#1 |
What's a Dremel?
Kettle lead/PSU questions
This system:
Asus P5KC 4GB Crucial Ballistix DDR2 800 nVidia 8800 GTS 320Mb Intel Core 2 Duo E8400 3GHz Intel 80Gb X25M SSD 2x Hitachi 160gb old HDDs Vista x32 recently replaced with Win 7 x64 Seasonic SS 650HT (650w PSU) Both vista 32 and win 7 64 had problems with hanging on startup. Particularly bad starting from cold (rather than reset.) It would hang during initial MS screen e.g. green loading bar in vista or 4 multicolour light thing in win 7. I was using ms config to selective startup to try to identify the problem but got rid of all non-windows programs and processes without helping. While doing this the system suddenly failed to POST. It is still in this situation despite change of Mobo. I have tried the GFX card in another computer and it seems to be working fine. On power on the fans all spin up, hdd LED flashes once but there is no output to the screen and no POST. There are no mobo failed POST bleep signals either. Should the system still POST if the processor is fried or is this more likely to be a PSU problem? Does anyone have any idea what is going on? Cheers. Written from my laptop! Last edited by nsymons; 7th Nov 2009 at 00:14. |
#2 |
What's a Dremel?
Could be MB but from personnel experience sounds more like a faulty memory stick
#3 |
What's a Dremel?
I have 4 x 1Gb Crucial balistix DDR2 800
I have tried booting with just one stick of RAM and swapped them around so I don't think that's it TBH. |
#4 |
What's a Dremel?
Does anyone know?
Will a mobo begin to POST if the CPU is dead or will I just get a black screen as described? |
#5 |
Multimodder
Granted it's been a while since I've had a dead CPU, but if I remember correctly a mobo will *not* POST if the CPU is bad/dead just as if it wasn't in the socket at all. If you got another one around that'll fit the socket that you know works, swap it in just to see if it posts.
#6 |
What's a Dremel?
Yeah, that's the problem
![]() No other CPU and no other PSU to use to check it out Will probably try Tottenham Ct Road computer fair tomorrow. I think there may be some guys there who could test this out for me and possibilities to but kit to replace dead parts. |
#7 |
What's a Dremel?
Woo hoo.
Found the problem, Blown fuse in kettle lead to PSU. Found it more or less by accident "it can't be the lead but I've tried everything else so what the hell..." ![]() I was using a 10A rated lead with a 5A fuse (as supplied) but I suspect it came from a printer or something waaaaay back when. It doesn't seem to b up to powering my whole system. Question: what rated kettle lead (in terms of ampage) do I need to run the system above? Cheers |
#8 |
New Build Project 100% Complete
5 amp fuse shouldn't have blown with your 650w PSU unless it is shorting.
Also, if the fuse had gone how would it have even powered on?
__________________
Intel i7 920 D0 @ Stock, Titan Fenrir Cooler, Cooler Master HAF 932, Corsair 6GB Dominator 1600mhz, XFX Radeon HD 4890, Samsung SpinPoint F3 1TB, Win 7 HP 64Bit. |
#9 |
What's a Dremel?
Well I've put a new 13A fuse in and it seems to be working again.
Initially I was getting dodgy hangs on startup, especially when booting from cold instead of restart. Then the system failed to POST, fans would spin up but screen would stay blank, no POST failure bleeps. Finally it stopped providing any power alt all. Seasonic 650W PSU says it draws up to 10A on the side of the case so I guess it could blow a 5A fuse. Slightly concerned having a 13A fuse in a cable only rated for 10A but if the PSU only draws 10A max and 650W is a bit of overkill for my system anyway so I hope I should be OK. |
#10 |
Don't panic!
A 10A max kettle plug sounds a bit weird - they're designed to comfortably cope with >20amps to avoid resistive heating etc while carrying 13A for a kettle.
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#11 |
What's a Dremel?
I have a couple like that. check out the plug that goes into the PSU. I have 2 the same that both have 10A embossed on them, as does the one in the back of my LCD TV.
#12 |
Don't panic!
Weird. You would've thought, being compatible with a kettle they would be much higher rated than that.
__________________
#13 |
Multimodder
Only thing that worries me here is why you're using a Kettle lead for your pc? Don't you have a normal psu power connector? Or are you actually referring to that as a Kettle lead?
__________________
i7 860 @ 2.80ghz/ 4gb ddr3 ram/ gtx 275 gfx/ 1tb/320gb sata hard drives |
| Ravenheart |
| View Public Profile |
| Find More Posts by Ravenheart |
#14 | |
Supermodder
therefore Current = Power/Voltage Assuming you are in the UK, on the primary (230V) side of the transformer the current will be: Current = 650/230 = 2.83 A I would put a 5A fuse back in. It could have been a dodgy fuse. |
#15 | |
Deaf forever to the battle's din
There are also cloverleaf and figure-8 connectors for laptop power bricks.
__________________
ASUS M4A785TD-M Evo | AMD Phenom II x4 955 BE | D-Tek FuZion
4GB Corsair XMMS3-10666 | Corsair TX650 Point Of View 8800GTX | EK FC-8800 |
#16 |
I *am* a Dremel
Everyone calls it a kettle lead because most first saw one plugged into their kettle.
The connector is offically an "IEC 60320 type C13" The true kettle plug is a type C15 which has a higher temperature rating (120C vs 70C).
__________________
Q6600@3GHz / AC Freezer 7 Pro / Gigabyte EP35-DS3R / 8GB OCZ Platinum PC6400 / EVGA GTX260 SSC / LG DVDR / 9TB HDD /
OCZ Modstream 780W / CoolerMaster 590 case / Dell E248WFP / Saitek Eclipse II / Logitech G9 / Ubuntu 9.10-64 |
#18 |
It's Big, and It's Clever
If you now have a 13A fuse in it, be careful, because that's much higher rated than you need, and it may not blow should a problem require it to do so.
Every PSU lead I've seen has had a 5A fuse in it.
__________________
Intel i7 920 @ 3.8GHz ¦¦ Asus P6T Deluxe ¦¦ 6Gb Corsair Dominator C8 ¦¦ XFX GTX295 ¦¦ 2x 1Tb Samsung F1 ¦¦ 1x Seagate 7200.11 1.5Tb ¦¦ Gigabyte Odin 800W PSU ¦¦ Dell 2405FPW.
#19 |
I'm not a modder.
Actually I don't think so. "Normal" PSU leads are cold IECs rated to 6A or 10A usually, depending on the cable diameter. Kettle leads have a little notch out of them and are rated to 13A I believe
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#20 |
I *am* a Dremel
Smooth = 6A (C13)
Notch = 10A (C15)
__________________
| Thread Tools | |
