RSS
Reply
Thread Tools View Mode
Old 29th Oct 2009, 15:35   #1
Frenkie
Lets mod the world!
Frenkie's Avatar
Frenkie is on a distinguished road
[FM] Hovermax
This is the worklog of my entree in the Enermax Crazy Twister competition. A quit simple assignment; make something crazy with an Enermax fan.
Well, I decided to give my PC some extra airflow from the top of the case and make it look like a stealth plane
First I made some designes in SketchUp, using the geometry of the Enermax Magma 120mm [UCMA12] and the Enermax Cluster 80mm [UCCL8].
(i'm posting the log in a few chunks, just to keep you occupied )
__________________
my cases http://www.casemodz.nl
Frenkie is offline   Reply With Quote
Old 29th Oct 2009, 16:22   #2
bigsharn
Ultramodder
bigsharn's Avatar
bigsharn is just really nicebigsharn is just really nicebigsharn is just really nicebigsharn is just really nice
Looks nice so far...
I reckon you need to mae the entire thing out of carbon fibre, have a dozen of those enermax fans at the bottom and make it live up to it's name
__________________
{Q6600}-{HD4850 512Mb}-{Hiper M 630W}-{Samsung F1 640Gb}-{Antec 300}-{4Gb Team Elite PC6400}-{ECS P35T-A}
{Nikon D80 w/ 18-55 and 50mm f/1.8}-{Lomo Smena 8m}
{LandRover G4 Challenge}-{MonsterRoller No Animal}
Originally Posted by Sir Digby View Post
The answer is alcohol, and if that don't work use more alcohol!
bigsharn is offline   Reply With Quote
Old 29th Oct 2009, 17:22   #3
Cheapskate
know-it-all b*stard...
Cheapskate's Avatar
Cheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud of
Cool!
Cheapskate is offline   Reply With Quote
Old 30th Oct 2009, 11:35   #4
Frenkie
Lets mod the world!
Frenkie's Avatar
Here are the two "victims", who were provided by my good friends from Space Promotion.
This is the position I want them to stand.
For body I use my favorite material called Vikureen, also know as polystyreen.
It's so easy to use, just measure; make a shallow cut....
..and the cut follows the lines perfectly.
__________________
Old 30th Oct 2009, 12:45   #5
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L will become famous soon enough
Nice start bro, good luck with the mod!!!
AnG3L is offline   Reply With Quote
Old 31st Oct 2009, 14:16   #6
Frenkie
Lets mod the world!
Frenkie's Avatar
The top of the microtower is 370 x 180 mm (14.5" x 7"), so thats the size of the mod.
The size of the fans dictated the cuts I made here.
Here you can see the SketchUp drawing and the mod in front of it.
I cut a larger hole in the top, to let the air in.
The smaller fan will provide an exhaust airflow.
For that reason I cut holes in front of the small fan and underneath the large one.
Wow! These fan are very easy to disassemble! What a great idea from Enermax !
I found it was very easy also to get the fans painted.
I painted them metallic silver.
After assembly I stuck the Enermax decall back on to it.
__________________
Old 1st Nov 2009, 12:52   #7
Frenkie
Lets mod the world!
Frenkie's Avatar
This is the large fan now, looks good !
And with just 7 Volt, it spins like a cat and looks very posh
The angle of the fan is fixed, so this piece will make that solid.
After the construction-glue was cured, I can slide it in very easy.
And there it is.
Sideview.
The fan on the back sucks hot air from the case, so it gets a duct.
Other side, with more polystyreen added.
__________________
Old 2nd Nov 2009, 13:28   #8
Frenkie
Lets mod the world!
Frenkie's Avatar
Now a tricky part, a rudder ! The Vikureen is just 2 mm thick.
Added a tiny little hinge.
And here is the connecting piece.
The main hinges I made from simple ear-swap sticks.
With glue, curing for a while.
This is how it should function.
Straight....
...to the left...
..and to the right. It works !
Oops. I forgot to spraypaint the back, quickly corrected.
And now with mounted rudder.
__________________
Old 3rd Nov 2009, 04:41   #9
sentek
my dremel works so i dont have to.
sentek's Avatar
sentek will become famous soon enough
nice, the rudder is pro
i like your designs as well :P
sentek is offline   Reply With Quote
Old 3rd Nov 2009, 14:30   #10
Frenkie
Lets mod the world!
