Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 22nd Nov 2009, 03:33   #1
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
mini-ITX case design question
How would you guys design a mini-ITX minimal system with motherboard, 2.5" SSHD or HDD, picoPSU, and NOT end up with a Mac mini or Dells new mini-ITX desktop? Most look like motherboard sized cases with rounded corners and height barely above I/O shield. 180mm to 200mm square, round the corners and call it done doesn't cut it. Boring.
Got any thoughts?
john
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Old 22nd Nov 2009, 03:52   #2
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
You're talking scratch builds only. An obvious exception is PC3
The key is utility - not many of us mod purely for the sake of it. We identify a need and mod to suit that need. For example, PC3 was built as an HTPC/Media center. 180 or 200mm square with rounded corners probably seems generic because mITX is a great HTPC platform and that's a shape/size that goes nicely in the living room beside the receiver/under the TV.
An exception was Cheapskate/Bill's epic Ion Cube - no constraints for utility and other silly things meant they could go do whatever they wanted.
__________________
stonedsurd is offline   Reply With Quote
Old 22nd Nov 2009, 04:35   #3
jhanlon303
jhanlon303's Avatar
We all love PS3 and the ION cube. What I was thinking is more in the line of commercial possibilities like the Nexus Psile. Niche commercial cases with features to attract mini-ITX builders.
Nexus is way expensive, the carputer cases to fit under a seat are pizza boxes with hetsinks.
How do we encourage manufacturers to cater to mini-ITX and smaller. The newest Zotac boards are more powerful that HP compact or Dell desk tops.
__________________
Old 22nd Nov 2009, 04:38   #4
stonedsurd
stonedsurd's Avatar
But all cases are boxes. Even if manufacturers do cater to mITX system builders, all they'll be doing is churning out 180x180x180 boxes.
__________________
Old 22nd Nov 2009, 04:54   #5
jhanlon303
jhanlon303's Avatar
why?
__________________
Old 22nd Nov 2009, 05:05   #6
stonedsurd
stonedsurd's Avatar
Manufacturing/financial concerns, I suppose?
They look at what people need, and an overwhelming majority are just after plain-looking black boxes to match their a/v equipment. It's simple to make, so they aren't complaining, and it's what everyone wants so if they make it, they're guaranteed sales.
__________________
Old 22nd Nov 2009, 05:25   #7
jhanlon303
jhanlon303's Avatar
What about Psile? A different approach but too pricey.
__________________
Old 22nd Nov 2009, 05:40   #8
stonedsurd
stonedsurd's Avatar
The Psile is not particularly innovative in terms of aesthetics - isn't it what you were lamenting upon in your first post? A box with rounded corners.
That's the real hurdle - how to build something innovative and _not_ mundane-looking without charging the earth and the moon for it.
__________________
Old 22nd Nov 2009, 10:19   #9
Moriquendi
Bit Tech Biker
Moriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the DremelMoriquendi has yet to learn the way of the Dremel
I think a lot of it comes down to materials and packaging. If you're working with metal then boxes are the easiest shape to make but plane boxes aren't fashionable at the moment so you round off the corners. Packaging is the other point, components are mainly rectangular cuboids, the most efficient way to fit them together is into a larger cuboid, there's no escaping that. If you were to go for a more interesting shape you would have to make the case larger than if you just made a box and at the moment, size is an important thing.
Moriquendi
__________________
My Deviance CAD and Photography.
My Project Log Making a one piece motorbike suit.
"Woman: without her man, is nothing" or "Woman, without her, man is nothing" Punctuation is important.
