Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 19th Nov 2009, 20:06   #1
dakota67
SOUTH DAKOTA MODDER!!!
dakota67's Avatar
dakota67 has yet to learn the way of the Dremel
Dakota Mod 2009
This is my very first Mod. I started it back about 10 months ago. I purchased the case on eBAY and painted it.
I started with a USED Cooler Master Cosmos S.
dakota67 is offline   Reply With Quote
Old 19th Nov 2009, 21:21   #2
Oreon_237
CHEA BRO!
Oreon_237 has yet to learn the way of the Dremel
no pics man, but from your sig, looks pretty sweet
__________________
Rigless.
Oreon_237 is offline   Reply With Quote
Old 19th Nov 2009, 23:48   #3
dakota67
dakota67's Avatar
BACK VIEW
PROJECT LOG..........
UNDER MODDING/PROJECT LOG/PROJECT DAKOTA PC
Old 20th Nov 2009, 01:41   #4
dakota67
dakota67's Avatar
Front panel almost done
Old 20th Nov 2009, 11:45   #5
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Awesome job Dakota! and the Tribal Flame grills look awesome
mnpctech is offline   Reply With Quote
Old 20th Nov 2009, 13:31   #6
dakota67
dakota67's Avatar
I love your Tribal Flame grills! I had your bulls-eye grill on the front before but I changed them all to the Tribal Flame. I do not have the front panel finished yet. I am still waiting on paint.
Old 20th Nov 2009, 13:40   #7
dakota67
dakota67's Avatar
ALL FANS ON THE CASE WERE REPLACED WITH XIGMATEK 120MM ORANGE/WHITE FANS.
ALL FAN GRILLS ARE FROM mnpctech.com TRIBAL FLAME...FAN GRILLS.
Old 20th Nov 2009, 13:46   #8
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
Wow, this does look great man! I love the color combination, and yes, Bill's grills fit the theme very well!
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 20th Nov 2009, 13:58   #9
dakota67
dakota67's Avatar
1. USED Self-Etching Primer from Walmart.
2. Spray painted with Kyrlon and Duplicolor paint.
3. let dry for two weeks.
4. wetsanded.
5. 3M Rubbing Compound, 3M hand glaze, Carnauba Wax.
Old 20th Nov 2009, 14:02   #10
dakota67
dakota67's Avatar
Inside isnt done yet. I am waiting for some parts from Performance-pcs.
I will post pictures as soon as more parts get in.
waiting on more lights, tubing, waterblock for the graphics card.
Old 20th Nov 2009, 17:11   #11
dakota67
dakota67's Avatar
Vinyl Custom Logo from local vendor.
TOP FANS
Old 20th Nov 2009, 18:04   #12
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
/snip
Lakota cross?
Colors are right. Yellow for East, White for South, Black for West, and red for North.
I like this mod.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 20th Nov 2009, 18:15   #13
dakota67
dakota67's Avatar
yes. Lakota use those colors.
Some dakota use the same colors, but Dakota use dark blue too.
I got the logo from a wacipi in Flandreau SD, but it was originally for my truck.
I decided to use it on my pc case.
Depends upon the meaning, I guess.
Old 20th Nov 2009, 18:17   #14
dakota67
dakota67's Avatar
I cannot find the guy who was selling the vinyl stickers..I wanted him to make another one for the window panel as well.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
