Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 8th Nov 2009, 08:16   #1
gingbeard
Minimodder
gingbeard has yet to learn the way of the Dremel
Mini ITX
Im looking at building a mini-itx pc with a Atom 230 1.6GHz CPU and 1gig of ram. Will this be able to play .avi files ok? What are the advantages / disadvantages to mini-itx?
gingbeard is offline   Reply With Quote
Old 8th Nov 2009, 08:25   #2
Moyo2k
AMD Fanboy
Moyo2k's Avatar
Moyo2k has yet to learn the way of the DremelMoyo2k has yet to learn the way of the DremelMoyo2k has yet to learn the way of the DremelMoyo2k has yet to learn the way of the Dremel
yar, it will manage .avi, if you get some decent onboard graphics it will manage blu-ray even...
Moyo2k is offline   Reply With Quote
Old 8th Nov 2009, 08:36   #3
gingbeard
Minimodder
"manage" makes it seem like it might struggle...
Old 8th Nov 2009, 08:37   #4
steveo_mcg
STILL ALIVE
steveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for presidentsteveo_mcg should be considered for president
Nah it'll be fine, the cpu usage will be up around 60-80% but there is still a bit of leg room for web use or the like.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 8th Nov 2009, 09:19   #5
Moyo2k
AMD Fanboy
Moyo2k's Avatar
yes, but it will have to be chrome, firefox with addons demolishes even mobile Core 2s
Old 8th Nov 2009, 10:30   #6
gingbeard
Minimodder
To be fair, when I have a .AVI running, That'll be all that needs to be running - no need to run a .AVI on the tv (using the VGA cable) aswell as running chrome/firefox...
Old 8th Nov 2009, 11:09   #7
gingbeard
Minimodder
Is crome good then? Worth having?
Old 8th Nov 2009, 13:53   #8
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.PureSilver is a hoopy frood who really knows where their towel is.
Chrome's very simple, very stripped back, and not as modifiable as Firefox. I like it because it seems quite resilient and it's really simple.
With regard to the PC, it's difficult to give a definite answer unless all you will ever do with this thing is play .avi's. Is that it? What onboard graphics were you planning?
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 8th Nov 2009, 14:11   #9
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the Dremel
I don't find that at all. Sure, on my old laptop with a 1.8GHz Pentium M it struggles (thats the RAM (768MB holding it back I reckon) but my current one with a 1.8GHz Core 2 Duo, Firefox is fine.
To the OP - if you are thinking about the future, apart from getting a Via Nano, something with either or both of a dual core Atom or Ion might be worth thinking about.
__________________
i7 920, 5870, 6GB Corsair all in an Intel DX58SO; 60GB Vertex, 1.5TB F2; Fractal Design R2
ThinkPad Edge 13.
Cupboard is offline   Reply With Quote
Old 8th Nov 2009, 14:53   #10
gingbeard
Minimodder
Used primeraly as a torrent box. But used to play the DL'd torrents through a TV or monitor. Also to store Photos on. Nothing more other than perhaps facebook etc. No games, thats for sure
Old 8th Nov 2009, 18:40   #11
gingbeard
Minimodder
bump. Might be buying parts tomorrow morning
Old 8th Nov 2009, 18:46   #12
PureSilver
E-tailer Tailor
PureSilver's Avatar
Then it depends on the video chipset. Something like an NVIDIA ION will play everything - even HD content - but I don't know about the performance of the other integrated ones.
__________________
Old 8th Nov 2009, 18:50   #13
Perfectionist
What's a Dremel?
Perfectionist has yet to learn the way of the Dremel
I'm running Firefox 3.5.5 with Noscript, Better Privacy, Adblock Plus, Greasemonkey and IE tab on a spare PC, Pentium 4 1.3 Ghz and 1GB crappy RIMM memory at the moment and no slowness or problems at all.
Perfectionist is offline   Reply With Quote
Old 8th Nov 2009, 18:51   #14
gingbeard
Minimodder
Video chipset? I was just going to use whatever the above listed Motherboard had in it?
Old 8th Nov 2009, 18:58   #15
TheMusician
Audio/Tech Enthusiast/Historian
TheMusician's Avatar
TheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the DremelTheMusician has yet to learn the way of the Dremel
Video chipsets are becoming increasingly important because they're increasingly useful. Especially with Vista and 7, because their entire interfaces are accelerated and handled by the GPU. This takes a lot of load off of the CPU.
The next version of Flash player is said to be completely accelerated as well, which means Youtube and the like will be completely handled by the GPU. And trust me, even "low-end" dedicated cards can handle this kind of stuff just fine. As a result, Youtube and Hulu and HDTV video playback will be a piece of cake for a lot of PCs which have traditionally been too weak for (because their CPUs were too weak).
Most GPUs have been capable of doing all of this stuff for a long time, it's just now that we can finally use them for something other than gaming and 3-D work (and certain offline video playback applications).
__________________
DIY Desktop: Ph X4 960T (w/OCZ Vendetta), Gigabyte 785G, 8GB DDR2-1066, XFX HD4850, 64GB Crucial M4 + 640GB Cav Black, M-Audio 2496, W7 Pro x64
ASUS UL30VT-A1 Laptop: C2D SU7300, 6GB DDR3-1066, G210M, 500GB Sco Blue, W7 Pro x64
TheMusician is offline   Reply With Quote
Old 8th Nov 2009, 19:03   #16
gingbeard
Minimodder
OK guys. Here is my new question, that I wish to ask the masters of computer wizardry...
Basically, I have the choice between a second hand 2gb/360gb , nvidea graphics card (a decent one), coolmaster PSU DESKTOP from a work mate (£100), or a new MINI ITX PC that I will build myself with 1gb/360gb for £150. What should I do?
My reason for liking the mini-itx idea is that It would be used as a torrent box, and used as a tv, advantages being that is uses a lot less power. Advantages to the Desktop is that It'll do anything I ask of it.
HELP! lol
Old 8th Nov 2009, 19:06   #17
TheMusician
HELP! lol
What CPU does the second-hand machine have?
__________________
Old 8th Nov 2009, 19:16   #18
gingbeard
Minimodder
I believe its a Intel® Core™2 Quad
Old 8th Nov 2009, 19:18   #19
TheMusician
?? I'd definitely go with that. Unless you really care about saving a little on your energy bill.
The second-hand PC you just described is several times as powerful as the ITX build you were planning.
And considering it's cheaper than what you would build yourself, it's a no-brainer.
__________________
Old 8th Nov 2009, 19:21   #20
gingbeard
Minimodder
Yes, I suppose that you are right TheMusician. I will get the bigger, desktop PC and put my dream to loose my PC build virginity behind me... To pick up another day when I have more money to build me mini-itx ;p.
Thankyou.
Reply
Tags
mini-itx, miniitx
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
