#1 |
What's a Dremel?
New Build Advice
Here's a nice simple question for my first post...
I'm building a new system, it will be used for everything other than gaming...and I do mean everything (well, everything I can imagine anyone ever doing with their PC). Here's my spec list...
What does everyone think? Can you make any suggestions? Anything you would add/remove? All suggestions welcomed gratefully. Cheers
#2 |
Supermodder
From the system you have posted I am guessing you are not limited by your budget.
A 1250W PSU is way over the top. If you want to stick with the Enermax Revolution go with the 850W model. |
#3 |
hc/w=hf=e
The Corsair case is really quite terrible for air cooling. I'd suggest either the Antec 1200 or HAF 932. As for graphics power, well crossfire or not HD5770's don't have much going for them ( Seem to be not much over the stupidly out of date GTS250/8800 GTS ).
__________________
Core i7 920 D0 @ 3.5GHz , Titan Fenrir /./ EVGA GTX 285 SuperSuperClocked -SLI- /./ Asus Rampage II Extreme X58 + Supreme X-Fi /./ Corsair Dominator 6Gb @ 1758MHz CL 8 9 8 20 /./ WD Velociraptor 300Gb /./ 1Tb Samsung Spinpoint F1 /./ Enermax Revolution 85+ 1050w /./ Antec 900 V2I modded a Womble
#4 |
can't be arsed...
Now that is a very nice set up mate..
^and i disagree.. The 800D is an amazing case Got mine this week - a dream to work with. Cable management is outstanding & Cooling is great. Added 3 extra 120mm to the top of case as well. Read this review: http://www.guru3d.com/article/corsai...-review-test/1 Bought a Corsair H50 CPU cooler with it as well. All looks good... Go for it
__________________
Intel i7 920 D0 @4.0Ghz - Corsair H50 - 6GB Corsair XMS DDR3 1600 - ASUS 6T Deluxe v2 - 1TB Samsung F1 - 2 x XFX GTX260 Sli - Corsair 750w - Corsair 800D(its massive) - Dell 2209W 1920 x 1080 |
#5 |
Supermodder
The HD5770 is a difficult one. On one hand it is not the most powerful card around in its price bracket. On the other hand it is DX11 compliant and it does scale well in crossfire. Two HD5770s will cost around the same as one HD5850 and will perform better.
#6 |
FFXI Asura Server - Blackstarr
save the money get 5850 and lower the PSU down to 650W.
also make sure the samsung 1TB are F3 revision not F1 now. |
| adam_bagpuss |
| View Public Profile |
| Find More Posts by adam_bagpuss |
#7 |
can't be arsed...
surely he's need a higher PSU for running that lot..
ok running Ati lowers the level, but still more than 650w... 850W min i'd say
__________________
#8 |
Supermodder
#9 |
can't be arsed...
not a lot..
future proofing.. 650W just seems a bit low for running all he wants.. and for the sake of a few quid more. also if he changes from Ati to Nvidia then he will need it - Sli/Dual card etc ok 750w - i'm running on this and all is fine.
__________________
#10 |
im running a i7 920 @ 4Ghz with a 1GB 4870 and 6GB of RAM with the usual rest as well.
ive got a 650W PSU and its more than enough. there is no need for anything bigger unless you have some specific need like SLI/xfire a million HDD and additional cards plugged in etc. |
| adam_bagpuss |
#11 |
Supermodder
If you allow 130W for the CPU and 100W for each of the graphics cards that comes to around 350W. I think you probably could get away with 650W.
As far as future proofing goes the move to smaller process nodes probably negates the need to have too much spare capacity in the power supply. |
#12 | |||||
What's a Dremel?
Thanks for all the responses, I'm impressed considering it's only been 24 hours and this board must see hundreds of similar questions!
OK, I'm gonna address some of the issues/questions raised so far.. Quote:
Which leads me onto.... Quote:
Noted, Thanks. Anymore advice guys? I'm particularly interest in opinions on the GFX and RAM choices I've made. |
#13 |
What's a Dremel?
List now edited (first post)
Awaiting Mod approval on follow-up post?? |
#14 |
can't be arsed...
Nice
Seems that your all sorted... You'll enjoy putting that lot together & using it.. Enjoy
__________________
#15 | |
Richard Swinburne
bit-tech Staff
Man you really like Corsair don't you :P
Good brand, but lets not go over the top! Seasonic M12-D 850W or Enermax Revolution 85+ 850W: you will never, ever use this much power. Unless you plan on having FOUR graphics cards. Corsair is expensive memory in the UK: yea, it looks nice but you can get the same exact thing for less so shop around. You don't need the cooler for it too, it's completely unnecessary. For the cash you're willing to throw at the 1250W, expensive memory and two 5770s - wait until you can buy the 5850 and a 120GB SSD. Don't both with RAIDing those F1s and for the love of god please don't bother with CrossFire. The P6TD Deluxe is out now too, which replaces the V2: same price, tweaked design (again). Quote:
#16 |
can't be arsed...
Sorry Bindi
It was there... You do that.. kick it.. Well i love the case.
__________________
#17 | |
This is bit-tech!
I can't believe the number of people that are putting blind faith into the 800D just because it's made by Corsair and proclaiming it as the best thing since sliced bread. I can only assume that these people have never even heard of Lian-Li. I also can't believe how many people actually believe they need a 1250W PSU. You say it was an educated guess, but it clearly couldn't have been because if you had done a bit of research you would see that you wouldn't even need half that. You're basically throwing over £100 away, because you can get a top of the range 650W PSU for £100, and you will never draw more than 600W from that 1250W PSU with that system. When will people learn that more Watts =/= better? Even for future proofing it doesn't make any sense; the new technology is actually reducing power consumption considerably over the previous generation, and that will only decrease with further die shrinks etc. |
#18 | |
Supermodder
#19 | |
This is bit-tech!
#20 |
Supermodder
I said the performance was better, not that is was good.
You are quite right though, there are a lot of cheaper cases that have far better thermal performance than the Obsidian. |
| Thread Tools | |
