Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Oct 2009, 10:32   #1
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
What's the best supersize case fan?
http://www.bit-tech.net/hardware/200...ize-case-fan/1
We've collected six supersized case fans (180mm to 225mm) to see which is best for that all-important side panel fan. Read on to see how Akasa, Antec and others fared in our rigorous airflow and noise testing!
Tim S is offline   Reply With Quote
Old 9th Oct 2009, 10:45   #2
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
I had to get the antec big boy to replace the fan on my cosmos s and apart from using a molex connector (the original 200mm fan used a little 3 pin connector so the motherboard could control fan speed) this has been a good replacement fan.
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 2Tb 2.5" Toshiba HDD, Cooler: Corsair H105, OS: Win 7 - 64
Dave Lister is offline   Reply With Quote
Old 9th Oct 2009, 12:08   #3
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
On page three... the picture discription states both fans to be on the left...
This is an intersting article and the data revealed quite surprising. That such large fans move little more than standard 120mm fans and quiet noise levels. I'm quite glad that when I modded my side panel (blue perspex) I used a standard Sharkoon blowing directly over my GPU cooler, which resulted in a 10c drop in my GPU temps while being virtually discreet.
__________________
SchizoFrog is offline   Reply With Quote
Old 9th Oct 2009, 12:41   #4
IccleD
Modder
IccleD has yet to learn the way of the Dremel
I would love to have seen you include one of these in your review...
Performance PCs Monster 360mm Fan.
That fan is surely for those PC modders that have small... overclocks!
Very informative review yet again. I may have missed it though, but what size was your sack? Just wondering if the bigger sacks, which would take longer to fill, would be more accurate than a smaller one?
IccleD is offline   Reply With Quote
Old 9th Oct 2009, 12:44   #5
frojoe
Multimodder
frojoe has yet to learn the way of the Dremel
So basically there are no good large case fans? That's unfortunate as the build I'm planning now has a few very large fans.
frojoe is offline   Reply With Quote
Old 9th Oct 2009, 12:51   #6
tk421
Idiot.
tk421's Avatar
tk421 has yet to learn the way of the Dremeltk421 has yet to learn the way of the Dremel
it's the law of diminishing returns ...
looks like 120 -140mm is the sweet spot, until there is a radical advancement in technology. that's fine with me, 3x 120mm exhausts and 2x120mm intakes is fine.
__________________
:gamebox: e7400@3.5 (333x10.5)|MSI Neo3f(p43)|2x2gb pc6400|HD4850 (512)|CM590|westie lcm-22w3|
:htpc: Dell 755 desktop|e7500(stock)|4gb ram|HD4350|500gb stripe+1tb storage|LG 37" 1080p lcd|
tk421 is offline   Reply With Quote
Old 9th Oct 2009, 13:12   #7
smc8788
...at least I have chicken
smc8788's Avatar
smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.
I'd like to see how multiple smaller fans compare to supersize ones where cases have the option for it (i.e. 2x140mm or 4x120mm).
smc8788 is offline   Reply With Quote
Old 9th Oct 2009, 13:22   #8
Kyocera
The Garden of Evil
Kyocera's Avatar
Kyocera has yet to learn the way of the DremelKyocera has yet to learn the way of the Dremel
The number of tested fans is too low to give any valid conclusion;
the site here recommends ATCS 840, which has one front 230 x 30 mm fan x 1 / 700 RPM / 19 dBA ; one does not know if to change it, with which one.....
The piece on the classic dimensioned fans was great, this here is just to no avail.
Kyocera is offline   Reply With Quote
Old 9th Oct 2009, 13:26   #9
SchizoFrog
I *am* a Dremel
That would be a totally unfair comparison with 280x140mm2 (39200mm2) compared to 240x240mm2 (57600mm2) which would have a 46% area increase.
(Not exactly true as really you would have to work out the circumfrance area of each individual fan and then time that by 2 or 4 depending on which set up you are looking at... but you get the idea.)
__________________
Old 9th Oct 2009, 13:41   #10
smc8788
smc8788's Avatar
It may be an unfair comparison, but it would still be an interesting one if your case has the option of one 200mm or multiple 120mm mounts (though the latter would be considerably more expensive), as I don't think it would work to just extrapolate from the single-fan CFM and dBA results.
Old 9th Oct 2009, 13:52   #11
fathazza
Freed on Probation
fathazza's Avatar
fathazza has yet to learn the way of the Dremelfathazza has yet to learn the way of the Dremelfathazza has yet to learn the way of the Dremelfathazza has yet to learn the way of the Dremelfathazza has yet to learn the way of the Dremelfathazza has yet to learn the way of the Dremel
yeah, as a HAF 932 owner i'd have liked to have seen the coolermaster 230mm fans on the list too. Tho 3 of them in my case do actually create a breeze around my computer area so i dont think i need an upgrade
__________________
I may be fat but at least I am not Ginger
"The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson
fathazza is offline   Reply With Quote
Old 9th Oct 2009, 15:59   #12
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.
Good info. Too bad about the low static pressures. Looks like some of these fans are mostly for show.
Yay Antec!
__________________
Regardless of what you believe there is someone at least as smart, or smarter, than you who believes something you think is stupid (and it's not just because you know something they don't).
Tyinsar is offline   Reply With Quote
Old 9th Oct 2009, 20:03   #13
i7lova
Minimodder
i7lova has yet to learn the way of the Dremel
Anyone know what brand of fans the Xclio wind tunnel uses? That's the case I ahve and they seem to move a decent amount of air with not a whole lot of noise and also have speed controls built in.
i7lova is offline   Reply With Quote
Old 9th Oct 2009, 20:26   #14
Otto69
Supermodder
Otto69 has yet to learn the way of the Dremel
Bit Tech continues to use the Ghetto fan testing methodology, Until they actually get some real test equipment, and a tester who has some clue as to use it, any further "fan tests" are invalid.
Otto69 is offline   Reply With Quote
Old 9th Oct 2009, 20:27   #15
Otto69
Supermodder
More to the point: this is like doing CPU heat sink tests using your finger tip as the thermometer.
Old 9th Oct 2009, 20:33   #16
drakanious
Minimodder
drakanious has yet to learn the way of the Dremel
NO, NO, NO!
This testing methodology is just plain stupid.
drakanious is offline   Reply With Quote
Old 9th Oct 2009, 21:40   #17
Dave Lister
Hypermodder
If i rember correctly (custom pc did a big article with the fans a couple months back) i think they use the black sack method because there is no proper test equipment available, and even the fan manafacturers just make up the cfm and db ratings that they provide
__________________
Old 9th Oct 2009, 23:45   #18
Sparrowhawk
Wetsander
Sparrowhawk's Avatar
Sparrowhawk has yet to learn the way of the Dremel
Way to be very negative there, Otto. The theory is sound. You have a container of a known volume, and a fan to inflate that container full of air. As long as there are no major leaks in the cardboard fan shroud, the diaphragm between the cardboard and the plastic bag, or in the bag itself...
Sparrowhawk is online now   Reply With Quote
Old 10th Oct 2009, 06:03   #19
Otto69
Supermodder
As I said in the thread for the last fan "test" using this method; at the very least the fans pressure has to overcome the weight of most of the bag, and of the captive air pushing back against the incoming pressurized air. NEITHER of those things should be present in an actual computer case.
Old 10th Oct 2009, 06:11   #20
SchizoFrog
I *am* a Dremel
Why not? Does the air inside your case not push back like the rest of ours?
Instead of just complaining like little girls, why not tell us how to do it better? Oh thats right... YOU DON'T KNOW!!! So STFU!!!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
