#1 | ||
Likes modding doesn't like bullies
Win 7 0x80070570 install error EASY FIX
If you just want the solution page down .. it's in this blue
![]() New shiny windows 7 disk arrives. ...... doesn't want to install ...keep getting error message 0x80070570 when Windows 7 is expanding files: Quote:
Then I see a lot of people reduced to trying to install from a USB key .... great .... borrow my neighbours 4GB Cruzer, follow instructions, ... and bork it in the process of not installing the OS. So eventually I call Microsoft and speak to a very nice lady in India who runs me through a dozen or so workarounds for this .. I'm pressing control +F keys left, right and centre, taking out RAM sticks, disabling EVERYTHING in BIOS. Always the same thing: Quote:
EASY SOLUTION: I don't wait weekends for answers (nor do I usually need to call tech support). One thing we had noticed is that the repair console refused to lauch because it said there was an install in progress. But the support didn't pick up on this and it wasn't until Saturday morning I tried what turned out to be the easiest solution ever. When you see the error "0x80070570 can't access files" on install click --> OK ---> you will be returned to the "Install Now" startup screen and - WITHOUT REBOOTING - just re-start the install. Second time round it went smooth as clockwork and installed fine. I have not tried to reproduce this error as I just want a working system :P Be interested to know if this easy solution works for anyone else. I informed Microsoft of it when their engineer called today and they are going to look into it. They are aware of the install issue but never heard of this fix before. Crazy B
__________________
Life can be brutal - we have a choice. Fractal Design R4, i5 2500K (Sandy Bridge), Gigabyte Z68AP-D3, OCZ ZS650W PSU, Sapphire HD5670 1GB,
16GB Corsair DDR3 1600 XMS3, OCZ Vertex 4 128GB - System, 1TB Seagate Barracuda - Data |
#2 |
What's a Dremel?
hi..
tried the solution u placed, got the same issue.. trying it again.. but seems like the same error is coming up.. any other suggestionss..
#3 | |
My instructions were off. You cancel the install which returns you to the "install now" screen with NO REBOOT then just click install again ... If that doesn't work then look here: http://www.sevenforums.com/installat...-problems.html If the disk is sticking at 62% then a fix has been released (in link above). Also some people have found resetting the CMOS simply clears the problem. You might even have a bum disk. Crazy B
__________________
#4 |
What's a Dremel?
Hi, i have the same problem with installing window 7 on my new pc (custom build) i have try to do everything above but still can't fix the problem. So, if the file is corrupt. How come with the same disc i can install it on my different computer but not to the one i'm just build? Thanks
#5 |
Neuken in de Keuken
Have you tried a different DVD drive in your PC?
#6 |
What's a Dremel?
crazy B you are right, actually i am supporting the suggestion you gave about windows 7 installation error. i faced the same problem and did the same thing that you have suggested here to do.
#7 |
What's a Dremel?
I was replacing Fedora with Windows 7.
After hours of unrelated problems with my bios, I finally got it to boot from the installation disk. I repeatedly got the same error as Crazy B. I spent DAYS searching Google and trying EVERYTHING before I found his post. Worked first time. Thanks |
#8 |
What's a Dremel?
I get this error when trying to do a backup on Windows 7, reason is because the file or directory is corrupted & unreadable. I downloaded a program, Paretologic PC Health Advisor, but following the system scan, it says that I have to register & pay to fix all the problems it found, is there a freeware alternative which can do exactly the same as this program does?
#9 | |
What's a Dremel?
Hello all. I see this is still an active thread. Some of you are getting the error 0x80070570 .
I was able to take the original vista sp1 wim, and place it on a Vista SP0 install disc from a Dell Vista 32bit Business cira 2006 Disc . I had the change the FLAGS option in IMAGEX, to fool the installer. I set the flag to "Business" like the DELL wim used. The recovery wim was then tested in Oracle VM. IT work great. The trouble i am running into is SP1 wim works, but the SP2 wim, which i 'captured' 3 or 4 times results in that hex error. What am I doing wrong? how can SP1 work ok, but SP2 falls on its face @ "Expanding files"? |
#11 | |
Hey What Who
#12 | |
Multimodder
Should have learned from work - we see the same sort of thing with TVs, unplugging and allowing all electricity to drain from the system works 50+% of the time...
__________________
Gaming Rig - Win7 Ult/XP, Antec 1200 v3, Q9650 @3.6GHz, 4x2GB DDR3 1600MHz, Asus P5E3 Deluxe WiFi/AP@n, 2x500GB Seagate Momentus XT, Asus nVidia 660Ti, Coolermaster Realpower M620, Dell U2410. HTPC - Antec Fusion Black, Intel Pentium G630T, 2GB MSI Geforce GT610, 4x4GB DDR3, Gigabyte H77M-D3H, OCZ Agility3 120GB SSD, Drobo S with 15TB, Blackgold 3650, Seasonic X Fanless 400W. Toshiba NB550D with 4GB RAM, Samsung 830 256GB SSD. Surface RT 64GB |
#13 |
What's a Dremel?
Windows Win 7 0x80070570 install error EASY FIX
Originally Posted by poosplat View Post
I was replacing Fedora with Windows 7. After hours of unrelated problems with my bios, I finally got it to boot from the installation disk. I repeatedly got the same error as Crazy B. I spent DAYS searching Google and trying EVERYTHING before I found his post. Worked first time. Thanks |
#14 |
What's a Dremel?
Thanks you!
I have spent two days trying to get windows 7 to install on a clean drive and this is the only trick that worked. Thank you so much for sharing it!
#15 |
What's a Dremel?
I found a solution
I recently had this problem. Found out that it had to do with the jumper settings. My CD-ROM had the jumper set to master and my hard drive was set as slave (no jumpers). All i did was set both jumpers on the drives as cable select.
**NOTE**I received this error having a setup of 1 CD-ROM attach to 1 Hard Disk and initially having only a jumper set as master on the CD-ROM and having no jumper's on the hard disk (making it a slave). The Solution to the problem: 1. Take out both drives 2. Remove the jumpers, and place both of drive's jumper settings to CS (cable select) 3.Reinsert and boot up 4.Install windows 5. It might fail half way or at some point and will reproduce the same error message but DON'T restart, just go back through the installation process again. 6. Wait and hope it installs the second time If anyone is still having problems, let me know ***I'm 100% sure that the jumpers were to blame because I actually try to go back to my initial setup and it failed. |
#16 |
What's a Dremel?
Thank u Crazy B..... It worked 4 me...... Thanx alot....
#17 |
What's a Dremel?
When I get the error message I get no option to "cancel", only the "ok" button. I tried it both booting from USB & DVD with the same results. My memory & HDD test passed and my CMOS is cleared. Any help on this would be greatly appreciated.
#18 | |
What's a Dremel?
#19 |
What's a Dremel?
Hi
This does not seem to be working for me. Quite annoying actually. Got some more tips? Realize this thread is a bit old, but all the google references about this error gets pointed in here. Thanks |
#20 |
What's a Dremel?
This did not fix it for me :/
| Tags |
| 0x80070570, easy fix, install error, windows 7 |
| Thread Tools | |