Frenkie's Avatar
Lights please !
Oooh shiny logo !
I spraypainted the rear of the duct in dull black, to get a little more contrast.
These will form the air intakes of the stealthplane.
Had some ACRyan mesh left, very nice material to cover the intakes.
Hmmm, that cable sticks out too far, I better get it inside.
There, thats much better.
For finishing I used a technique called "kit-bashing". From redundant plastic scale models ( planes, cars and boats ) I use small parts to add more detail to the mod.
Some can be very tiny
__________________
Old 3rd Nov 2009, 16:01   #11
gabriel_d7
Budget Mod?
gabriel_d7's Avatar
gabriel_d7 is on a distinguished road
Nice... you just gave me an idea of what material to use if I decide to change my case.
Great start there sir. Gonna be watching out for this one.
gabriel_d7 is offline   Reply With Quote
Old 4th Nov 2009, 13:11   #12
Frenkie
Lets mod the world!
Frenkie's Avatar
With filler I filled the largest cracks.
More details added, I think it will look very nice when its done.
This hinge part was damaged...
So I better stick something over it, to conceal it
More detail added.
Just use my imagination to stick it on.
Fastened the wings, ready to paint.
Primer coats.
__________________
Old 4th Nov 2009, 14:06   #13
mansueto
Ultramodder
mansueto's Avatar
mansueto will become famous soon enoughmansueto will become famous soon enough
Very neat idea, looks really cool!
__________________
Gaming Rig: Processor: Intel E8400 dual core 3.0 GHz stock, Mobo: aBit p35 pro, Ram: 4GB (2x2GB) Corsair twinx 5-5-5-18, Hard Drive: 1tb Seagate Barricuda, Video Card: EVGA 260 GTX superclocked, Monitor: Acer 24 - P243w 1920 x 1200, Operating System: Windows Vista home premium 64 bit, PSU: Ultra X2 connect 550 - modular, Case: Thermaltake armor, black interior, Razer DeathAdder, g15 v1.
mansueto is offline   Reply With Quote
Old 4th Nov 2009, 14:53   #14
Agressions
Reverse/srvR
Agressions is on a distinguished road
Lovely work Frenky, maybe you should create some-sort of lines between the large parts.
So it looks like sheet-metal with the parts welded on..
Agressions is online now   Reply With Quote
Old 5th Nov 2009, 10:56   #15
Frenkie
Lets mod the world!
Frenkie's Avatar
I know what you mean. I've seen a SciFi model last week, with fake panels and rivets painted on. It looked really good. The model was silver-metal colored though, and my color scheme is egg-shade black. Stealth planes have no rivets and panels, it stealth-i-ness wouldnt work I guess.
Thanx for thinking though!
OT ( Hey Jos, can you fix your pictures in your worklogs? )
__________________
Old 5th Nov 2009, 16:57   #16
DeltaFX
Modder
DeltaFX is on a distinguished road
Nice, but the greebles look weird. It's either too much or not enough, I can't figure out the scale of the model. Oh, while you're at it, please close this cockpit....
DeltaFX is offline   Reply With Quote
Old 5th Nov 2009, 17:39   #17
Frenkie
Lets mod the world!
Frenkie's Avatar
Adding egg-shell black to the mod.
And here is the end result;
The contest voting starts tomorrow, Im really eager to see what the others have made!
I hope you liked reading this worklog as much as I have enjoyed making it.
Frenkie
__________________
Old 5th Nov 2009, 18:18   #18
Agressions
Reverse/srvR
Looking great! I totally see why you didn't add the panel-look. This looks great as it is.
It seems you forgot to paint the back of the big fan, but this gives it a special effect.
I'm probably starting a new log soon, those builds aren't really impressive, the last one was destroyed in a fire while it wasn't even finished..
Old 5th Nov 2009, 22:17   #19
bigsharn
Ultramodder
bigsharn's Avatar
I love it! Especially the salvaging of the model planes
__________________
Old 5th Nov 2009, 22:21   #20
DeltaFX
Modder
But I don't see how the rear fan is going to suck fresh air....
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
