Other Help Identifying an LED Sign Board.
Discussion in 'Hardware' started by Omalleh, 10 Nov 2009.
  1. Omalleh
    Omalleh What's a Dremel?
    15 Jan 2006
    Hello there,
    Long time reader of the Bit-Tech site, and regular forum reader.
    I'm looking for some help identifying an LED Sign board I recently acquired and didn't know where else to start asking/looking for help.
    I'd like to identify it because it currently lacks a power supply and a method of input.
    From what I know, the sign was removed from a call center several years ago.
    The sign has no visible branding, part or serial numbers except for:
    A little white sticker on the back by the connectors: "7352 00" but could possibly be "7352 DD"
    The physical size of the sign is 96cms in length and 11cms in height.
    With a visible LED sizing of 91.5cm by 5.5cm. LED's are 7 rows by 120 columns.
    The case of the sign is metal with plastic end caps.
    One end has a few different connectors:
    Input for a 3.5mm TRS Jack labeled Serial,
    a 5.5mm barrel connector labeled Power,
    a rectangular 14 pin socket for what looks like a ribbon cable labeled Keyboard Cable.
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    A picture is worth a thousand words dude, lets see it!
  3. Omalleh
    15 Jan 2006
    My apologies.
    Photo Showing the end of the unit with Serial Connector:
  4. Omalleh
    15 Jan 2006
    Stripped the Unit down and found:
    Data Display DL210-04.
    Now to find what PSU it needs and how to program it lol.
  5. Jutulind
    Jutulind What's a Dremel?
    21 May 2010
    Got exactly the same model with 9VAC power supply. Inside is HD6303RP processor running at 4.9152 mhz, so serial must be RS232 witn 300/1200/9600/76800 baud. But I got no soft for that either ...
    More markings at led panels -
    DATA DISPLAY
    DL210-04
    SHIP SM-1 D9511
    On processor board -
    SHIP SM1
    D9649
    on other side -
    DLPTSC REV 5.0
    Would also be happy for any further info. :wallbash:
    totalpunch likes this.
  6. totalpunch
    totalpunch What's a Dremel?
    12 Mar 2018
    I know it been a while since someone posted to this post.
    But we have 2 of the same LED sign.
    And no power supply, tried a few but cant get it to work properly.
    Was wondering what kind of mA your power supply has?
    Also did you found a way to program it ?
