Reply
Thread Tools View Mode
Old 24th Nov 2009, 10:57   #1
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
PC-Beto ( 23-12-2011 - MOTY nomination!! )
hello bt! its time again!
PC-Beto
A big thanks goes out to the sponsors that have helped me out with hardware for this mod!
lets jump right into it. as usual i am modding an old used case!
the inspiration?
the case, and plans.
im going to watercool the system with a 3*140 mm radiator in front, and two pumps. as seen on the pics, the case is devided in 2 sections. the frame is going to be powdercoated in matte black.
this is some of the evelopment of the cad drawings i made. the big round one on the left is going to be a window.
and the finished drawings. the top drawings is going to be cut in foil, and the bottom one in green acrylic. since ac-ryan didnt reply on my mails, I found the same acrylic that they uses (for 1/4 the price) and will be using that.
finished middle plate
the middle plate is going to be bend around the frame, to give a smoother look
the little room in the top will be sealed off, and most likely used for 2 harddrives.
close up of the rad hole in the front
on this pic, the foil looks quite thick, but it wont be
the motherboard tray (yes, that old bucket have a removeable mobo tray!) is going to be made of 2 pieces of acrylic. black and green, and will look like this
for pumps holders, i designed a bracket, that will fit on 140 mm fans to hold the ddc pumps. with rubber grommets, theese should reduce vibrations too, and the cold air from the fans will cool them down a bit.
close up of the bracket.
hardware is yet to be decided. but for watercooling i will go for theese 2 for certain
2 ddc pumps
HWLabs black ice gtx 420 radiator
soo.. hoped you enjoyd this little start of my new project though it almost only consists of renders. more WILL come. (already got a lilī testplate cut out to play with )
-p0Pe
__________________
p0Pe is offline   Reply With Quote
Old 24th Nov 2009, 11:07   #2
Balder
Calmer than a monk on morphine
Balder's Avatar
Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.
hmm, might be just me but I cant see any pictures :\
EDIT: nvm, my workplace blocks your image host :doh
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem.
- Martin Luther King, Jr.
Balder is offline   Reply With Quote
Old 24th Nov 2009, 11:41   #3
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
I see the pics and they are grrrrreat!
Should be interesting to see how this turns out.
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is online now   Reply With Quote
Old 24th Nov 2009, 12:17   #4
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Oi p0pe. So, what is this? You post something in a worklog and then I post something in mine right afterwards?
No, seriously, this is looking good!
Oh, and "folie" is a danish word. I believe the english term would be "foil". Or that's perhaps the american term? Can't remember...
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 24th Nov 2009, 12:54   #5
p0Pe
gief cake?
p0Pe's Avatar
thanks all
nutman, guess denmark is on a streak with worklog output today then:P and thx for the foil correction!
__________________
Old 24th Nov 2009, 16:27   #6
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
I kinda like it with the thick cut out layer. I'm sure the foil will be cool too. I've always liked circuit traces, but never had the urge to draw them out like this. You rule.
Cheapskate is offline   Reply With Quote
Old 24th Nov 2009, 16:58   #7
blt44
Long Time Lurker
blt44's Avatar
blt44 has yet to learn the way of the Dremel
This looks awesome. Can't wait to see you start constructing it!
blt44 is offline   Reply With Quote
Old 24th Nov 2009, 17:01   #8
bigsharn
Officially demotivated
bigsharn's Avatar
bigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysisbigsharn can run Crysis
I love the idea behind this, consider me subscribed
__________________
{Rolling on a 1990s Dawes Galaxy}
{Nikon D80, 18-55 f/3.5-5.6G and 50mm f/1.8}{Lomo Smena 8M}{Olympus OM10, 50mm f/1.8, 28mm f/2 and 135mm f/3.5}
bigsharn is offline   Reply With Quote
Old 24th Nov 2009, 17:43   #9
p0Pe
gief cake?
p0Pe's Avatar
haha thanks all and cheapskate, you wouldnt belive how many hours i put into thoose friggin drawings!
__________________
Old 24th Nov 2009, 19:28   #10
Xion X2
Multimodder
Xion X2's Avatar
Xion X2 has yet to learn the way of the Dremel
I'd believe it!
Nice work.
__________________
Project: r e f l e X i o n
Sponsored by: MNPCTech | DangerDen | Lamptron | Performance PCs
Xion X2 is offline   Reply With Quote
Old 24th Nov 2009, 19:28   #11
Sphering
Multimodder
Sphering's Avatar
Sphering has yet to learn the way of the Dremel
must agree with Cheaps, strange as that might seems to some, but curcuit traces are great. Was just admiring an old MSI mobo today. You know, one of the red ones ms-7037. The backside is really beautifull. This project is looking pretty as well.
