#1 |
That is substantially correct.
Assistance Please
I have had quite a bit of help on this forum with the spec for my first build but unfortunately, recently the help has stopped and i havent finished with the spec, so i was wondering if you guys and gals could give me this one last bit of reassurance that this build will work and that im getting enough power for my buck. The budget is £850 for everything, monitor and OS.
Here's me final plan:
__________________
:: Intel Core i5 750 @2.66GHz :: G.Skill Ripjaw 4GB 1600MHz ::
:: Asus P7P55D LE:: Undecided GPU :: :: 500W SeaSonic :: Antec 300 :: :: 500GB Samsung Spinpoint F3 :: 23" LG Full HD 1080p :: Last edited by Mystiik; 6th Nov 2009 at 18:04. |
#2 |
This is bit-tech!
I would:
1. Swap the HDD for a Samsung F3 500GB/1TB. 2. Drop the RAM and get this set. 3. Consider dropping the 5770 for the cheaper and generally faster 1GB 4870. Oh, and XP? Are you insane? Swap that out for Windows 7. |
#3 | |
oh and why get windows 7, i only have £850budget...
__________________
:: Asus P7P55D LE:: Undecided GPU :: :: 500W SeaSonic :: Antec 300 :: :: 500GB Samsung Spinpoint F3 :: 23" LG Full HD 1080p :: |
#4 | |
This is bit-tech!
HDMI input? Do you mean HDMI output? Well, that varies depending on the manufacturer but generally no, they usually come with 2 DVI ports, so you could just use a DVI --> HDMI cable/converter. Because it's not a horribly outdated OS, better features, better user interface, DX11 support, and last but not least the ability to use all of your RAM (amongst other things). Buying a 32-bit OS in this day and age is madness; out of an £850 budget it's easily worth the extra £10. |
#5 |
Yes i meant output :P I didnt even bother looking at F3's until now, they sounded very expensive. Common naivity... I didnt know that you could just convert DVI to HDMI, is the quality the same as straight HDMI. Last thing, you sed that buying a 32-bit OS these days is madness, does this mean i need to buy the 64-bit ?
__________________
#6 | |
Doesn't know his RSS from his elbow
No, in all seriousness, a 32-bit OS can only address (use) less than 4GB of RAM, amongst other limitations. They are to be avoided. Also you would have to be insane to buy XP when the vastly more advanced and generally well-received 7 is only a tenner more. Buy 7 x64.
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE1366, Asus P6T Deluxe, Corsair TR3X6G1600C8D @ XMP, XFX GTX-280,
Samsung SpinPoint F1 640GB, Corsair TX850W, Lian-Li V1000B+ with 3x Noctua NF-P12 & NZXT Sentry LX 2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB SSD |
| PureSilver |
| View Public Profile |
| Find More Posts by PureSilver |
#7 |
Okay, so apart from that it's all good ?
__________________
#8 | |||
This is bit-tech!
#9 |
Thank you very much, i will post the final list in a sec and will get my parents to order it tomorrow :P Can't wait.
__________________
#10 |
__________________
#11 |
Parents? If you're a student you can get W7 for £30.
__________________
| PureSilver |
#12 | |
__________________
#13 |
Looks good although if you can, I would get a cheaper OEM processor and get a decent heatsink (the supplied one will suck, really, really badly). Does the 300 need any further fans? I don't know what it's supplied with but you will need one intake and one exhaust.
__________________
| PureSilver |
#14 |
I'm Freakin out..... man
the 300 comes with mounting points for 2 front 120mm fans, but no actual fans....
pick 2 up if you can, along with a decent aftermarket heatsink for that processor
__________________
Current System- XFX 780i SLI Mobo, MSI 8800GTS, Q6600, 8GB OCZ RAM, 250GB Seagate HDD + 2x 160GB Seagate HDD's, 1000W OCZ PSU, Running W7 Ultimate x64 Laptop- Toshiba Satellite (M115-S1061), 75GB HDD, ATI GFX, 2GB Corsair RAM, Running W7 Professional x32 |
#15 |
What's a Dremel?
Unless I have missed something, this may worth considering as a monitor:
http://www.scan.co.uk/Products/23-Ac...5ms-Height-Adj |
#16 | |
This is bit-tech!
#17 |
What's a Dremel?
Fair point. I think I would take the £30, and use a dvi-vga adapter, but that's just me (and i happen to have an adapter lying around).
edit: Then possibly spend that £30 upgrading to a 4890. I did just do a bit of reading though, and I think that, in hindsight, I bow before SMC's wisdom. Last edited by bigdunge; 6th Nov 2009 at 23:46. |
#18 |
VGA's not worth it if you have DVI outputs on the 'card; why go to all the trouble of buying a decent 'card to then lose it all in translation?
Looks like you needs some fans and a heatsink. BT's 'what hardware should I buy' and 'what's the best 120mm fan' should solve those...
__________________
| PureSilver |
#19 |
Ultramodder
for you heat sink buy the titan fenrir only £30 for one of the best cooler on the market
http://www.scan.co.uk/Products/Titan...366-K8-AM2-AM3)
__________________
q6600 water cooled/msi p45 platinum/1gb dominator and 2gb giel/8800gt/nzxt panzerbox/vx550w corsair |
#20 |
REMEMBER: Budget £850
Im glad someone noticed that othewise I wouldnt have noticed! Where can i save money to be able to afford 2 fans and a heatsink ?
__________________
| Thread Tools | |
