RSS
Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 4th Nov 2009, 05:30   #1
Ravenheart
Supermodder
Ravenheart's Avatar
Ravenheart is on a distinguished road
PSU Question, is this normal?
I recently bought a Corsair TX 850 Watt PSU and it runs perfectly fine but when I switch my pc off I hear what can only be described as if someone starts rolling their tongue while saying the letter R, kind of like a motor powering down or the PSU fan just catching something for a brief second inside the PSU when I shut down but the sound literally only lasts about 3 seconds.
And I don't want to be voiding the warranty by having a look inside the PSU just to make sure nothing is catching.
Does anyone have any ideas please? also the saying of the letter R thing I mentioned, just say the letter R while rolling your tongue and you'll get the sound I'm talking about , I know it sounds stupid but that's the only way I can describe the sound.
Anyway any help or info would be appreciated because RMA isn't an option as the PSU works fine so they wouldn't find a fault with it anyway, it's just that sound that's making me wonder what the heck it could be.
__________________
i7 860 @ 2.80ghz/4gb ddr3 ram/Gtx 275 gfx/1TB Samsung F3/320gb sata hard drives/Enermax Revolution 850w PSU
Ravenheart is offline   Reply With Quote
Old 4th Nov 2009, 05:56   #2
GoodBytes
mother into a board?!
GoodBytes's Avatar
GoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to all
This is not normal. RMA the power supply. It sounds like the fan motor has issues. And you don't want the PSU overheat, if the fan fails on you, as it may damage your computer component when it shutdowns due to overheating. Prevention is better than fixing... well replacing in this case.. not to mention cost more. And I remind you that Corsair won't cover your computer, JUST the PSU. Now, in reality they are security messures, but what if they are faulty?
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro!
GoodBytes is offline   Reply With Quote
Old 4th Nov 2009, 10:55   #3
Ravenheart
Supermodder
Ravenheart's Avatar
Thanks for the reply Goodbytes,
Anyone else had this issue then? And would you agree with Goodbytes about rma'ing the PSU?
The only problem I have with that is I don't have another PSU to put in my PC while that one is being rma'd, do you think if I rang Ebuyer and explained that I need my PC for work purposes that they would agree to collect the potentially faulty one and at the same time have a replacement sent out/brought to my house at the same time?
I know that's probably doubtful but just thought I'd ask
__________________
Old 4th Nov 2009, 11:30   #4
DragunovHUN
Never did a proper mod in his life
DragunovHUN's Avatar
DragunovHUN has a spectacular aura aboutDragunovHUN has a spectacular aura about
Definitely RMA it, but with the retailer not with Corsair as their EU depot is in the Netherlands and they won't cover shipping both ways.
DragunovHUN is offline   Reply With Quote
Old 4th Nov 2009, 12:38   #5
Ravenheart
Supermodder
Ravenheart's Avatar
Thanks for that Dragunov,
What do you think ebuyer might say then about the whole rma situation? RE: My suggestion in post 3, because I mean no testing should be needed as it's as simple a fault as mentioned, the psu does work it's just the fan motor obviously has some sort of issue where it has to make the noise mentioned in the 1st post when the pc is shut off.
P.S) I never even knew a psu had a fan motor! lol
__________________
Old 4th Nov 2009, 15:17   #6
Big Elf
I broke my Dremel
Big Elf's Avatar
Big Elf is on a distinguished road
You could try loosening the fan screws by a quarter to half a turn.
Big Elf is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
