Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 22nd Jul 2011, 21:50   #181
markc123
What's a Dremel?
markc123 has yet to learn the way of the Dremel
GTX 460 added to the cause.
557
markc123 is offline   Reply With Quote
Old 26th Jul 2011, 19:57   #182
hbeevers
Yes, it can play crysis!
hbeevers has yet to learn the way of the Dremel
Added my 460 at 850Mhz too
557
__________________
Core i5 750 @ 3.2Ghz @ 1.096V | 4GB ram @ 1600MHz | GTX 460 Gainward GLH @ 897/ 2000/ 1794 @ 1.987V
hbeevers is offline   Reply With Quote
Old 8th Sep 2011, 00:18   #183
big-bert
Multimodder
big-bert has yet to learn the way of the Dremel
2 x GTX 560 Ti
1 x GTX 580
Added to the cause
554
__________________
3930K @ 4.2 (24/7), H100, Rampage IV Extreme, G. Skill 16GB 2133
2700K @ 4.5 (24/7), NH-D14, Maximus V Gene, Vengence 8GB 1600
2600K @ 4.5 (24/7), NH-D14, P8Z77-m pro, Team 4GB 1333
GTX 560 Ti x 2 (24/7) on a 775 platform
Folding stats
big-bert is offline   Reply With Quote
Old 10th Oct 2011, 14:39   #184
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpit
HD6770 added a few weeks ago. Hoping to start adding a few GTX580 at the end of the year or early next year (on my new dedicated folding machine).
553
debs3759 is offline   Reply With Quote
Old 19th Oct 2011, 14:06   #185
meandmymouth
I *am* a Dremel
meandmymouth's Avatar
meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!
Just added an extra 460
552
__________________
Folding stats
meandmymouth is offline   Reply With Quote
Old 16th Dec 2011, 15:26   #186
OmightyOne
Multimodder
OmightyOne's Avatar
OmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the Dremel
just set up my two 260 gtx for 24rh use
550
__________________
The Tank - Intel i7 920 @ 4ghz - Nvidia 560ti F/OC (Main) Nvidia gtx 460 F/OC (Physx) - 6gb 1866mhz ocz Reaper Ram - F3 1TB - Coolermaster 850w slient pro - CM HAF case - Custom water loop!
OmightyOne is offline   Reply With Quote
Old 21st Dec 2011, 19:31   #187
debs3759
debs3759's Avatar
Just replaced my HD6770 with a GTX570 (overclocked of course!). Count remains the same, but I wanted to share my good fortune Current estimate (at 10% into my first wu with stable overclock) is just over 34K ppd, and it hasn't affected how much of the CPU is available for smp!
550
__________________
Folding stats
Old 6th Jan 2012, 09:52   #188
cave_diver
Modding Virgin
cave_diver has yet to learn the way of the Dremel
548
Thanks to DocJonz you can add an extra two GTX260's to the team
__________________
Folding stats
Folding with: E3400, U7300, Opteron, E6750, Athlon64, 8800GTX x 2, GTX260 x 2
http://piro.pirocast.net/badge/fah01...255/538862.png
cave_diver is offline   Reply With Quote
Old 13th Jan 2012, 09:59   #189
Scorpuk
Supermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Added 1 x GTX580.
547
Scorpuk is online now   Reply With Quote
Old 30th Jan 2012, 13:42   #190
BaskB
What's a Dremel?
BaskB has yet to learn the way of the Dremel
HD6850 added to the cause
546
BaskB is offline   Reply With Quote
Old 30th Jan 2012, 13:43   #191
BaskB
What's a Dremel?
Duplicate please delete
Old 12th Feb 2012, 20:15   #192
Mark_Skeldon
Multimodder
Mark_Skeldon's Avatar
Mark_Skeldon has yet to learn the way of the Dremel
GTX 570
545
__________________
i7 2600k @4.42GHz, | Asus Maximus IV Gene-z | 8GB G.Skill Ripjaws CL9 | GTX 570 @ 803/2002 | 128GB Crucial M4 SSD | Coolermaster RP Pro 1000w | Lian Li PC70 | Onkyo SR608 amp | Mordaunt Short components |
Mark_Skeldon is offline   Reply With Quote
Old 19th Apr 2012, 19:57   #193
Eldorado
Needs new glasses..
Eldorado's Avatar
Eldorado has yet to learn the way of the Dremel
I'm running a gtx460 and a gt430 (Eldorado-Bit-tech)
Eldorado is offline   Reply With Quote
Old 23rd Apr 2012, 22:43   #194
johnim40
Multimodder
johnim40 has yet to learn the way of the Dremel
3 gtx 460s
540
__________________
MAIN:i5 2500k@3.3:660GTXGAME:i5 750@2.6:P7P55DPRO:2x460GTXGAME2:i5 750@2.6:P7P55D-E:460GTXF1:E5200@2.5:P5N-E SLI:260GTX
Folding stats
johnim40 is offline   Reply With Quote
Old 6th Nov 2012, 11:27   #195
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.
1 x GTX660.
539
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML
xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB
dazzypops:Win8Prox64, i5-2500k@4.3, 8GB, 4TB, Samsung 840 Pro 256GB, MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1
Put my hands behind my head, crouch down and fall forwards - that's how I roll.
kenco_uk is offline   Reply With Quote
Old 8th Dec 2012, 20:21   #196
atc95
Need help with scratchbuild!
atc95's Avatar
atc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpit
1x radeon hd 7950
(and 1x radeon hd 2600xt when i work out how to set it up)
538
__________________
i5 3550 // gigabyte g1 sniper m3 // xfx 7950 dd @ 1ghz // 2x4gb C. Vengeance // samsung 256gb 830 // 750gb scorpio black // silverstone tj08be // enermax ets t40 tb // ocz modXstream pro 700w // Dell u2412m // IBM 17" tft.
Xbox PC mod (nearly finished): a10 5800k @ 4.6ghz, h100i, msi fm2 a75ia, 8gb samsung greens, 256gb sandisk ultra!
atc95 is offline   Reply With Quote
Old 1st Jan 2013, 13:10   #197
houch
Multimodder
houch's Avatar
houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!
gtx 275
537
houch is offline   Reply With Quote
Old 6th Jan 2013, 21:06   #198
BillyTheCat
Nuttier Bubbles
BillyTheCat's Avatar
BillyTheCat has yet to learn the way of the Dremel
2 x HD7700
__________________
Folding stats
BillyTheCat is offline   Reply With Quote
Old 25th Jan 2013, 10:40   #199
PAULWARDEN
Multimodder
PAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run CrysisPAULWARDEN can run Crysis
534 just added a 2nd gpu MSI GTX 560 TI 448
__________________
Folding stats
CoolerMaster HAF932 ,Gigabyte GA 990 FXA UD7,AMD FX 6300 clocked@4.5GHz,Corsair H80i,8GB ddr3 Crucial ballistix tracer 1866MHz , Crucial V4 256GB SSD , Samsung f3 1TB hdd , MSI N560GTX-448 PE,MSI N560-TI 448, Sapphire fire 625w psu , optiarc dvd rw
PAULWARDEN is offline   Reply With Quote
Old 31st Jan 2013, 18:05   #200
OutrageD
What's a Dremel?
OutrageD has yet to learn the way of the Dremel
Just joined the folding team and so bring my lowly HD7770
533
OutrageD is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