__________________
One day...
Sphering is offline   Reply With Quote
Old 2nd Dec 2009, 23:32   #12
p0Pe
gief cake?
p0Pe's Avatar
hah yeah, i loved that theme for years now. so im really excited about building this thing
test panels sits behind me, and i just need to test how they bend lol. a little teaser
i was out of green acrylic lol.. so you have to live with blue this time + the foil is a bit off xD
__________________
Old 3rd Dec 2009, 09:23   #13
Nutman
Nutman's Avatar
MOAR!!!
__________________
Old 3rd Dec 2009, 14:18   #14
p0Pe
gief cake?
p0Pe's Avatar
haha nutman! not pics, but you can have this info
NEWSFLASH!
Proud to say, that www.CoolBits.dk is now sponsoring products to the mod! so next week i should be getting something to test fit in the case!
some of the parts:
more will come, when i get my act together and decide what hardware to use
2 x AC watertemperature sensors
1 x HWLabs Black Ice GTX 420
1 x Laing DDC-1T Plus
1 x EK-DDC X-TOP rev.2 Acetal
5 x Noiseblocker NB-BlackSilentFan XK1 (140mm, 11dBa)
i am still struggling with the thought about going dual loop, and throw a HWLabs gtx 280 in the bottom.
__________________
Old 4th Dec 2009, 04:44   #15
The Twisted One
Minimodder
The Twisted One's Avatar
The Twisted One has yet to learn the way of the Dremel
Dam nice idea , Ive often had a similar idea when i look at my MB . Plan looks primo . subed
The Twisted One is offline   Reply With Quote
Old 4th Dec 2009, 05:04   #16
Nutman
Nutman's Avatar
Sweet! What kind of sponsorship? Full sponsorship, or just chipping in? And what do you have to do to get that sponsorship?
Nice, I have the same parts. You got an Aquaero, too?
Since you're designing the case, won't you be able to fit 2 480 mm. rads in there? If the first one goes in the top, the second one should be able to go in the bottom? That way you'll also make sure that the same amount of air that goes in goes out again.....
__________________
Old 4th Dec 2009, 11:01   #17
p0Pe
gief cake?
p0Pe's Avatar
i havent gotten an aquaero yet, since i need to clarify some things with it first:P it seems, that it doesnt have enough power for my needs sadly. so if the koolance tms board, have fixed its software faults, ill be grabbing one of them
and yes, i would be able to fit 480īs in the case, but a 420 performs better IIRC, and 140 mm fans simply just look cooler its go big or go home
__________________
Old 4th Dec 2009, 16:40   #18
Nutman
Nutman's Avatar
Sorry, I DID mean a 420 - I meant that if you're able to cram a 420 in the top (not sure if that's your plan or not) then you should be able to put one in the bottom aswell, and this would give you the same output as input. Not considering what other fans, you plan to put in there, of course.... (I noticed 3 fans in the front, cooling down each of the pumps?)
__________________
Old 4th Dec 2009, 16:47   #19
Nutman
Nutman's Avatar
Oh, and in regards to the Aquaero controlling the Laing pumps, try 3 of these:
http://www.vcore.dk/shop/ac-poweradjust-usb-909p.html
Or just buy 3 10W Laing DDCs and use one of these to control all of them simultaneously - but you lose some flexibility that way, however. And this makes me think about WHY you're chosing 3 pumps, when you only THINK about adding a second loop? Did you really plan to use 3 pumps for just one single loop? Seems kind of.... american?
__________________
Old 4th Dec 2009, 23:09   #20
p0Pe
gief cake?
p0Pe's Avatar
do you have any idea of how long the 420 is wont fit the top of the case its only 41 cm long lol!
regarding the air thing, then thats not one of my biggest concerns:P there is going to be 2 140 mm outtakes, and the psu. should be enough. and yes, the radiator is going to be in front where you see the 3 fans now
as for the pumps, ive changed my minds about having them there. and i will start out with one, and see if i go dual loop, or just huge single loop.
and in case you didnt notice my comment in the last post ill say it again: GO BIG OR GO HOME
as i once said, it aint overkill until something dies from it
apriciate the comments
next weekend, the mobo tray will be cut, and i hope to have most of my watercooling gear sorry for the lack of pics, but im going big updates this time, instead of small 3 pic updates:P
Edit:
and i will most likely see if i can get my hands on the koolance tms-200 board, since it can handle much more than the aquaero.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
