05:39   #15
sentek
Multimodder
sentek's Avatar
sentek has yet to learn the way of the Dremelsentek has yet to learn the way of the Dremel
1920x1200 for my main monitor, 1440x900 on my 2nd
its under 'thread tools' at the top
sentek is offline   Reply With Quote
Old 29th Sep 2009, 05:48   #16
Journeyer
Mod Master
Journeyer's Avatar
Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.Journeyer is a hoopy frood who really knows where their towel is.
At home: 1920*1200 and 1280*1024
At work: dual 1920*1200
__________________
When you have eliminated the impossible, whatever remains, however improbable, must be the truth.
ASUS Sabertooth 990FX || FX-8150BE || 16Gb Corsair DDR3 1866Mhz || 2xGTX285 SLI|| 2xOCZ Agility 3 120Gb RAID0 for OS
Journeyer is offline   Reply With Quote
Old 29th Sep 2009, 05:53   #17
docodine
I Mod, Therefore I Own
docodine's Avatar
docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!
Desktop 1: 1920x1200
Desktop 2: 1680x1050
Netbook: 800x480 ()
__________________
Intel i7-3820 @ 4.65GHz | GeForce GTX 480 | 4x4GB Vengeance | Asus Sabertooth X79
Silverstone TJ07 | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet
docodine is offline   Reply With Quote
Old 29th Sep 2009, 06:42   #18
Ending Credits
Bunned
Ending Credits's Avatar
Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!
Main: 1920x1200
Laptop: 1024x768
Netbook: 1280x600 (something like that)
__________________
Originally Posted by lp1988 View Post
We can conclude that Ending Credits has a niche for ejaculation related quotes.
Ending Credits is offline   Reply With Quote
Old 29th Sep 2009, 07:12   #19
4.54billionyears
Multimodder
4.54billionyears's Avatar
4.54billionyears has yet to learn the way of the Dremel4.54billionyears has yet to learn the way of the Dremel4.54billionyears has yet to learn the way of the Dremel4.54billionyears has yet to learn the way of the Dremel
1920x1080 (ATi ccc/advanced/desktops and displays/configure/scaling options/overscan 0%) removes black letterbox frame.
__________________
Corei7 920 4.3ghz v1.44 HT//CorsairDominatorGT 7-8-7-20//Bloodrage//Coolmax1350w//radeon hd5970//CoolerMaster690//LG Blu-ray//FeserXchanger360-mcp655-HeatKiller3-ekres.rev2-feser1/2"od-panaflow.ultras 1550rpm scythe controlpanel//wd1tb_black//external wd1tb_green//HPw2338h & LG E2250T Monitor//Windows7x64 cpuz validated gpuz validated
4.54billionyears is offline   Reply With Quote
Old 29th Sep 2009, 07:38   #20
mooseguy
Crazy Moose
mooseguy's Avatar
mooseguy has yet to learn the way of the Dremel
1920x1200 as my primary monitor, and 1280x1024 for my second.
I wish I had space on my desk for two 24"ers
__________________
Q6600 @ 3.6GHz | DFI LanParty DK P45-T2RS Plus | 4GB Corsair 800MHz | Sapphire Radeon 4870 512MB | Yuraku 24" M-PVA
mooseguy is offline   Reply With Quote
Reply
Tags
lcd, monitor, populace, resolution, screen
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