Moriquendi is offline   Reply With Quote
Old 22nd Nov 2009, 12:25   #10
bigsharn
Officially demotivated
bigsharn's Avatar
bigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysis
Well not necessarily, if you're after scratch building you can literally make it *just* big enough to fit the components in, then add extra fancy bits afterwards
Zotac 9300 mITX is 17x17cm, add a low profile heatsink and you're on about 17x17x3cm and this is about as small as mITX can go. I was looking into building an ultra compact case for photoshop on the go but I lacked funds and laptops are more plausible (board + PSU makes it around 15cm high and that still wouldn't fit in my bag )
__________________
{Rolling on a 1990s Dawes Galaxy}
{Nikon D80, 18-55 f/3.5-5.6G and 50mm f/1.8}{Lomo Smena 8M}{Olympus OM10, 50mm f/1.8, 28mm f/2 and 135mm f/3.5}
bigsharn is offline   Reply With Quote
Old 22nd Nov 2009, 12:40   #11
Sir Digby
The Supprising Adventures
Sir Digby's Avatar
Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.
I'd make it as low as possible, with it being wider or deeper to compensate. Maybe 35x20x3?
Sir Digby is offline   Reply With Quote
Old 22nd Nov 2009, 15:50   #12
jhanlon303
jhanlon303's Avatar
This is Thermaltake's new SD-100 mini-ITX case. My point is that it looks like a DVD player. No inspiration.
I would love to see someone like Bang and Olufsen do a mini case. They know style
__________________
Old 22nd Nov 2009, 16:15   #13
Sir Digby
Sir Digby's Avatar
That is nasty.
I'd like to see a Chiaroscuro inspired design, with the disk drive and power button stealthed behind panels on the front. Gaps between the panels that light up, dark wood, exposed dovetail joints.
Old 22nd Nov 2009, 16:15   #14
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
I've just ordered the Zotac ION ITX A-E as it has an integrated PSU and I'm facing the same little question.
A box of 20x20x??? cm is easy to build, but it's quiet unimpressive from a designPOV
EDIT: As we're at it, does someone own the Zotac ION ITX A-E and what cooling-solution are you using? I'm thinking of just slapping a Scythe 120mm 800RPM fan above the mainboard not using the 60mm fan that comes with the mainboard. Would this be enough cooling?
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is online now   Reply With Quote
Old 22nd Nov 2009, 17:47   #15
bigkingfun
Tinkering addict
bigkingfun's Avatar
bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.bigkingfun is a hoopy frood who really knows where their towel is.
You should take a look at their BeoMaster5.
Visit their site. You might just get some inspiration.
A mediacenter in a BeoCenter2 would be quite nice.
bigkingfun is offline   Reply With Quote
Old 22nd Nov 2009, 18:32   #16
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
the main issue with B&O is the price to be honest. You pay A LOT of money for a tv, which on the inside is basically Philips..
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is offline   Reply With Quote
Old 22nd Nov 2009, 20:13   #17
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
An Audi TT is nothing but a Škoda Octavia underneath. Aesthetics can justify a lot, although you're right, B&O are at the stratospheric levels of pricing...
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 22nd Nov 2009, 20:46   #18
Picarro
Picarro's Avatar
Atleast with the TT you get a better engine, and some nicer interior. With the B&O you get the same kind of plastic, and if you are lucky a couple of cm2 of aluminium
__________________
Old 22nd Nov 2009, 21:19   #19
13eightyfour
Formerly Titanium Angel
13eightyfour's Avatar
13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan
Other than rounding a few corners, from a mass production point of view there isnt alot else you could do without making the case bigger than it needs to be.
I actually like the design of the mac mini and mini dell studio.
A few years ago i saw a philips hifi and the exterior was covered in thick bright red rubber and i remember thinking i could squeeze a computer in that, but i never got round to buying 1 and now i cant find them anywhere
13eightyfour is online now   Reply With Quote
Old 23rd Nov 2009, 15:57   #20
bigkingfun
Tinkering addict
bigkingfun's Avatar
OffTopic: That is because B&O TV's is about the design and audio. I Challenge you to find a flat-screen TV with better audio than a B&O.
They are actually Samsung panels.
OnTopic: Regarding the mITX I would love to see a bunch of these boards in a cluster setup, like this one.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
